# Global configuration that will be applicable for all virtual hosts, unless
# deleted here, or overriden elswhere.
DocumentRoot "/srv/www/web1/html"
# Configure the DocumentRoot
<Directory "/srv/www/web1/html">
# Possible values for the Options directive are "None", "All",
# or any combination of:
# Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
# Note that "MultiViews" must be named *explicitly* --- "Options All"
# doesn't give it to you.
# The Options directive is both complicated and important. Please see
# http://httpd.apache.org/docs-2.0/mod/core.html#options
# for more information.
Options None
# AllowOverride controls what directives may be placed in .htaccess files.
# It can be "All", "None", or any combination of the keywords:
# Options FileInfo AuthConfig Limit
AllowOverride None
# Controls who can get stuff from this server.
Order allow,deny
Allow from all
</Directory>
# Aliases: aliases can be added as needed (with no limit). The format is
# Alias fakename realname
# Note that if you include a trailing / on fakename then the server will
# require it to be present in the URL. So "/icons" isn't aliased in this
# example, only "/icons/". If the fakename is slash-terminated, then the
# realname must also be slash terminated, and if the fakename omits the
# trailing slash, the realname must also omit it.
# We include the /icons/ alias for FancyIndexed directory listings. If you
# do not use FancyIndexing, you may comment this out.
Alias /icons/ "/usr/share/apache2/icons/"
<Directory "/usr/share/apache2/icons">
Options Indexes MultiViews
AllowOverride None
Order allow,deny
Allow from all
</Directory>
# ScriptAlias: This controls which directories contain server scripts.
# ScriptAliases are essentially the same as Aliases, except that
# documents in the realname directory are treated as applications and
# run by the server when requested rather than as documents sent to the client.
# The same rules about trailing "/" apply to ScriptAlias directives as to
# Alias.
ScriptAlias /cgi-bin/ "/srv/www/cgi-bin/"
# "/srv/www/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/srv/www/cgi-bin">
AllowOverride None
Options +ExecCGI -Includes
Order allow,deny
Allow from all
</Directory>
# UserDir: The name of the directory that is appended onto a user's home
# directory if a ~user request is received.
# To disable it, simply remove userdir from the list of modules in APACHE_MODULES
# in /etc/sysconfig/apache2.
<IfModule mod_userdir.c>
# Note that the name of the user directory ("public_html") cannot simply be
# changed here, since it is a compile time setting. The apache package
# would have to be rebuilt. You could work around by deleting
# /usr/sbin/suexec, but then all scripts from the directories would be
# executed with the UID of the webserver.
UserDir public_html
# The actual configuration of the directory is in
# /etc/apache2/mod_userdir.conf.
Include /etc/apache2/mod_userdir.conf
# You can, however, change the ~ if you find it awkward, by mapping e.g.
# http://www.example.com/users/karl-heinz/ --> /home/karl-heinz/public_html/
#AliasMatch ^/users/([a-zA-Z0-9-_.]*)/?(.*) /home/$1/public_html/$2
</IfModule>
# Include all *.conf files from /etc/apache2/conf.d/.
# This is mostly meant as a place for other RPM packages to drop in their
# configuration snippet.
# You can comment this out here if you want those bits include only in a
# certain virtual host, but not here.
Include /etc/apache2/conf.d/*.conf
# The manual... if it is installed ('?' means it won't complain)
Include /etc/apache2/conf.d/apache2-manual?conf
