Confixx E-Mail-Problem
Sep  9 14:36:01 t416 postfix/smtpd[791]: connect from p549D6489.dip.t-dialin.net[84.157.100.137]
Sep  9 14:36:01 t416 postfix/smtpd[791]: warning: SASL authentication problem: unable to open Berkeley db /etc/sasldb2: No such file or directory
Sep  9 14:36:01 t416 postfix/smtpd[791]: warning: SASL authentication failure: no secret in database
Sep  9 14:36:01 t416 postfix/smtpd[791]: warning: p549D6489.dip.t-dialin.net[84.157.100.137]: SASL NTLM authentication failed
Sep  9 14:36:02 t416 postfix/smtpd[791]: warning: SASL authentication problem: unable to open Berkeley db /etc/sasldb2: No such file or directory
Sep  9 14:36:02 t416 postfix/smtpd[791]: warning: SASL authentication failure: no secret in database
Sep  9 14:36:02 t416 postfix/smtpd[791]: warning: p549D6489.dip.t-dialin.net[84.157.100.137]: SASL NTLM authentication failed
Sep  9 14:39:03 t416 in.qpopper[974]: (v4.0.5) POP login by user "web1p1" at (p549D6489.dip.t-dialin.net) 84.157.100.137 [pop_log.c:244]
Sep  9 14:39:17 t416 postfix/smtpd[977]: connect from p549D6489.dip.t-dialin.net[84.157.100.137]
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: SASL authentication problem: unable to open Berkeley db /etc/sasldb2: No such file or directory
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: SASL authentication failure: no secret in database
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: p549D6489.dip.t-dialin.net[84.157.100.137]: SASL CRAM-MD5 authentication failed
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: p549D6489.dip.t-dialin.net[84.157.100.137]: SASL NTLM authentication failed
Sep  9 14:39:21 t416 last message repeated 4 times
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: SASL authentication failure: Password verification failed
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: p549D6489.dip.t-dialin.net[84.157.100.137]: SASL PLAIN authentication failed
Sep  9 14:39:21 t416 last message repeated 5 times
Sep  9 14:39:21 t416 postfix/smtpd[977]: warning: p549D6489.dip.t-dialin.net[84.157.100.137]: SASL LOGIN authentication failed
Sep  9 14:39:24 t416 postfix/smtpd[977]: lost connection after AUTH from p549D6489.dip.t-dialin.net[84.157.100.137]
Sep  9 14:39:24 t416 postfix/smtpd[977]: disconnect from p549D6489.dip.t-dialin.net[84.157.100.137]
Sep  9 14:39:29 t416 postfix/smtp[956]: connect to inbound.borland.com[143.186.1.17]: Connection timed out (port 25)
Sep  9 14:39:29 t416 postfix/smtp[961]: connect to inbound.borland.com[143.186.1.15]: Connection timed out (port 25)
Sep  9 14:39:49 t416 in.qpopper[980]: (v4.0.5) POP login by user "web1p1" at (p549D6489.dip.t-dialin.net) 84.157.100.137 [pop_log.c:244]
Sep  9 14:39:59 t416 postfix/smtp[956]: connect to inbound.borland.com[143.186.1.15]: Connection timed out (port 25)
Sep  9 14:39:59 t416 postfix/smtp[961]: connect to inbound.borland.com[143.186.1.17]: Connection timed out (port 25)
web1p1 ist mein Postfach.
man saslpasswd2
Evtl. solltest Du vorher nachsehen, welche sasl2-Version Du installiert hast und ob die /etc/sasldb2 wirklich fehlt.
Es kommen bei der Boardsuche nur 3 Threads raus. Einer ist dieser und die andern Beiden sind nicht wirklich lang. Also ließ das kleine Bischen mal gründlich.
Also die sasldb2 ist definitv da. Ich habe nach den Rechten geschaut, wie es in den beiden Threads drinne steht. Aber es geht einfach ned.
Ich weiss noch immer ned was ein Dummy ist. Aber da ja die sasldb2 vorhanden ist muss ich ja nicht mit saslpasswd eine machen.
Ergo:
Die Threads haben mir nicht helfen können.
Er nimmt nach wie vor das Passwort nicht.
Rechte der sasldb2 sind nu 770
saslauthd 2.1.19
läuft Postfix im Chroot? Falls ja, ist die Datei auch im Chroot vorhanden?
/etc/postfix/master.cf öffnen und in die Spalte Chroot gucken.
Da gibbets keine Spalte mit Chroot
Hier der Inhalt der main.cf
#sasl#
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
myorigin = /etc/mailname
mydestination = t416.greatnet.de
mynetworks = 127.0.0.0/8
mailbox_size_limit = 0
recipient_delimiter = +
### CONFIXX POSTFIX ENTRY ###
Ahhh, sorry :D
Diese Tabelle?
#submission inet n      -       -       -       -       smtpd
#       -o smtpd_etrn_restrictions=reject
#628      inet  n       -       -       -       -       qmqpd
pickup    fifo  n       -       -       60      1       pickup
qmgr      fifo  n       -       -       300     1       qmgr
#qmgr     fifo  n       -       -       300     1       oqmgr
lmtp      unix  -       -       n       -       -       lmtp
anvil     unix  -       -       n       -       1       anvil
das ist die richtige.
Minuszeichen ist Defaultwert, und Defaultwert ist yes, also läuft Dein Postfix chrooted. Du kannst das nochmal nachprüfen, indem Du nach main.cf suchst, Du solltest die Datei zweimal finden, in /etc/postfix und vermutlich in /var/lib/postfix/etc/postfix/main.cf. Falls der Pfad anders ist bitte den korrekten mitteilen.
Vermißt wird nicht /etc/sasldb2 sondern /var/lib/postfix/etc/sasldb2, Postfix meint aber (durch das chroot) /var/lib/postfix/ sei das Hauptverzeichnis, und aus dieser Sicht meldet er /etc/sasldb2 fehlt.
Kopiere /etc/sasldb2 nach /var/lib/postfix/etc/sasldb2, restarte Postfix und probiere aus ob die Fehlermeldung weg ist.
Falls es hilft muß das Startscript angepaßt werden, für den Test reicht kopieren.
Also ich habe nu in "var/lib" keinen Postfix-Ordner gefunden.
Jetzt hab ich halt den Ordner "Postfix/etc" erstellt und die sasldb2 hineinkopiert.
Der Fehler kommt immer noch.
Muss denn Postfix im chroot laufen? Was hab ich davon?
Ich hab Postfix sonst nirgends wo gefunden.
Es ist im etc Ordner und da arbeitet auch Confixx mit, weil man im Postfix-Ordner Confixx-Dateien sieht.
Da hat sich ein kleiner Fehler eingeschlichen:
Das chroot-Verzeichnis lautet /var/spool/postfix/
Allerdings muß dort die sasldb2 i.d.R. nicht abgelegt werden, da ja nicht Postfix sondern saslauthd drauf zugreift. Und saslauthd läuft ausserhalb des chroot.
Mehr Sicherheit.
PS: Du hast immer noch nicht die sasl2-Version genannt. Bitte immer auf alle Fragen antworten und nicht alles einzeln aus der Nase ziehen lassen. So macht das niemanden Spaß.
Hab ich weiter oben genannt.
saslauthd 2.1.19
Das zeigt es zummindest, wenn ich "/usr/sbin/saslauthd -v"
Oder meinst du was anderes?
Mehr nicht?
Nicht zufällig
saslauthd 2.1.19
authentication mechanisms: sasldb getpwent kerberos4 kerberos5 pam rimap shadow ldap
Du hast also ein Cyrus-Sasl auf einem Debian Sarge.
(Ist zwar nur geraten aber zu 90% lieg ich damit richtig, oder?)
In dem Fall brauch ich folgende Files:
/etc/postfix/sasl/smtpd.conf
/etc/pam.d/smtp
/etc/default/saslauthd
Einfach per Cut&Paste hier rein. Sind ja nur jeweils ein paar Zeilen.
Grund: sasldb2 ist bei Cyrus die Default-Methode. D.h. es geht bereits vorher etwas schief. Sprich, die eigendliche Authentifizierungs-Methode funktioniert nicht.
Aso, ich dachte nur saslauthd 2.**** reicht.
Hat natürlich mehr gezeigt:
saslauthd 2.1.19
smtp.conf:
pwcheck_method: saslauthd
mech_list: PLAIN LOGIN
saslauthd_path: /var/run/saslauthd/mux
autotransition:true
smtp:
auth required /lib/security/pam_unix_auth.so
account required /lib/security/pam_unix_acct.so
password required /lib/security/pam_unix_passwd.so
session required /lib/security/pam_unix_session.so
saslauthd:
# This needs to be uncommented before saslauthd will be run automatically
 START=yes
# You must specify the authentication mechanisms you wish to use.
# This defaults to "pam" for PAM support, but may also include
# "shadow" or "sasldb", like this:
# MECHANISMS="pam shadow"
MECHANISMS="pam"
Probier mal folgende Einträge in der /etc/default/saslauthd:
START=yes
MECHANISMS="pam"
[COLOR="Red"]# For Postfix-Chroot:
PARAMS="-m /var/spool/postfix/var/run/saslauthd"
PIDFILE="/var/spool/postfix/var/run/saslauthd/saslauthd.pid"[/COLOR]
Danach "/etc/init.d/saslauthd restart" nicht vergessen.
Sorry, ein Postfix-Restart hätte es auch benötigt.
Ausserdem mußt Du /var/spool/postfix/var/run/saslauthd/ überprüfen, ob dort die Nutzerrechte korrekt gesetzt sind.
Also von "mux" sind sie auf 777
von "mux.accept" auf 600
von saslauth.pid auf 600
Sind die so ok oder muss ich was ändern?
