# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "/var/log/apache2/foo.log"
# with ServerRoot set to "" will be interpreted by the
# server as "//var/log/apache2/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs-2.1/mod/mpm_common.html#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
#<IfModule !mpm_winnt.c>
#<IfModule !mpm_netware.c>
LockFile /var/lock/apache2/accept.lock
#</IfModule>
#</IfModule>
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 30
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 150
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 2
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
StartServers 5
MinSpareServers 5
MaxSpareServers 10
MaxClients 100
MaxRequestsPerChild 0
</IfModule>
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule mpm_worker_module>
StartServers 2
MaxClients 100
MinSpareThreads 25
MaxSpareThreads 75
ThreadsPerChild 25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# logged here. If you *do* define an error logfile for a <VirtualHost>
ErrorLog /var/log/apache2/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include /etc/apache2/mods-enabled/*.load
Include /etc/apache2/mods-enabled/*.conf
# Include all the user configurations:
Include /etc/apache2/httpd.conf
# Include ports listing
Include /etc/apache2/ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %b" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Define an access log for VirtualHosts that don't define their own logfile
CustomLog /var/log/apache2/other_vhosts_access.log vhost_combined
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# Putting this all together, we can internationalize error responses.
# We use Alias to redirect any /error/HTTP_<error>.html.var response to
# our collection of by-error message multi-language collections. We use
# includes to substitute the appropriate text.
# You can modify the messages' appearance without changing any of the
# default HTTP_<error>.html.var files by adding the line:
# Alias /error/include/ "/your/include/path/"
# which allows you to create your own set of files by starting with the
# /usr/share/apache2/error/include/ files and copying them to /your/include/path/,
# even on a per-VirtualHost basis. The default include files will display
# your Apache version number and your ServerAdmin email address regardless
# of the setting of ServerSignature.
# The internationalized error documents require mod_alias, mod_include
# and mod_negotiation. To activate them, uncomment the following 30 lines.
# Alias /error/ "/usr/share/apache2/error/"
# <Directory "/usr/share/apache2/error">
# AllowOverride None
# Options IncludesNoExec
# AddOutputFilter Includes html
# AddHandler type-map var
# Order allow,deny
# Allow from all
# LanguagePriority en cs de es fr it nl sv pt-br ro
# ForceLanguagePriority Prefer Fallback
# </Directory>
# ErrorDocument 400 /error/HTTP_BAD_REQUEST.html.var
# ErrorDocument 401 /error/HTTP_UNAUTHORIZED.html.var
# ErrorDocument 403 /error/HTTP_FORBIDDEN.html.var
# ErrorDocument 404 /error/HTTP_NOT_FOUND.html.var
# ErrorDocument 405 /error/HTTP_METHOD_NOT_ALLOWED.html.var
# ErrorDocument 408 /error/HTTP_REQUEST_TIME_OUT.html.var
# ErrorDocument 410 /error/HTTP_GONE.html.var
# ErrorDocument 411 /error/HTTP_LENGTH_REQUIRED.html.var
# ErrorDocument 412 /error/HTTP_PRECONDITION_FAILED.html.var
# ErrorDocument 413 /error/HTTP_REQUEST_ENTITY_TOO_LARGE.html.var
# ErrorDocument 414 /error/HTTP_REQUEST_URI_TOO_LARGE.html.var
# ErrorDocument 415 /error/HTTP_UNSUPPORTED_MEDIA_TYPE.html.var
# ErrorDocument 500 /error/HTTP_INTERNAL_SERVER_ERROR.html.var
# ErrorDocument 501 /error/HTTP_NOT_IMPLEMENTED.html.var
# ErrorDocument 502 /error/HTTP_BAD_GATEWAY.html.var
# ErrorDocument 503 /error/HTTP_SERVICE_UNAVAILABLE.html.var
# ErrorDocument 506 /error/HTTP_VARIANT_ALSO_VARIES.html.var
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
Include /etc/apache2/conf.d/
# Include the virtual host configurations:
Include /etc/apache2/sites-enabled/
AddOutputFilter INCLUDES .shtml
AddType text/html .shtml
AddType application/x-httpd-php .php
AddType application/x-httpd-php-source .phps
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
bind-address = 127.0.0.1
# * Fine Tuning
key_buffer = 16M
max_allowed_packet = 16M
thread_stack = 192K
thread_cache_size = 8
# This replaces the startup script and checks MyISAM tables if needed
# the first time they are touched
myisam-recover = BACKUP
#max_connections = 100
#table_cache = 64
#thread_concurrency = 10
# * Query Cache Configuration
query_cache_limit = 1M
query_cache_size = 16M
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
# As of 5.1 you can enable the log at runtime!
#general_log_file = /var/log/mysql/mysql.log
#general_log = 1
# Error logging goes to syslog due to /etc/mysql/conf.d/mysqld_safe_syslog.cnf.
# Here you can see queries with especially long duration
#log_slow_queries = /var/log/mysql/mysql-slow.log
#long_query_time = 2
#log-queries-not-using-indexes
# The following can be used as easy to replay backup logs or for replication.
# note: if you are setting up a replication slave, see README.Debian about
# other settings you may need to change.
#server-id = 1
#log_bin = /var/log/mysql/mysql-bin.log
expire_logs_days = 10
max_binlog_size = 100M
#binlog_do_db = include_database_name
#binlog_ignore_db = include_database_name
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * InnoDB plugin
# As of MySQL 5.1.38, the InnoDB plugin from Oracle is included in the MySQL source code.
# It has many improvements and better performances than the built-in InnoDB storage engine.
# Please read http://www.innodb.com/products/innodb_plugin/ for more information.
# Uncommenting the two following lines to use the InnoDB plugin.
#ignore_builtin_innodb
#plugin-load=innodb=ha_innodb_plugin.so
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# For generating SSL certificates I recommend the OpenSSL GUI "tinyca".
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
# * IMPORTANT: Additional settings that can override those from this file!
# The files must end with '.cnf', otherwise they'll be ignored.
!includedir /etc/mysql/conf.d/
n112h143:/usr/bin# tuning-primer.sh
- By: Matthew Montgomery -
MySQL Version 5.1.51-0.dotdeb.1 i486
Uptime = 1 days 22 hrs 57 min 23 sec
Avg. qps = 0
Total Questions = 134530
Threads Connected = 2
Warning: Server has not been running for at least 48hrs.
It may not be safe to use these recommendations
http://dev.mysql.com/doc/refman/5.1/en/server-system-variables.html
Visit http://www.mysql.com/products/enterprise/advisors.html
for info about MySQL's Enterprise Monitoring and Advisory Service
SLOW QUERIES
The slow query log is NOT enabled.
Current long_query_time = 10.000000 sec.
You have 2 out of 134551 that take longer than 10.000000 sec. to complete
Your long_query_time seems to be fine
BINARY UPDATE LOG
The binary update log is NOT enabled.
You will not be able to do point in time recovery
See http://dev.mysql.com/doc/refman/5.1/en/point-in-time-recovery.html
WORKER THREADS
Current thread_cache_size = 8
Current threads_cached = 7
Current threads_per_sec = 0
Historic threads_per_sec = 0
MAX CONNECTIONS
Current max_connections = 151
Current threads_connected = 2
Historic max_used_connections = 20
The number of used connections is 13% of the configured maximum.
Your max_connections variable seems to be fine.
INNODB STATUS
Current InnoDB index space = 3 M
Current InnoDB data space = 3 M
Current InnoDB buffer pool free = 13 %
Current innodb_buffer_pool_size = 8 M
Depending on how much space your innodb indexes take up it may be safe
to increase this value to up to 2 / 3 of total system memory
MEMORY USAGE
Max Memory Ever Allocated : 95 M
Configured Max Per-thread Buffers : 405 M
Configured Max Global Buffers : 42 M
Configured Max Memory Limit : 447 M
Physical Memory : 1.97 G
KEY BUFFER
Current MyISAM index space = 46 M
Current key_buffer_size = 16 M
Key cache miss rate is 1 : 117
Key buffer free ratio = 88 %
Your key_buffer_size seems to be fine
QUERY CACHE
Query cache is enabled
Current query_cache_size = 16 M
Current query_cache_used = 15 M
Current query_cache_limit = 1 M
Current Query cache Memory fill ratio = 99.34 %
Current query_cache_min_res_unit = 4 K
However, 6112 queries have been removed from the query cache due to lack of memory
Perhaps you should raise query_cache_size
MySQL won't cache query results that are larger than query_cache_limit in size
SORT OPERATIONS
Current sort_buffer_size = 2 M
Current read_rnd_buffer_size = 256 K
Sort buffer seems to be fine
JOINS
Current join_buffer_size = 132.00 K
You have had 37 queries where a join could not use an index properly
OPEN FILES LIMIT
Current open_files_limit = 1024 files
TABLE CACHE
Current table_open_cache = 64 tables
Current table_definition_cache = 256 tables
You have a total of 864 tables
You have 64 open tables.
Current table_cache hit rate is 0%
, while 100% of your table cache is in use
You should probably increase your table_definition_cache value.
TEMP TABLES
Current max_heap_table_size = 16 M
Current tmp_table_size = 16 M
Of 10174 temp tables, 29% were created on disk
Perhaps you should increase your tmp_table_size and/or max_heap_table_size
to reduce the number of disk-based temporary tables
Note! BLOB and TEXT columns are not allow in memory tables.
If you are using these columns raising these values might not impact your
ratio of on disk temp tables.
TABLE SCANS
Current read_buffer_size = 128 K
Current table scan ratio = 406 : 1
TABLE LOCKING
Current Lock Wait ratio = 1 : 991
You may benefit from selective use of InnoDB.
If you have long running SELECT's against MyISAM tables and perform
frequent updates consider setting 'low_priority_updates=1'
If you have a high concurrency of inserts on Dynamic row-length tables
consider setting 'concurrent_insert=2'.
Heißt konkret?Die Optimierung meines Sql-servers bereitet mir momentan Probleme
[client]
port = 3306
[mysqld_safe]
nice = 0
[mysqld]
# * Basic Settings
user = mysql
port = 3306
basedir = /usr
tmpdir = /tmp
# * Fine Tuning
key_buffer = 16M
thread_stack = 192K
table_cache = 1024
thread_concurrency = 8
#general_log = 1
long_query_time = 2
#server-id = 1
# * InnoDB
# * InnoDB plugin
[mysqldump]
quick
quote-names
[mysql]
[isamchk]
key_buffer = 16M
MySQL Version 5.1.51-0.dotdeb.1-log i486
Uptime = 0 days 0 hrs 6 min 21 sec
Avg. qps = 761
Total Questions = 290056
Threads Connected = 3
SLOW QUERIES
The slow query log is enabled.
Current long_query_time = 2.000000 sec.
You have 0 out of 290088 that take longer than 2.000000 sec. to complete
BINARY UPDATE LOG
The binary update log is enabled
Binlog sync is not enabled, you could loose binlog records during a server crash
WORKER THREADS
Current threads_cached = 0
MAX CONNECTIONS
Current max_connections = 100
Current threads_connected = 3
Historic max_used_connections = 3
The number of used connections is 3% of the configured maximum.
You are using less than 10% of your configured max_connections.
Lowering max_connections could help to avoid an over-allocation of memory
See "MEMORY USAGE" section to make sure you are not over-allocating
INNODB STATUS
Current InnoDB buffer pool free = 19 %
MEMORY USAGE
Max Memory Ever Allocated : 50 M
Configured Max Per-thread Buffers : 271 M
Configured Max Memory Limit : 313 M
KEY BUFFER
Current MyISAM index space = 44 M
Key cache miss rate is 1 : 15766
Key buffer free ratio = 87 %
Your key_buffer_size seems to be too high.
Perhaps you can use these resources elsewhere
QUERY CACHE
Current query_cache_used = 19 K
Current Query cache Memory fill ratio = .12 %
Your query_cache_size seems to be too high.
SORT OPERATIONS
JOINS
You have had 0 queries where a join could not use an index properly
Your joins seem to be using indexes properly
OPEN FILES LIMIT
Current open_files_limit = 2158 files
TABLE CACHE
Current table_open_cache = 1024 tables
You have a total of 896 tables
You have 897 open tables.
The table_cache value seems to be fine
TEMP TABLES
Of 580 temp tables, 12% were created on disk
TABLE SCANS
Current table scan ratio = 9 : 1
TABLE LOCKING
Current Lock Wait ratio = 0 : 293384
Your table locking seems to be fine
Wie genau behebt man sowas denn?Temporary table size is already large - reduce result set size
Jetzt frag ich schon zum zweiten Mal:da es zu Datenbankfehlern in meiner vbulletin Installation kam.
Nach 6 Minuten liefert das Script noch keine brauchbaren statistischen Werte.Uptime = 0 days 0 hrs 6 min 21 sec
Dann muss ich wohl damit leben. In meinem vB und wBB schraube ich nichts drin rum.Um diese Meldung weg zu bekommen, müssen die SQL-Queries verbessert werden.
Falls man das nicht kann, muss man eben damit leben.
Ich hatte nach Fakten gefragt, nicht nach Erzählungen. Für Geschichten kann ich auch ein Buch lesen.Kam es in meiner vb Installation zu dauernden Datenbankfehler
Das Selbe auch hier. Wo im Plesk? Oder meinst Du eher phpMyAdmin? Meinst Du vielleicht den den php-mysql-Client?Pleskpanel auf Mysql-client 5.0 komme und Mysql-server-5.1 sich befindet
Dachte ich's mir doch, dass es so ist und die Meldung an den Queries liegt.
>> MySQLTuner 1.0.1 - Major Hayden <major@mhtx.net>
>> Bug reports, feature requests, and downloads at http://mysqltuner.com/
>> Run with '--help' for additional options and output filtering
-------- General Statistics --------------------------------------------------
[--] Skipped version check for MySQLTuner script
[!!] Your MySQL version 4.0.15 is EOL software! Upgrade soon!
[OK] Operating on 32-bit architecture with less than 2GB RAM
-------- Storage Engine Statistics -------------------------------------------
[--] Status: -Archive -BDB -Federated -InnoDB +ISAM -NDBCluster
[--] Data in HEAP tables: 252K (Tables: 3)
[--] Data in MyISAM tables: 490M (Tables: 554)
[!!] ISAM is enabled but isn't being used
[!!] Total fragmented tables: 5
-------- Performance Metrics -------------------------------------------------
[--] Up for: 11h 24m 28s (553K q [13.473 qps], 22K conn, TX: 869M, RX: 77M)
[--] Reads / Writes: 66% / 34%
[--] Total buffers: 48.0M global + 1.7M per thread (60 max threads)
[OK] Maximum possible memory usage: 149.2M (14% of installed RAM)
[OK] Slow queries: 0% (25/553K)
[OK] Highest usage of available connections: 16% (10/60)
[OK] Key buffer size / total MyISAM indexes: 16.0M/67.1M
[OK] Key buffer hit rate: 98.1% (30M cached / 576K reads)
[OK] Query cache efficiency: 61.2% (261K cached / 428K selects)
[!!] Query cache prunes per day: 29720
[OK] Sorts requiring temporary tables: 0% (128 temp sorts / 34K sorts)
[!!] Joins performed without indexes: 216
[!!] Temporary tables created on disk: 36% (8K on disk / 22K total)
[!!] Thread cache is disabled
[!!] Table cache hit rate: 14% (101 open / 697 opened)
[OK] Open file limit used: 0% (198/32K)
[OK] Table locks acquired immediately: 99% (310K immediate / 310K locks)
[!!] Connections aborted: 38%
-------- Recommendations -----------------------------------------------------
General recommendations:
Add skip-isam to MySQL configuration to disable ISAM (MySQL > 4.1.0)
Run OPTIMIZE TABLE to defragment tables for better performance
MySQL started within last 24 hours - recommendations may be inaccurate
Enable the slow query log to troubleshoot bad queries
Adjust your join queries to always utilize indexes
When making adjustments, make tmp_table_size/max_heap_table_size equal
Reduce your SELECT DISTINCT queries without LIMIT clauses
Set thread_cache_size to 4 as a starting value
Increase table_cache gradually to avoid file descriptor limits
Upgrade to MySQL 4.1+ to use concurrent MyISAM inserts
Your applications are not closing MySQL connections properly
Variables to adjust:
query_cache_size (> 16M)
join_buffer_size (> 128.0K, or always use indexes with joins)
tmp_table_size (> 32M)
max_heap_table_size (> 16M)
thread_cache_size (start at 4)
table_cache (> 16384)
MySQL Version 4.0.15 is EOL please upgrade to MySQL 4.1 or later
Uptime = 0 days 11 hrs 22 min 51 sec
Avg. qps = 13
Total Questions = 551737
Threads Connected = 1
http://dev.mysql.com/doc/refman/4.1/en/server-system-variables.html
SLOW QUERIES
Current long_query_time = 10 sec.
You have 25 out of 551756 that take longer than 10 sec. to complete
BINARY UPDATE LOG
See http://dev.mysql.com/doc/refman/4.0/en/point-in-time-recovery.html
WORKER THREADS
Current thread_cache_size = 0
Current threads_per_sec = 2
Threads created per/sec are overrunning threads cached
You should raise thread_cache_size
MAX CONNECTIONS
Current max_connections = 60
Current threads_connected = 1
Historic max_used_connections = 10
The number of used connections is 16% of the configured maximum.
No InnoDB Support Enabled!
MEMORY USAGE
Max Memory Ever Allocated : 48 M
Configured Max Per-thread Buffers : 101 M
Configured Max Global Buffers : 32 M
Configured Max Memory Limit : 133 M
Physical Memory : 1000 M
KEY BUFFER
Current MyISAM index space = 67 M
Key cache miss rate is 1 : 53
Key buffer free ratio = 75 %
QUERY CACHE
Current query_cache_used = 6 M
Current Query cache Memory fill ratio = 43.32 %
No query_cache_min_res_unit is defined. Using MySQL < 4.1 cache fragmentation can be inpredictable
Query Cache is 21 % fragmented
Run "FLUSH QUERY CACHE" periodically to defragment the query cache memory
If you have many small queries lower 'query_cache_min_res_unit' to reduce fragmentation.
SORT OPERATIONS
Current sort_buffer_size = 1 M
JOINS
You have had 216 queries where a join could not use an index properly
You should enable "log-long-format"
OPEN FILES LIMIT
Current open_files_limit = 32838 files
TABLE CACHE
Current table_cache value = 16384 tables
You have a total of 557 tables
You have 97 open tables.
TEMP TABLES
Current tmp_table_size = 32 M
Of 14543 temp tables, 36% were created on disk
TABLE SCANS
Current table scan ratio = 1212 : 1
TABLE LOCKING
Current Lock Wait ratio = 1 : 2643
# the MPM (multiprocessing module) is not a dynamically loadable module in the
# sense of other modules. It is a compile time decision which one is used. We
# provide different apache2 MPM packages, containing different httpd2 binaries
# compiled with the available MPMs. See APACHE_MPM in /etc/sysconfig/apache2.
# prefork MPM
<IfModule prefork.c>
# number of server processes to start
StartServers 2
# minimum number of server processes which are kept spare
MinSpareServers 3
# maximum number of server processes which are kept spare
MaxSpareServers 15
# highest possible MaxClients setting for the lifetime of the Apache process.
ServerLimit 150
# maximum number of server processes allowed to start
MaxClients 150
# maximum number of requests a server process serves
</IfModule>
# worker MPM
<IfModule worker.c>
# initial number of server processes to start
StartServers 2
# minimum number of worker threads which are kept spare
MinSpareThreads 25
# maximum number of worker threads which are kept spare
MaxSpareThreads 75
# maximum number of simultaneous client connections
MaxClients 150
# constant number of worker threads in each server process
ThreadsPerChild 25
</IfModule>
# leader MPM
<IfModule leader.c>
StartServers 2
MinSpareThreads 25
MaxSpareThreads 75
MaxClients 150
ThreadsPerChild 25
</IfModule>
# perchild MPM
<IfModule perchild.c>
# constant number of server processes
NumServers 5
# initial number of worker threads in each server process
StartThreads 5
MinSpareThreads 5
MaxSpareThreads 10
# maximum number of worker threads in each server process
MaxThreadsPerChild 20
# maximum number of connections per server process
AcceptMutex fcntl
</IfModule>
# metux MPM
<IfModule metuxmpm.c>
StartThreads 5
MinSpareThreads 5
MaxSpareThreads 10
Multiplexer "wwwrun" "www"
</IfModule>
KeepAlive On
MaxKeepAliveRequests 100
KeepAliveTimeout 2
# EnableMMAP: Control whether memory-mapping is used to deliver
# files (assuming that the underlying OS supports it).
# The default is on; turn this off if you serve from NFS-mounted
# filesystems. On some systems, turning it off (regardless of
# filesystem) can improve performance; for details, please see
# http://httpd.apache.org/docs-2.0/mod/core.html#enablemmap
#EnableMMAP off
# EnableSendfile: Control whether the sendfile kernel support is
# used to deliver files (assuming that the OS supports it).
# filesystems. Please see
# http://httpd.apache.org/docs-2.0/mod/core.html#enablesendfile
#EnableSendfile off
# The following directives modify normal HTTP response behavior to
# handle known problems with browser implementations.
BrowserMatch "Mozilla/2" nokeepalive
BrowserMatch "MSIE 4\.0b2;" nokeepalive downgrade-1.0 force-response-1.0
BrowserMatch "RealPlayer 4\.0" force-response-1.0
BrowserMatch "Java/1\.0" force-response-1.0
BrowserMatch "JDK/1\.0" force-response-1.0
# The following directive disables redirects on non-GET requests for
# a directory that does not include the trailing slash. This fixes a
# problem with Microsoft WebFolders which does not appropriately handle
# redirects for folders with DAV methods.
# Same deal with Apple's DAV filesystem and Gnome VFS support for DAV.
BrowserMatch "Microsoft Data Access Internet Publishing Provider" redirect-carefully
BrowserMatch "^WebDrive" redirect-carefully
BrowserMatch "^WebDAVFS/1.[012]" redirect-carefully
BrowserMatch "^gnome-vfs" redirect-carefully
[client]
#password = your_password
port = 3306
socket = /var/lib/mysql/mysql.sock
# Here follows entries for some specific programs
# The MySQL server
[mysqld]
port = 3306
skip-locking
key_buffer = 16M
max_allowed_packet = 1M
table_cache = 64K
sort_buffer_size = 1M
net_buffer_length = 8K
myisam_sort_buffer_size = 8M
set-variable = max_connections=60
# Maximale Groesse eines Abfrage Ergebnisses, damit es gecached wird
# Gesamtgroesse des Cache
# Don't listen on a TCP/IP port at all. This can be a security enhancement,
# if all processes that need to connect to mysqld run on the same host.
# All interaction with mysqld must be made via Unix sockets or named pipes.
# Note that using this option without enabling named pipes on Windows
# (via the "enable-named-pipe" option) will render mysqld useless!
#skip-networking
# Replication Master Server (default)
# binary logging is required for replication
# log-bin
# required unique id between 1 and 2^32 - 1
# defaults to 1 if master-host is not set
# but will not function as a master if omitted
server-id = 1
# Replication Slave (comment out master section to use this)
# To configure this host as a replication slave, you can choose between
# two methods :
# 1) Use the CHANGE MASTER TO command (fully described in our manual) -
# the syntax is:
# CHANGE MASTER TO MASTER_HOST=<host>, MASTER_PORT=<port>,
# MASTER_USER=<user>, MASTER_PASSWORD=<password> ;
# where you replace <host>, <user>, <password> by quoted strings and
# <port> by the master's port number (3306 by default).
# Example:
# CHANGE MASTER TO MASTER_HOST='125.564.12.1', MASTER_PORT=3306,
# MASTER_USER='joe', MASTER_PASSWORD='secret';
# OR
# 2) Set the variables below. However, in case you choose this method, then
# start replication for the first time (even unsuccessfully, for example
# if you mistyped the password in master-password and the slave fails to
# connect), the slave will create a master.info file, and any later
# change in this file to the variables' values below will be ignored and
# overridden by the content of the master.info file, unless you shutdown
# the slave server, delete master.info and restart the slaver server.
# For that reason, you may want to leave the lines below untouched
# (commented) and instead use CHANGE MASTER TO (see above)
# required unique id between 2 and 2^32 - 1
# (and different from the master)
# defaults to 2 if master-host is set
# but will not function as a slave if omitted
#server-id = 2
# The replication master for this slave - required
#master-host = <hostname>
# The username the slave will use for authentication when connecting
# to the master - required
#master-user = <username>
# The password the slave will authenticate with when connecting to
# the master - required
#master-password = <password>
# The port the master is listening on.
# optional - defaults to 3306
#master-port = <port>
# binary logging - not required for slaves, but recommended
#log-bin
# Point the following paths to different dedicated disks
#tmpdir = /tmp/
#log-update = /path-to-dedicated-directory/hostname
# Uncomment the following if you are using BDB tables
#bdb_cache_size = 4M
#bdb_max_lock = 10000
# Uncomment the following if you are using InnoDB tables
#innodb_data_home_dir = /var/lib/mysql/
#innodb_data_file_path = ibdata1:10M:autoextend
#innodb_log_group_home_dir = /var/lib/mysql/
#innodb_log_arch_dir = /var/lib/mysql/
# You can set .._buffer_pool_size up to 50 - 80 %
# of RAM but beware of setting memory usage too high
#innodb_buffer_pool_size = 16M
#innodb_additional_mem_pool_size = 2M
# Set .._log_file_size to 25 % of buffer pool size
#innodb_log_file_size = 5M
#innodb_log_buffer_size = 8M
#innodb_flush_log_at_trx_commit = 1
#innodb_lock_wait_timeout = 50
# The safe_mysqld script
[safe_mysqld]
err-log=/var/lib/mysql/mysqld.log
[mysqldump]
quick
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[isamchk]
key_buffer = 16M
sort_buffer_size = 16M
read_buffer = 2M
write_buffer = 2M
[myisamchk]
key_buffer = 16M
read_buffer = 2M
write_buffer = 2M
[mysqlhotcopy]
interactive-timeout
Geben die Dienste auf? Funktioniert nichts mehr am Server? Musst/Tust Du rebooten? Stehen Kernel-Meldungen in den Logfiles?weil zur zeit mein mysql und dann auch der apache bei last abschmiert.
MySQL Version 5.0.77 x86_64
Uptime = 0 days 12 hrs 12 min 26 sec
Avg. qps = 146
Total Questions = 6422276
Threads Connected = 8
http://dev.mysql.com/doc/refman/5.0/en/server-system-variables.html
SLOW QUERIES
You have 0 out of 6422340 that take longer than 10 sec. to complete
BINARY UPDATE LOG
See http://dev.mysql.com/doc/refman/5.0/en/point-in-time-recovery.html
WORKER THREADS
Current threads_per_sec = 39
Historic threads_per_sec = 10
MAX CONNECTIONS
Current threads_connected = 9
Historic max_used_connections = 34
The number of used connections is 34% of the configured maximum.
INNODB STATUS
Current InnoDB index space = 2 M
Current InnoDB data space = 2 M
Current InnoDB buffer pool free = 35 %
MEMORY USAGE
Max Memory Ever Allocated : 111 M
Configured Max Per-thread Buffers : 274 M
Configured Max Global Buffers : 17 M
Configured Max Memory Limit : 292 M
Physical Memory : 7.80 G
KEY BUFFER
Current MyISAM index space = 341 M
Current key_buffer_size = 7 M
Key cache miss rate is 1 : 201
Key buffer free ratio = 76 %
QUERY CACHE
Query cache is supported but not enabled
Perhaps you should set the query_cache_size
SORT OPERATIONS
JOINS
You have had 7546 queries where a join could not use an index properly
OPEN FILES LIMIT
TABLE CACHE
Current table_cache value = 64 tables
You have a total of 1522 tables
TEMP TABLES
Of 50362 temp tables, 1% were created on disk
TABLE SCANS
Current table scan ratio = 1074 : 1
TABLE LOCKING
Current Lock Wait ratio = 1 : 55
