huschi said:MOD: Full-Quote gekürzt!
Lösung: Halte den Apache im Rahmen des Hauptspeichers.
Und genau das regulierst Du mit MaxClients.
SLOW QUERIES
The slow query log is NOT enabled.
Current long_query_time = 10.000000 sec.
You have 3 out of 1591205 that take longer than 10.000000 sec. to complete
Your long_query_time seems to be fine
BINARY UPDATE LOG
The binary update log is NOT enabled.
You will not be able to do point in time recovery
See [url]http://dev.mysql.com/doc/refman/5.1/en/point-in-time-recovery.html[/url]
WORKER THREADS
Current thread_cache_size = 256
Current threads_cached = 0
Current threads_per_sec = 0
Historic threads_per_sec = 0
MAX CONNECTIONS
Current max_connections = 125
Current threads_connected = 2
Historic max_used_connections = 2
The number of used connections is 1% of the configured maximum.
You are using less than 10% of your configured max_connections.
Lowering max_connections could help to avoid an over-allocation of memory
See "MEMORY USAGE" section to make sure you are not over-allocating
INNODB STATUS
Current InnoDB index space = 11 M
Current InnoDB data space = 5 M
Current InnoDB buffer pool free = 56 %
Current innodb_buffer_pool_size = 8 M
Depending on how much space your innodb indexes take up it may be safe
to increase this value to up to 2 / 3 of total system memory
MEMORY USAGE
Max Memory Ever Allocated : 59 M
Configured Max Per-thread Buffers : 93 M
Configured Max Global Buffers : 58 M
Configured Max Memory Limit : 151 M
Physical Memory : 15.70 G
KEY BUFFER
Current MyISAM index space = 137 M
Current key_buffer_size = 24 M
Key cache miss rate is 1 : 59
Key buffer free ratio = 0 %
You could increase key_buffer_size
It is safe to raise this up to 1/4 of total system memory;
assuming this is a dedicated database server.
QUERY CACHE
Query cache is enabled
Current query_cache_size = 24 M
Current query_cache_used = 1 M
Current query_cache_limit = 4 M
Current Query cache Memory fill ratio = 5.64 %
Current query_cache_min_res_unit = 4 K
Your query_cache_size seems to be too high.
Perhaps you can use these resources elsewhere
MySQL won't cache query results that are larger than query_cache_limit in size
SORT OPERATIONS
Current sort_buffer_size = 256 K
Current read_rnd_buffer_size = 128 K
Sort buffer seems to be fine
JOINS
Current join_buffer_size = 132.00 K
You have had 0 queries where a join could not use an index properly
Your joins seem to be using indexes properly
OPEN FILES LIMIT
Current open_files_limit = 4231 files
TABLE CACHE
Current table_open_cache = 2048 tables
Current table_definition_cache = 256 tables
You have a total of 700 tables
You have 701 open tables.
The table_cache value seems to be fine
You should probably increase your table_definition_cache value.
TEMP TABLES
Current max_heap_table_size = 16 M
Current tmp_table_size = 16 M
Of 1078 temp tables, 9% were created on disk
TABLE SCANS
Current read_buffer_size = 128 K
Current table scan ratio = 14 : 1
TABLE LOCKING
Current Lock Wait ratio = 0 : 1591460
Your table locking seems to be fine
- By: Matthew Montgomery -
MySQL Version 5.1.49-1ubuntu8.1 x86_64
Uptime = 0 days 0 hrs 15 min 27 sec
Avg. qps = 2
Total Questions = 2481
Threads Connected = 2
Warning: Server has not been running for at least 48hrs.
It may not be safe to use these recommendations
http://dev.mysql.com/doc/refman/5.1/en/server-system-variables.html
Visit http://www.mysql.com/products/enterprise/advisors.html
for info about MySQL's Enterprise Monitoring and Advisory Service
SLOW QUERIES
You have 0 out of 2502 that take longer than 10.000000 sec. to complete
BINARY UPDATE LOG
See http://dev.mysql.com/doc/refman/5.1/en/point-in-time-recovery.html
WORKER THREADS
Current thread_cache_size = 8
MAX CONNECTIONS
Current max_connections = 151
INNODB STATUS
Current InnoDB index space = 0 bytes
Current InnoDB data space = 0 bytes
Current InnoDB buffer pool free = 96 %
MEMORY USAGE
Max Memory Ever Allocated : 47 M
Configured Max Per-thread Buffers : 405 M
Configured Max Global Buffers : 42 M
Configured Max Memory Limit : 447 M
Physical Memory : 1.91 G
KEY BUFFER
Current MyISAM index space = 5 M
Current key_buffer_size = 16 M
Key cache miss rate is 1 : 147
Key buffer free ratio = 81 %
Your key_buffer_size seems to be fine
QUERY CACHE
Current query_cache_size = 16 M
Current query_cache_used = 432 K
Current query_cache_limit = 1 M
Current Query cache Memory fill ratio = 2.63 %
Query Cache is 31 % fragmented
Run "FLUSH QUERY CACHE" periodically to defragment the query cache memory
If you have many small queries lower 'query_cache_min_res_unit' to reduce fragmentation.
SORT OPERATIONS
Current sort_buffer_size = 2 M
Current read_rnd_buffer_size = 256 K
JOINS
OPEN FILES LIMIT
Current open_files_limit = 1024 files
TABLE CACHE
Current table_open_cache = 64 tables
You have a total of 230 tables
You have 64 open tables.
Current table_cache hit rate is 2%
, while 100% of your table cache is in use
TEMP TABLES
Of 600 temp tables, 15% were created on disk
TABLE SCANS
Current table scan ratio = 50 : 1
TABLE LOCKING
Current Lock Wait ratio = 0 : 2757
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "foo.log"
# with ServerRoot set to "/etc/apache2" will be interpreted by the
# server as "/etc/apache2/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs/2.2/mod/mpm_common.html#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
LockFile ${APACHE_LOCK_DIR}/accept.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 1
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 50
MaxRequestsPerChild 8000
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadLimit: ThreadsPerChild can be changed to this maximum value during a
# graceful restart. ThreadLimit can only be changed by stopping
# and starting Apache.
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule mpm_worker_module>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
MaxClients 150
MaxRequestsPerChild 0
</IfModule>
# event MPM
<IfModule mpm_event_module>
StartServers 2
MaxClients 150
MinSpareThreads 25
MaxSpareThreads 75
ThreadLimit 64
ThreadsPerChild 25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
Satisfy all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# logged here. If you *do* define an error logfile for a <VirtualHost>
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include mods-enabled/*.load
Include mods-enabled/*.conf
# Include all the user configurations:
Include httpd.conf
# Include ports listing
Include ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
Include conf.d/
# Include the virtual host configurations:
Include sites-enabled/
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
# * IMPORTANT
# If you make changes to these settings and your system uses apparmor, you may
# also need to also adjust /etc/apparmor.d/usr.sbin.mysqld.
user = mysql
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
# * Fine Tuning
key_buffer = 16M
max_allowed_packet = 16M
thread_stack = 192K
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
# * Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
log_error = /var/log/mysql/error.log
# Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
# other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
# * IMPORTANT: Additional settings that can override those from this file!
# The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
Alles drei und auch noch vier.sind die Empfehlungen hier nur für Vserver oder für kleine Server mit wenig RAM und CPU, oder allgemein für alle MYSQL.
Ist eine Perl-Implementation des tuning-primer-Scripts.habe ich bei Google gefunden das da auch mit mysqltuner.pl MySQL-Optimierung möglich ist.
# ./mysqltuner.pl
>> MySQLTuner 1.0.1 - Major Hayden <major@mhtx.net>
>> Bug reports, feature requests, and downloads at http://mysqltuner.com/
>> Run with '--help' for additional options and output filtering
-------- General Statistics --------------------------------------------------
[--] Skipped version check for MySQLTuner script
[OK] Currently running supported MySQL version 5.0.51a-24+lenny5
[OK] Operating on 32-bit architecture with less than 2GB RAM
-------- Storage Engine Statistics -------------------------------------------
[--] Status: +Archive -BDB -Federated +InnoDB -ISAM -NDBCluster
[--] Data in MyISAM tables: 101M (Tables: 5470)
[--] Data in InnoDB tables: 3M (Tables: 178)
[!!] Total fragmented tables: 432
-------- Performance Metrics -------------------------------------------------
[--] Up for: 5d 0h 55m 53s (3M q [7.496 qps], 138K conn, TX: 269M, RX: 570M)
[--] Reads / Writes: 65% / 35%
[--] Total buffers: 51.0M global + 2.6M per thread (100 max threads)
[OK] Maximum possible memory usage: 313.5M (15% of installed RAM)
[OK] Slow queries: 0% (11/3M)
[!!] Highest connection usage: 100% (101/100)
[OK] Key buffer size / total MyISAM indexes: 16.0M/31.6M
[OK] Key buffer hit rate: 97.3% (5M cached / 153K reads)
[OK] Query cache efficiency: 71.4% (1M cached / 1M selects)
[!!] Query cache prunes per day: 26112
[OK] Sorts requiring temporary tables: 0% (0 temp sorts / 57K sorts)
[!!] Joins performed without indexes: 2408
[!!] Temporary tables created on disk: 34% (92K on disk / 267K total)
[OK] Thread cache hit rate: 98% (1K created / 138K connections)
[!!] Table cache hit rate: 0% (64 open / 313K opened)
[OK] Open file limit used: 12% (126/1K)
[OK] Table locks acquired immediately: 99% (1M immediate / 1M locks)
[!!] InnoDB data size / buffer pool: 4.0M/2.0M
-------- Recommendations -----------------------------------------------------
General recommendations:
Run OPTIMIZE TABLE to defragment tables for better performance
Enable the slow query log to troubleshoot bad queries
Reduce or eliminate persistent connections to reduce connection usage
Adjust your join queries to always utilize indexes
When making adjustments, make tmp_table_size/max_heap_table_size equal
Reduce your SELECT DISTINCT queries without LIMIT clauses
Increase table_cache gradually to avoid file descriptor limits
Variables to adjust:
max_connections (> 100)
wait_timeout (< 28800)
interactive_timeout (< 28800)
query_cache_size (> 16M)
join_buffer_size (> 128.0K, or always use indexes with joins)
tmp_table_size (> 32M)
max_heap_table_size (> 16M)
table_cache (> 64)
innodb_buffer_pool_size (>= 3M)
Stimmt das denn? Oben redest Du von einem 64-bit Server mit 12 GB RAM.[OK] Operating on 32-bit architecture with less than 2GB RAM
MySQL Version 5.0.51a-24+lenny5-log i486
Uptime = 78 days 1 hrs 56 min 40 sec
Avg. qps = 8
Total Questions = 54330637
Threads Connected = 1
Server has been running for over 48hrs.
It should be safe to follow these recommendations
http://dev.mysql.com/doc/refman/5.0/en/server-system-variables.html
SLOW QUERIES
The slow query log is enabled.
Current long_query_time = 2 sec.
You have 5275979 out of 54330658 that take longer than 2 sec. to complete
BINARY UPDATE LOG
See http://dev.mysql.com/doc/refman/5.0/en/point-in-time-recovery.html
WORKER THREADS
Current threads_cached = 7
MAX CONNECTIONS
Current max_connections = 100
Current threads_connected = 1
Historic max_used_connections = 11
The number of used connections is 11% of the configured maximum.
Your max_connections variable seems to be fine.
INNODB STATUS
Current InnoDB index space = 15 M
Current InnoDB data space = 8 M
Current InnoDB buffer pool free = 0 %
MEMORY USAGE
Configured Max Per-thread Buffers : 262 M
Configured Max Global Buffers : 19 M
Configured Max Memory Limit : 281 M
Physical Memory : 1.96 G
KEY BUFFER
Current MyISAM index space = 171 M
Current key_buffer_size = 1 M
Key cache miss rate is 1 : 29
Key buffer free ratio = 88 %
QUERY CACHE
Current query_cache_size = 8 M
Current query_cache_used = 6 M
Current Query cache Memory fill ratio = 84.28 %
However, 6693182 queries have been removed from the query cache due to lack of memory
Perhaps you should raise query_cache_size
SORT OPERATIONS
JOINS
You have had 3657 queries where a join could not use an index properly
You have had 7 joins without keys that check for key usage after each row
OPEN FILES LIMIT
TABLE CACHE
Current table_cache value = 64 tables
You have a total of 1736 tables
Current table_cache hit rate is 0%
TEMP TABLES
Current tmp_table_size = 32 M
Of 973109 temp tables, 30% were created on disk
Perhaps you should increase your tmp_table_size and/or max_heap_table_size
to reduce the number of disk-based temporary tables
Note! BLOB and TEXT columns are not allow in memory tables.
If you are using these columns raising these values might not impact your
ratio of on disk temp tables.
TABLE SCANS
Current table scan ratio = 72 : 1
TABLE LOCKING
Current Lock Wait ratio = 1 : 4120
You may benefit from selective use of InnoDB.
If you have long running SELECT's against MyISAM tables and perform
frequent updates consider setting 'low_priority_updates=1'
If you have a high concurrency of inserts on Dynamic row-length tables
consider setting 'concurrent_insert=2'.
Und jetzt bitte noch dazu Deine Fragen spezifizieren. Denn woher sollen wir wissen, was Du davon verstanden hast und was nicht?Teile verstehe ich zwar, doch bei weitem nicht alles.
