hre Nachricht hat einige oder alle Empfänger nicht erreicht.
Betreff: AW: Mailtest
Gesendet am: 19.08.2006 18:54
Folgende Empfänger konnten nicht erreicht werden:
'xxx@xxxx.com' am 19.08.2006 18:54
554 <xxx@xxxx.com>: Relay access denied
Aug 19 19:26:25 89-149-194-33 postfix/smtpd[2291]: warning: dict_nis_init: NIS domain name not set - NIS lookups disabled
Aug 19 19:26:26 89-149-194-33 postfix/smtpd[2291]: unable to get certificate from '/path/to/smtpd.pem'
Aug 19 19:26:26 89-149-194-33 postfix/smtpd[2291]: 2291:error:02001002:system library:fopen:No such file or directory:bss_file.c:278:fopen('/path/to/smtpd.pem','r'):
Aug 19 19:26:26 89-149-194-33 postfix/smtpd[2291]: 2291:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:280:
Aug 19 19:26:26 89-149-194-33 postfix/smtpd[2291]: 2291:error:140DC002:SSL routines:SSL_CTX_use_certificate_chain_file:system lib:ssl_rsa.c:760:
Aug 19 19:26:26 89-149-194-33 postfix/smtpd[2291]: TLS engine: cannot load RSA cert/key data
Aug 19 19:26:26 89-149-194-33 postfix/smtpd[2291]: connect from p54A17581.dip.t-dialin.net[84.161.117.129]
Aug 19 19:26:29 89-149-194-33 postfix/smtpd[2291]: NOQUEUE: reject: RCPT from p54A17581.dip.t-dialin.net[84.161.117.129]: 554 <ForrestFunk@t-online.de>: Relay access denied; from=<jan@janaran.selfip.com> to=<ForrestFunk@t-online.de> proto=ESMTP helo=<homeforrest>
Aug 19 19:26:32 89-149-194-33 postfix/smtpd[2291]: disconnect from p54A17581.dip.t-dialin.net[84.161.117.129]
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: warning: dict_nis_init: NIS domain name not set - NIS lookups disabled
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: unable to get certificate from '/path/to/smtpd.pem'
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: 2295:error:02001002:system library:fopen:No such file or directory:bss_file.c:278:fopen('/path/to/smtpd.pem','r'):
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: 2295:error:20074002:BIO routines:FILE_CTRL:system lib:bss_file.c:280:
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: 2295:error:140DC002:SSL routines:SSL_CTX_use_certificate_chain_file:system lib:ssl_rsa.c:760:
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: TLS engine: cannot load RSA cert/key data
Aug 19 19:28:20 89-149-194-33 postfix/smtpd[2295]: connect from p54A17581.dip.t-dialin.net[84.161.117.129]
Aug 19 19:28:23 89-149-194-33 postfix/smtpd[2295]: AD9FD1016D: client=p54A17581.dip.t-dialin.net[84.161.117.129]
alias_maps = hash:/etc/aliases, nis:mail.aliases
NOQUEUE: reject: RCPT from p54A17581.dip.t-dialin.net[xx.xx.xxx.xxx]: 554 <xxxxxx@t-online.de>: Relay access denied; from=<xxx@xxxxxx.selfip.com> to=<xxxxxx@t-online.de> proto=ESMTP helo=<homeforrest>
Lösche alles ab und inklusive dem Komma in der main.cf.alias_maps = hash:/etc/aliases, nis:mail.aliases
Weil Du DynDNS nutzt und das mögen viele große MTA's überhaupt nicht.Woher kommt diese Ablehnung vom gegnerischen Server???
Dann erstell eben den entsprechenden Eintrag.also in der main.cf ist keine Textzeile die mit alias_maps: beginnt...
Es geht nicht um Deine Domain sondern um den Reverse-Lookup Deiner IP.Dieser dürfte doch dann nicht geblockt werden von T-online oder???
Das klang aber bisher nicht so.ähm das ist doch schon ein realer Rootserver....
smtp_use_tls = no
smtp_tls_note_starttls_offer = yes
smtpd_use_tls = no
smtpd_tls_key_file = /etc/postfix/smtpd.pem
smtpd_tls_cert_file = /etc/postfix/smtpd.pem
smtpd_tls_CAFile = /etc/postfix/smtpd.pem
smtpd_tls_loglevel = 0
smtpd_tls_received_header = no
smtpd_tls_session_cache_timeout = 3600s
tls_random_source = dev:/dev/urandom
Unter Debian liegen die Certs auch unter /etc/postfix/ssl/smtpd.pem.weil ich sonnst fehlermeldungen bekomme, dass in den pfaden diese Datei "smtpd.pem" nicht ist... und das ist sie auch nicht....
