Plesk Spamdyke Control Panel
Das klingt super :)
Hier mal die Struktur bei meinem Suse 9.3 32bit
Aug 19 19:52:15 lvps87-230-7-234 relaylock: /var/qmail/bin/relaylock: mail from xxx.xxx.191.11:3962 (not defined)
Aug 19 19:52:52 lvps87-230-7-234 relaylock: /var/qmail/bin/relaylock: mail from xxx.xxx.33.46:60250 (smtp10.xxx.de)
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue[32439]: scan: the message(drweb.tmp.LwTgVz) sent by [email protected] to [email protected] is passed
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue-handlers[32441]: Handlers Filter before-queue for qmail started ...
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue-handlers[32441]: [email protected]
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue-handlers[32441]: hook_dir = '/var/qmail//handlers/before-queue'
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue-handlers[32441]: recipient[3] = '[email protected]'
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue-handlers[32441]: handlers dir = '/var/qmail//handlers/before-queue/recipient/[email protected]'
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.533621 new msg 455099516
Aug 19 19:52:58 lvps87-230-7-234 qmail-queue-handlers[32441]: starter: submitter[32442] exited normally
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.542011 info msg 455099516: bytes 1169 from <[email protected]> qp 32442 uid 2020
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.549528 starting delivery 141: msg 455099516 to local [email protected]
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.549619 status: local 1/10 remote 0/20
Aug 19 19:52:58 lvps87-230-7-234 qmail-local-handlers[32443]: Handlers Filter before-local for qmail started ...
Aug 19 19:52:58 lvps87-230-7-234 qmail-local-handlers[32443]: [email protected]
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.726702 delivery 141: success: did_0+0+2/
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.726793 status: local 0/10 remote 0/20
Aug 19 19:52:58 lvps87-230-7-234 qmail: 1219168378.726856 end msg 455099516
Muss ich da noch irgendwas einstellen damit der mitloggt?
Also das Greylisting von Spamdyke funzt auf jeden Fall da bei einer eingehenden Mail die Ordner und Dateien im Greylisting angelegt werden ...
Grüße
Chris
Dann duchsuch mal Deine Logs wo "ALLOWED" bzw. "XXXX_DENIED" drin vorkommt.
In der spamdyke.conf sollte der Log-Level auf Info stehen:
Erste Zeile -> log-level=info
Gut zu wissen, mal wieder herzlichen Dank!
Der Parameter kam in meiner conf gar nicht vor.
Jetzt funzt alles super und es wird auch alles richtig im CP angezeigt :)
Grüße
Chris
Danke haggybear
Hallo haggybear,
danke für die Version 0.5 habe sie gerade per update installiert.
Mir ist aufgefallen das die Symbole für White-/Black-List nicht die richtigen Rechte bekommen, und deswegen nicht angezeigt werden.
Sonst hat alles bestens funktioniert, und die neuen Funktionen finde ich klasse.
Großes LOB an deine Person.
Harpi
Version 0.6
Moin,
die Version 0.6 ist fertig, wir nähern uns mit großen Schritten der ersten Stable!!! Danke an alle Tester und Ideengeber!
Diese Version enthält nun die Auswahl wie viele Einträge pro Seite angezeigt werden sollen. Ausserdem kann eingeschaltet werden ob das SCP Pärchen bilden soll aus einer ALLOWED<>DENIED Kostellation beim Greylisting um die Laufzeit evtl. nachvollziehen zu können.
Bitte NICHT per AU! Die config.inc.php hat sich geändert, hier muss jetzt den komplette Pfad zum qMail Logfile angegeben werden.
Haggy
So, nun lüppt alles bei mir :)
Aber ich hab mal eine Frage, was bedeutet genau die Einstellung "Greylisting für Domain : deaktiv / aktiv "
Ob das Greylisting greift oder nicht ...
Also wenn dus aktiviert hast für die Domain dann werden eingehende Mails vorher mittels greylisting gecheckt und falls es deaktiviert ist dann halt nicht!
Grüße
Chris
ok!
Wenn ich den SCP nicht für die einzelnen Domains nutzen will sondern Global für den ganzen Server, dann reicht es doch wenn ich den Benutzerdefinierten Button im Ort Navigationsfenster erstelle und nur die Sichtbarkeit für die User deaktiviere oder muß ich dann noch auf was anderes achten?
Version 0.7
Damit wäre auch die Version 0.7 da! Ich habe hier die farbliche Aufbereitung der Greylisting-Pärchen überarbeitet und eine Überprüfung der spamdyke.conf eingebaut, dass der Log-Level richtig gesetzt ist.
Desweiteren ist eine Administration hinzugekommen, die es erlaubt den Plesk Event-Handler zu verwalten um Spamdyke bei der Domainverwaltung mit einzubeziehen. Wenn gewünscht, dann richtet das SCP Plesk so ein, das der Greylisting-Order für eine neu angelegte Domain automatisch mit angelegt wird.
Download -> www.haggybear.de
Haggy
log-level
mir ist aufgefallen das dein tool jetzt den log-level überprüft. Ich hatte den level auf "verbose". Das Tool sucht aber nur nach "info",deswegen war es der Meinung ich habe kein log-level eingestell.
Harpi
Version 0.8
Die nächste, evtl. schon letzte Vor-Stable, Version. Ich habe einen Filter implementiert um die Einträge nach der "Bewertung" anzuzeigen. Ausserdem ich habe das Überprüfen der spamdyke.conf gelockert, so dass man auch mit den Log-Leveln "debug", "verbose" und "exessive" arbeiten kann.
Haggy
Hi, hab noch einen Fehler beim updater gefunden:
Die Dateien "wl.jpg" und "bl.jpg" werden nicht mit Rechten versehen und sind somit nicht sichtbar.
Ansonsten lüppt es schon echt SUPER:cool:
Interessant wäre auch noch eine Statistikfunktion für einen Monat oder Woche oder Tag mit Balkendiagramm ;)
Auch nicht schlecht wäre eine an/abschaltfunktion in der Ansicht für die einzelnen Spalten (z.B. Bewertung nicht anzeigen...)
Vielleicht auch noch die Rechte des Domaineigentümers unter Administration.
:cool:
Version 1.0
damit wäre die erste Stable des SCP fertig. Danke an alle Tester!!
Mit der Version 1.0 ist nun auch die Suche aktiv sowie die Ansicht ob die Mail eingehend, ausgehend oder lokal war.
Haggy
Super Sache
erst einmal Super Sache diese Geschichte, Danke.
Ich habe es mal auf folgender Plattform installiert.
Suse 10.3 / Plesk 8.6
Spamdyke läuft lt. Logfiles. Qmail wird in Plesk als down angezeigt, aber funktioniert.
Das Control Panel läuft auch soweit. Nur wird dort nichts angezeigt. Weder Mails die durchgelassen wurden noch sonst was. Wenn ich den Benutzerdefinierten Button anklicke geht das Panel auch, und er zeigt immer an das das Greylisting "deaktiv" ist. Wenn ich es auf "aktiviert" setze und speichere geht es wieder auf deaktiv.
Die Spalte "Rechte des Domaineigentümers" kann geändert werden.
Was mir auch aufgefallen ist, er schreibt in das Verzeichnis /var/qmail/spamdyke/greylist/ auch nichts rein. Ausserdem steht in der mail-info auch nur bei dem Spamdyke Prozess ALLOWED drin und nicht beim ersten mal denied. Hat das vielleicht was mit meiner Installation oder Konfiguration zu tun?
Vielen dank schon mal für ein paar Tips.
