Die Einstellungen werden über die mySQL Konfigurationsdatei (my.cnf) geregelt. Nach einer Änderung den mySQL Server einmal durchstarten. Allerdings sollte der Server nach einer Änderungen erst mal 48 Stunden laufen, um aussagekräftige Werte zu erhalten.
genau dies habe ich getan. Nur scheint es nicht angenommen zu werden?
Hier mal meine my.cnf:
# The MySQL database server configuration file.
# You can copy this to one of:
# - "/etc/mysql/my.cnf" to set global options,
# - "/var/lib/mysql/my.cnf" to set server-specific options or
# - "~/.my.cnf" to set user-specific options.
# One can use all long options that the program supports.
# Run program with --help to get a list of available options and with
# --print-defaults to see which it would actually understand and use.
# For explanations see
# http://dev.mysql.com/doc/mysql/en/server-system-variables.html
# This will be passed to all mysql clients
# It has been reported that passwords should be enclosed with ticks/quotes
# escpecially if they contain "#" chars...
# Remember to edit /etc/mysql/debian.cnf when changing the socket location.
[client]
port = 3306
socket = /var/run/mysqld/mysqld.sock
# Here is entries for some specific programs
# The following values assume you have at least 32M ram
# This was formally known as [safe_mysqld]. Both versions are currently parsed.
[mysqld_safe]
nice = 0
skip-bdb
set-variable = innodb_buffer_pool_size=2M
set-variable = innodb_additional_mem_pool_size=500K
set-variable = innodb_log_buffer_size=500K
set-variable = innodb_thread_concurrency=2
[mysqld]
set-variable=local-infile=0
# * Basic Settings
user = mysql
pid-file = /var/run/mysqld/mysqld.pid
port = 3306
basedir = /usr
datadir = /var/lib/mysql
tmpdir = /tmp
language = /usr/share/mysql/english
skip-external-locking
# For compatibility to other Debian packages that still use
# libmysqlclient10 and libmysqlclient12.
old_passwords = 1
# Instead of skip-networking the default is now to listen only on
# localhost which is more compatible and is not less secure.
# bind-address = 127.0.0.1
# * Fine Tuning
key_buffer = 16M
max_allowed_packet = 16M
thread_stack = 128K
# * Query Cache Configuration
query_cache_limit = 1048576
query_cache_size = 16777216
query_cache_type = 1
# * Logging and Replication
# Both location gets rotated by the cronjob.
# Be aware that this log type is a performance killer.
#log = /var/log/mysql.log
#log = /var/log/mysql/mysql.log
# Error logging goes to syslog. This is a Debian improvement :)
# Here you can see queries with especially long duration
#log-slow-queries = /var/log/mysql/mysql-slow.log
# The following can be used as easy to replay backup logs or for replication.
#server-id = 1
log-bin = /var/log/mysql/mysql-bin.log
expire-logs-days = 20
max_binlog_size = 104857600
#binlog-do-db = include_database_name
#binlog-ignore-db = include_database_name
# * BerkeleyDB
# According to an MySQL employee the use of BerkeleyDB is now discouraged
# and support for it will probably cease in the next versions.
skip-bdb
# * InnoDB
# InnoDB is enabled by default with a 10MB datafile in /var/lib/mysql/.
# Read the manual for more InnoDB related options. There are many!
# * Security Features
# Read the manual, too, if you want chroot!
# chroot = /var/lib/mysql/
# If you want to enable SSL support (recommended) read the manual or my
# HOWTO in /usr/share/doc/mysql-server/SSL-MINI-HOWTO.txt.gz
# ssl-ca=/etc/mysql/cacert.pem
# ssl-cert=/etc/mysql/server-cert.pem
# ssl-key=/etc/mysql/server-key.pem
[mysqldump]
quick
quote-names
[mysql]
#no-auto-rehash # faster start of mysql but no tab completition
[isamchk]
key_buffer = 16M
# * NDB Cluster
# See /usr/share/doc/mysql-server-*/README.Debian for more information.
# The following configuration is read by the ndbd storage daemons,
# not from the ndb_mgmd management daemon.
# [MYSQL_CLUSTER]
# ndb-connectstring=127.0.0.1
# Slow Query Log - Enable Logging of Slow Queries
log-slow-queries = /var/log/mysql-slow-queries.log
