root@Testhotel123:~# sudo apt-get install mysql-server
Reading package lists... Done
Building dependency tree
Reading state information... Done
The following extra packages will be installed:
libaio1 libdbd-mysql-perl libdbi-perl libhtml-template-perl libmysqlclient18
libnet-daemon-perl libplrpc-perl libterm-readkey-perl mysql-client-5.5
mysql-client-core-5.5 mysql-common mysql-server-5.5 mysql-server-core-5.5
Suggested packages:
libipc-sharedcache-perl tinyca
The following NEW packages will be installed:
mysql-client-core-5.5 mysql-common mysql-server mysql-server-5.5
0 upgraded, 14 newly installed, 0 to remove and 0 not upgraded.
Need to get 27.3 MB of archives.
After this operation, 97.2 MB of additional disk space will be used.
Do you want to continue [Y/n]? y
Get:1 http://archive.ubuntu.com/ubuntu/ quantal/main libaio1 amd64 0.3.109-2ubuntu1 [6396 B]
Get:2 http://archive.ubuntu.com/ubuntu/ quantal-updates/main mysql-common all 5.5.34-0ubuntu0.12.10.1 [13.5 kB]
Get:3 http://archive.ubuntu.com/ubuntu/ quantal-updates/main libmysqlclient18 amd64 5.5.34-0ubuntu0.12.10.1 [950 kB]
Get:4 http://archive.ubuntu.com/ubuntu/ quantal/main libnet-daemon-perl all 0.48-1 [43.1 kB]
Get:5 http://archive.ubuntu.com/ubuntu/ quantal/main libplrpc-perl all 0.2020-2 [36.0 kB]
Get:6 http://archive.ubuntu.com/ubuntu/ quantal/main libdbi-perl amd64 1.622-1 [852 kB]
Get:7 http://archive.ubuntu.com/ubuntu/ quantal/main libdbd-mysql-perl amd64 4.021-1 [97.7 kB]
Get:8 http://archive.ubuntu.com/ubuntu/ quantal-updates/main mysql-client-core-5.5 amd64 5.5.34-0ubuntu0.12.10.1 [1943 kB]
Get:9 http://archive.ubuntu.com/ubuntu/ quantal/main libterm-readkey-perl amd64 2.30-4build4 [28.4 kB]
Get:10 http://archive.ubuntu.com/ubuntu/ quantal-updates/main mysql-client-5.5 amd64 5.5.34-0ubuntu0.12.10.1 [8336 kB]
Get:11 http://archive.ubuntu.com/ubuntu/ quantal-updates/main mysql-server-core-5.5 amd64 5.5.34-0ubuntu0.12.10.1 [6015 kB]
Get:12 http://archive.ubuntu.com/ubuntu/ quantal-updates/main mysql-server-5.5 amd64 5.5.34-0ubuntu0.12.10.1 [8857 kB]
Get:13 http://archive.ubuntu.com/ubuntu/ quantal/main libhtml-template-perl all 2.91-1 [65.1 kB]
Get:14 http://archive.ubuntu.com/ubuntu/ quantal-updates/main mysql-server all 5.5.34-0ubuntu0.12.10.1 [11.6 kB]
Fetched 27.3 MB in 8s (3297 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libaio1:amd64.
(Reading database ... 27604 files and directories currently installed.)
Unpacking libaio1:amd64 (from .../libaio1_0.3.109-2ubuntu1_amd64.deb) ...
Selecting previously unselected package mysql-common.
Unpacking mysql-common (from .../mysql-common_5.5.34-0ubuntu0.12.10.1_all.deb) ...
Selecting previously unselected package libmysqlclient18:amd64.
Unpacking libmysqlclient18:amd64 (from .../libmysqlclient18_5.5.34-0ubuntu0.12.10.1_amd64.deb) ...
Selecting previously unselected package libnet-daemon-perl.
Unpacking libnet-daemon-perl (from .../libnet-daemon-perl_0.48-1_all.deb) ...
Selecting previously unselected package libplrpc-perl.
Unpacking libplrpc-perl (from .../libplrpc-perl_0.2020-2_all.deb) ...
Selecting previously unselected package libdbi-perl.
Unpacking libdbi-perl (from .../libdbi-perl_1.622-1_amd64.deb) ...
Selecting previously unselected package libdbd-mysql-perl.
Unpacking libdbd-mysql-perl (from .../libdbd-mysql-perl_4.021-1_amd64.deb) ...
Selecting previously unselected package mysql-client-core-5.5.
Unpacking mysql-client-core-5.5 (from .../mysql-client-core-5.5_5.5.34-0ubuntu0.12.10.1_amd64.deb) ...
Selecting previously unselected package libterm-readkey-perl.
Unpacking libterm-readkey-perl (from .../libterm-readkey-perl_2.30-4build4_amd64.deb) ...
Selecting previously unselected package mysql-client-5.5.
Unpacking mysql-client-5.5 (from .../mysql-client-5.5_5.5.34-0ubuntu0.12.10.1_amd64.deb) ...
Selecting previously unselected package mysql-server-core-5.5.
Unpacking mysql-server-core-5.5 (from .../mysql-server-core-5.5_5.5.34-0ubuntu0.12.10.1_amd64.deb) ...
Processing triggers for man-db ...
Setting up mysql-common (5.5.34-0ubuntu0.12.10.1) ...
Selecting previously unselected package mysql-server-5.5.
(Reading database ... 27984 files and directories currently installed.)
Unpacking mysql-server-5.5 (from .../mysql-server-5.5_5.5.34-0ubuntu0.12.10.1_amd64.deb) ...
Selecting previously unselected package libhtml-template-perl.
Unpacking libhtml-template-perl (from .../libhtml-template-perl_2.91-1_all.deb) ...
Selecting previously unselected package mysql-server.
Unpacking mysql-server (from .../mysql-server_5.5.34-0ubuntu0.12.10.1_all.deb) ...
Setting up libaio1:amd64 (0.3.109-2ubuntu1) ...
Setting up libmysqlclient18:amd64 (5.5.34-0ubuntu0.12.10.1) ...
Setting up libnet-daemon-perl (0.48-1) ...
Setting up libplrpc-perl (0.2020-2) ...
Setting up libdbi-perl (1.622-1) ...
Setting up libdbd-mysql-perl (4.021-1) ...
Setting up mysql-client-core-5.5 (5.5.34-0ubuntu0.12.10.1) ...
Setting up libterm-readkey-perl (2.30-4build4) ...
Setting up mysql-client-5.5 (5.5.34-0ubuntu0.12.10.1) ...
Setting up mysql-server-core-5.5 (5.5.34-0ubuntu0.12.10.1) ...
Setting up mysql-server-5.5 (5.5.34-0ubuntu0.12.10.1) ...
131108 9:05:59 [Warning] Using unique option prefix key_buffer instead of key_buffer_size is deprecated and will be removed in a future release. Please use the full name instead.
