Den ersten Fehler kannste ignorieren.
Den unteren liegt daran das du das HowTo nicht komplett befolgt hast.
Dort habe ich geschrieben das man weiter Pakete über Yast installieren muss.
apache apache_mmn_20051115 is needed by apache2-mod_php5-5.1.2-3.1.20060127
Please select the components you want to install:
1. [*] Base packages of Plesk
2. [=] Plesk Updater
3. [*] Apache ASP support
4. [*] Mailman mailing list manager support
5. [=] PosgreSQL server support
6. [*] Tomcat Java Servlets support
7. [*] SpamAssassin support
8. [*] SPAM blocker for QMail daemon
9. [=] Apache mod_python module
10. [*] Ruby on Rails support
11. [=] FastCGI support (mod_fcgid)
12. [*] Application vault packages
13. [*] Additional Horde (webmail) components for Plesk
14. [*] Additional Plesk manuals
15. [*] Plesk Backup Manager
16. [*] Dr. Web antivirus
17. [*] Kaspersky antivirus module
18. [ ] Plesk Professional Web Site Editor
19. [*] Plesk API [former Plesk Agent]
20. [*] SSHTerm - SSH Terminal java applet
21. [*] Plesk migration manager
22. [*] Plesk Firewall module
23. [*] Plesk Counter-Strike game server module
24. [*] Plesk VPN module
25. [*] Plesk Battlefield 1942 game server module
26. [*] Plesk Battlefield2 game server module
27. [*] Plesk Fileserver module and SMB file server package
28. [*] Watchdog (System monitoring module)
29. [*] SiteBuilder and Sitebuilder module for Plesk
30. [ ] SiteBuilder publishing support for Plesk
31. [*] ColdFusion support for Plesk
32. [*] MIVA Empresa support
33. [*] OpenFusion SSO support
34. [=] German language pack
35. [ ] Japanese language pack
36. [ ] Spanish language pack
37. [ ] Russian language pack
38. [ ] French language pack
39. [ ] Italian language pack
40. [ ] Chinese language pack for China
41. [ ] Chinese language pack for Taiwan
N) Next page; P) Go back; Q) Cancel installing;
A) Select all; D) Deselect all;
To select or deselect a component, enter its number;
Type a number or a character of desired action [N]:
Exchanging information with licensing server.
Retrieving information about the installed packages... done
Downloading the file PSA_8.2.1/dist-rpm-SuSE-9.3-x86_64/build-8.2.1-suse9.3-x86_64.hdr.gz: 20%..53%..89%..100% done.
Downloading the file PSA_8.2.1/update-rpm-SuSE-9.3-x86_64/update-8.2.1-suse9.3-x86_64.hdr.gz: 31%..64%..94%..100% done.
Downloading the file PSA_8.2.1/thirdparty-rpm-SuSE-9.3-x86_64/thirdparty-8.2.1-suse9.3-x86_64.hdr.gz: 100% done.
Determining the packages that need to be installed.
ERROR: Unable to proceed with the installation until the package apache2-mod_perl-2.0.0-4.i586 is removed from the system.
Not all packages were installed.
Please, resolve the above problem and try installing the packages again.
If you cannot resolve the problem on your own, contact product technical support for assistance.
s15249307:~ #
'../configure' '--prefix=/usr' '--datadir=/usr/share/php5' '--mandir=/usr/share/man' '--bindir=/usr/bin' '--with-libdir=lib' '--includedir=/usr/include' '--sysconfdir=/etc/php5/apache2' '--with-config-file-path=/etc/php5/apache2' '--with-config-file-scan-dir=/etc/php5/conf.d' '--enable-libxml' '--enable-session' '--with-mm' '--with-pcre-regex' '--enable-xml' '--enable-simplexml' '--enable-spl' '--enable-filter' '--disable-debug' '--enable-inline-optimization' '--disable-rpath' '--disable-static' '--enable-shared' '--program-suffix=5' '--with-pic' '--with-apxs2=/usr/sbin/apxs2' '--disable-all' '--disable-cli'
ls -la
mysql_fix_privilege_tables --user=admin --password=`cat /etc/psa/.psa.shadow`
We use cookies and similar technologies to provide the best experience on our website. You can choose which purposes you consent to. Your choice applies across websites using the same consent framework.
Below you can select which purposes you consent to. Purpose 1 is required for basic website functionality.
Cookies, device or similar online identifiers together with other information can be stored or read on your device for the purposes presented to you.
Ads can be shown to you based on the content you are viewing, the app you are using, your approximate location, or your device type.
A profile can be built about you and your interests to show you personalised ads that are relevant to you.
Personalised ads can be shown to you based on a profile about you.
A profile can be built about you and your interests to show you personalised content that is relevant to you.
Personalised content can be shown to you based on a profile about you.
The performance and effectiveness of ads that you see or interact with can be measured.
The performance and effectiveness of content that you see or interact with can be measured.
Market research can be used to learn more about the audiences who visit sites/apps and view ads.
Your data can be used to improve existing systems and software, and to develop new products.
Content can be selected based on limited data, such as the content you are viewing or the device you are using.
Below is a list of all technology vendors that may process your data. You can enable or disable each vendor individually.
