Sep 30 00:54:33 h1120016 xinetd[5681]: xinetd Version 2.3.13 started with libwrap loadavg options compiled in.
Sep 30 00:54:33 h1120016 xinetd[5681]: Started working: 4 available services
Sep 30 00:54:34 h1120016 kernel: klogd 1.4.1, log source = /proc/kmsg started.
Sep 30 00:54:34 h1120016 kernel: Capability LSM initialized
Sep 30 00:54:34 h1120016 kernel: Disabled Privacy Extensions on device c038e740(lo)
Sep 30 00:54:34 h1120016 kernel: tg3.c:v3.23 (February 15, 2005)
Sep 30 00:54:34 h1120016 kernel: ACPI: PCI interrupt 0000:02:03.0[A] -> GSI 24 (level, low) -> IRQ 177
Sep 30 00:54:34 h1120016 kernel: eth0: Tigon3 [partno(BCM95704A6) rev 2100 PHY(5704)] (PCI:66MHz:64-bit) 10/100/1000BaseT Ethernet 00:30:48:59:54:56
Sep 30 00:54:34 h1120016 kernel: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] Split[0] WireSpeed[1] TSOcap[0]
Sep 30 00:54:34 h1120016 kernel: ACPI: PCI interrupt 0000:02:03.1[b] -> GSI 25 (level, low) -> IRQ 185
Sep 30 00:54:34 h1120016 kernel: eth1: Tigon3 [partno(BCM95704A6) rev 2100 PHY(5704)] (PCI:66MHz:64-bit) 10/100/1000BaseT Ethernet 00:30:48:59:54:57
Sep 30 00:54:34 h1120016 kernel: eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] Split[0] WireSpeed[1] TSOcap[1]
Sep 30 00:54:34 h1120016 kernel: NET: Registered protocol family 17
Sep 30 00:54:34 h1120016 kernel: tg3: eth0: Link is up at 100 Mbps, full duplex.
Sep 30 00:54:34 h1120016 kernel: tg3: eth0: Flow control is off for TX and off for RX.
Sep 30 00:54:34 h1120016 kernel: ACPI: Power Button (FF) [PWRF]
Sep 30 00:54:34 h1120016 kernel: ACPI: Sleep Button (FF) [SLPF]
Sep 30 00:54:34 h1120016 kernel: eth0: no IPv6 routers present
Sep 30 00:54:34 h1120016 authdaemond.plain: authdaemon: modules="authcustom authcram authuserdb authvchkpw authshadow authpwd", daemons=5
Sep 30 00:54:35 h1120016 ntpdate[5820]: step time server 81.169.163.105 offset -0.083695 sec
Sep 30 00:54:35 h1120016 ntpd[5835]: ntpd 4.2.0a@1.1190-r Sat Mar 19 19:20:10 UTC 2005 (1)
Sep 30 00:54:35 h1120016 ntpd[5835]: precision = 3.000 usec
Sep 30 00:54:35 h1120016 ntpd[5835]: Listening on interface wildcard, 0.0.0.0#123
Sep 30 00:54:35 h1120016 ntpd[5835]: Listening on interface wildcard, ::#123
Sep 30 00:54:35 h1120016 ntpd[5835]: Listening on interface lo, 127.0.0.1#123
Sep 30 00:54:35 h1120016 ntpd[5835]: Listening on interface eth0, 85.214.77.20#123
Sep 30 00:54:35 h1120016 ntpd[5835]: kernel time sync status 0040
Sep 30 00:54:35 h1120016 ntpd[5835]: frequency initialized 51.536 PPM from /var/lib/ntp/drift/ntp.drift
Sep 30 00:54:36 h1120016 /usr/sbin/cron[5876]: (CRON) STARTUP (V5.0)
Sep 30 00:57:01 h1120016 /usr/sbin/cron[17910]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 00:59:10 h1120016 sshd[24914]: Accepted keyboard-interactive/pam for root from ::ffff:212.56.244.85 port 4909 ssh2
Sep 30 00:59:11 h1120016 sshd[24914]: subsystem request for sftp
Sep 30 01:00:01 h1120016 /usr/sbin/cron[25161]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:00:01 h1120016 /usr/sbin/cron[25163]: (root) CMD (root test -x /usr/lib/cron/run-crons && /usr/lib/cron/run-crons >/dev/null 2>&1)
Sep 30 01:03:01 h1120016 /usr/sbin/cron[25881]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:06:01 h1120016 /usr/sbin/cron[26698]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:09:01 h1120016 /usr/sbin/cron[27540]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:12:01 h1120016 /usr/sbin/cron[28418]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:15:01 h1120016 /usr/sbin/cron[29242]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:15:01 h1120016 /usr/sbin/cron[29244]: (root) CMD (root test -x /usr/lib/cron/run-crons && /usr/lib/cron/run-crons >/dev/null 2>&1)
Sep 30 01:18:01 h1120016 /usr/sbin/cron[30181]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:21:01 h1120016 /usr/sbin/cron[30946]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:27:16 h1120016 syslog-ng[5392]: syslog-ng version 1.6.5 starting
Sep 30 01:27:18 h1120016 named[5542]: starting BIND 9.3.1 -t /var/lib/named -u named
Sep 30 01:27:18 h1120016 named[5542]: found 1 CPU, using 1 worker thread
Sep 30 01:27:18 h1120016 named[5542]: loading configuration from '/etc/named.conf'
Sep 30 01:27:18 h1120016 named[5542]: listening on IPv6 interfaces, port 53
Sep 30 01:27:18 h1120016 named[5542]: listening on IPv4 interface lo, 127.0.0.1#53
Sep 30 01:27:18 h1120016 named[5542]: listening on IPv4 interface eth0, 85.214.77.20#53
Sep 30 01:27:18 h1120016 named[5542]: command channel listening on 127.0.0.1#953
Sep 30 01:27:18 h1120016 named[5542]: command channel listening on ::1#953
Sep 30 01:27:18 h1120016 named[5542]: zone 0.0.127.in-addr.arpa/IN: loaded serial 42
Sep 30 01:27:18 h1120016 named[5542]: zone ads-distributor.com/IN: loaded serial 2007051300
Sep 30 01:27:18 h1120016 named[5542]: zone easydistributor.com/IN: loaded serial 2007051300
Sep 30 01:27:18 h1120016 named[5542]: zone multi-anzeiger.com/IN: loaded serial 2006113000
Sep 30 01:27:18 h1120016 named[5542]: zone multi-indicator.com/IN: loaded serial 2007051300
Sep 30 01:27:18 h1120016 named[5542]: zone simply-distributor.com/IN: loaded serial 2007051300
Sep 30 01:27:18 h1120016 named[5542]: zone az-server.de/IN: loaded serial 2006120600
Sep 30 01:27:18 h1120016 named[5542]: zone bannerpartner.de/IN: loaded serial 2006120600
Sep 30 01:27:18 h1120016 named[5542]: zone berla-bauelemente.de/IN: loaded serial 2006121900
Sep 30 01:27:18 h1120016 named[5542]: zone csubmit.de/IN: loaded serial 2006121800
Sep 30 01:27:18 h1120016 named[5542]: zone mailpunkte.de/IN: loaded serial 2006120600
Sep 30 01:27:18 h1120016 named[5542]: zone myjobfinder.de/IN: loaded serial 2007070700
Sep 30 01:27:18 h1120016 named[5542]: zone pep-is.de/IN: loaded serial 2007040400
Sep 30 01:27:18 h1120016 named[5542]: zone spiderline.de/IN: loaded serial 2007031300
Sep 30 01:27:18 h1120016 named[5542]: zone superpaidmail.de/IN: loaded serial 2006120600
Sep 30 01:27:19 h1120016 named[5542]: zone localhost/IN: loaded serial 42
Sep 30 01:27:19 h1120016 named[5542]: zone classifieds4all.net/IN: loaded serial 2007051300
Sep 30 01:27:19 h1120016 named[5542]: zone supertausch.net/IN: loaded serial 2007051600
Sep 30 01:27:19 h1120016 named[5542]: zone multi-anzeiger.org/IN: loaded serial 2006113000
Sep 30 01:27:19 h1120016 named[5542]: running
Sep 30 01:27:19 h1120016 named[5542]: zone bannerpartner.de/IN: sending notifies (serial 2006120600)
Sep 30 01:27:19 h1120016 named[5542]: zone mailpunkte.de/IN: sending notifies (serial 2006120600)
Sep 30 01:27:19 h1120016 named[5542]: zone pep-is.de/IN: sending notifies (serial 2007040400)
Sep 30 01:27:19 h1120016 named[5542]: zone spiderline.de/IN: sending notifies (serial 2007031300)
Sep 30 01:27:19 h1120016 named[5542]: zone multi-indicator.com/IN: sending notifies (serial 2007051300)
Sep 30 01:27:19 h1120016 named[5542]: zone multi-anzeiger.com/IN: sending notifies (serial 2006113000)
Sep 30 01:27:19 h1120016 named[5542]: zone multi-anzeiger.org/IN: sending notifies (serial 2006113000)
Sep 30 01:27:19 h1120016 named[5542]: zone az-server.de/IN: sending notifies (serial 2006120600)
Sep 30 01:27:19 h1120016 named[5542]: zone superpaidmail.de/IN: sending notifies (serial 2006120600)
Sep 30 01:27:19 h1120016 named[5542]: zone berla-bauelemente.de/IN: sending notifies (serial 2006121900)
Sep 30 01:27:19 h1120016 named[5542]: zone csubmit.de/IN: sending notifies (serial 2006121800)
Sep 30 01:27:19 h1120016 named[5542]: zone ads-distributor.com/IN: sending notifies (serial 2007051300)
Sep 30 01:27:19 h1120016 named[5542]: zone myjobfinder.de/IN: sending notifies (serial 2007070700)
Sep 30 01:27:19 h1120016 named[5542]: zone easydistributor.com/IN: sending notifies (serial 2007051300)
Sep 30 01:27:19 h1120016 named[5542]: zone supertausch.net/IN: sending notifies (serial 2007051600)
Sep 30 01:27:19 h1120016 named[5542]: zone classifieds4all.net/IN: sending notifies (serial 2007051300)
Sep 30 01:27:19 h1120016 named[5542]: zone simply-distributor.com/IN: sending notifies (serial 2007051300)
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/bms-imap [file=/etc/xinetd.conf] [line=26]
Sep 30 01:27:20 h1120016 sshd[5574]: Server listening on :: port 22.
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/bms-pop3 [file=/etc/xinetd.d/bms-pop3] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/chargen [file=/etc/xinetd.d/chargen] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/chargen-udp [file=/etc/xinetd.d/chargen-udp] [line=13]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/daytime [file=/etc/xinetd.d/daytime] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/daytime-udp [file=/etc/xinetd.d/daytime-udp] [line=13]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/echo [file=/etc/xinetd.d/echo] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/echo-udp [file=/etc/xinetd.d/echo-udp] [line=13]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/netstat [file=/etc/xinetd.d/netstat] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/rsync [file=/etc/xinetd.d/rsync] [line=16]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/servers [file=/etc/xinetd.d/servers] [line=12]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/services [file=/etc/xinetd.d/services] [line=13]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/systat [file=/etc/xinetd.d/systat] [line=13]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/telnet [file=/etc/xinetd.d/telnet] [line=17]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/time [file=/etc/xinetd.d/time] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/time-udp [file=/etc/xinetd.d/time-udp] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/visasd3 [file=/etc/xinetd.d/visasd3] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: Reading included configuration file: /etc/xinetd.d/vsftpd [file=/etc/xinetd.d/vsftpd] [line=14]
Sep 30 01:27:20 h1120016 xinetd[5573]: removing chargen
Sep 30 01:27:20 h1120016 xinetd[5573]: removing daytime
Sep 30 01:27:20 h1120016 xinetd[5573]: removing echo
Sep 30 01:27:20 h1120016 xinetd[5573]: removing netstat
Sep 30 01:27:20 h1120016 xinetd[5573]: removing rsync
Sep 30 01:27:20 h1120016 xinetd[5573]: removing servers
Sep 30 01:27:20 h1120016 xinetd[5573]: removing services
Sep 30 01:27:20 h1120016 xinetd[5573]: removing systat
Sep 30 01:27:20 h1120016 xinetd[5573]: removing telnet
Sep 30 01:27:20 h1120016 xinetd[5573]: removing time
Sep 30 01:27:20 h1120016 xinetd[5573]: xinetd Version 2.3.13 started with libwrap loadavg options compiled in.
Sep 30 01:27:20 h1120016 xinetd[5573]: Started working: 4 available services
Sep 30 01:27:21 h1120016 authdaemond.plain: authdaemon: modules="authcustom authcram authuserdb authvchkpw authshadow authpwd", daemons=5
Sep 30 01:27:22 h1120016 kernel: klogd 1.4.1, log source = /proc/kmsg started.
Sep 30 01:27:22 h1120016 kernel: Capability LSM initialized
Sep 30 01:27:22 h1120016 kernel: Disabled Privacy Extensions on device c038e740(lo)
Sep 30 01:27:22 h1120016 kernel: tg3.c:v3.23 (February 15, 2005)
Sep 30 01:27:22 h1120016 kernel: ACPI: PCI interrupt 0000:02:03.0[A] -> GSI 24 (level, low) -> IRQ 177
Sep 30 01:27:22 h1120016 kernel: eth0: Tigon3 [partno(BCM95704A6) rev 2100 PHY(5704)] (PCI:66MHz:64-bit) 10/100/1000BaseT Ethernet 00:30:48:59:54:56
Sep 30 01:27:22 h1120016 kernel: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] Split[0] WireSpeed[1] TSOcap[0]
Sep 30 01:27:22 h1120016 kernel: ACPI: PCI interrupt 0000:02:03.1[b] -> GSI 25 (level, low) -> IRQ 185
Sep 30 01:27:22 h1120016 kernel: eth1: Tigon3 [partno(BCM95704A6) rev 2100 PHY(5704)] (PCI:66MHz:64-bit) 10/100/1000BaseT Ethernet 00:30:48:59:54:57
Sep 30 01:27:22 h1120016 kernel: eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] Split[0] WireSpeed[1] TSOcap[1]
Sep 30 01:27:22 h1120016 kernel: load_module: err 0xffffffef (dont worry)
Sep 30 01:27:22 h1120016 kernel: NET: Registered protocol family 17
Sep 30 01:27:22 h1120016 kernel: tg3: eth0: Link is up at 100 Mbps, full duplex.
Sep 30 01:27:22 h1120016 kernel: tg3: eth0: Flow control is off for TX and off for RX.
Sep 30 01:27:22 h1120016 kernel: ACPI: Power Button (FF) [PWRF]
Sep 30 01:27:22 h1120016 kernel: ACPI: Sleep Button (FF) [SLPF]
Sep 30 01:27:22 h1120016 kernel: eth0: no IPv6 routers present
Sep 30 01:27:22 h1120016 ntpdate[5698]: step time server 81.169.163.105 offset -0.056161 sec
Sep 30 01:27:22 h1120016 ntpd[5714]: ntpd 4.2.0a@1.1190-r Sat Mar 19 19:20:10 UTC 2005 (1)
Sep 30 01:27:22 h1120016 ntpd[5714]: precision = 3.000 usec
Sep 30 01:27:22 h1120016 ntpd[5714]: Listening on interface wildcard, 0.0.0.0#123
Sep 30 01:27:22 h1120016 ntpd[5714]: Listening on interface wildcard, ::#123
Sep 30 01:27:22 h1120016 ntpd[5714]: Listening on interface lo, 127.0.0.1#123
Sep 30 01:27:22 h1120016 ntpd[5714]: Listening on interface eth0, 85.214.77.20#123
Sep 30 01:27:22 h1120016 ntpd[5714]: kernel time sync status 0040
Sep 30 01:27:22 h1120016 ntpd[5714]: frequency initialized 51.536 PPM from /var/lib/ntp/drift/ntp.drift
Sep 30 01:27:23 h1120016 /usr/sbin/cron[5771]: (CRON) STARTUP (V5.0)
Sep 30 01:27:31 h1120016 sshd[5752]: Accepted keyboard-interactive/pam for root from ::ffff:212.56.244.85 port 2900 ssh2
Sep 30 01:27:32 h1120016 sshd[5752]: subsystem request for sftp
Sep 30 01:30:01 h1120016 /usr/sbin/cron[19731]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:30:01 h1120016 /usr/sbin/cron[19733]: (root) CMD (root test -x /usr/lib/cron/run-crons && /usr/lib/cron/run-crons >/dev/null 2>&1)
Sep 30 01:33:01 h1120016 /usr/sbin/cron[29665]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:35:52 h1120016 login[29765]: FAILED LOGIN 1 FROM /dev/ttyS0 FOR root, Authentication failure
Sep 30 01:36:01 h1120016 /usr/sbin/cron[30346]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:38:11 h1120016 sshd[30777]: Accepted keyboard-interactive/pam for root from ::ffff:212.56.244.85 port 3406 ssh2
Sep 30 01:38:12 h1120016 sshd[30777]: subsystem request for sftp
Sep 30 01:39:01 h1120016 /usr/sbin/cron[30954]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:39:42 h1120016 sshd[31142]: Did not receive identification string from ::ffff:82.192.68.82
Sep 30 01:42:01 h1120016 /usr/sbin/cron[31621]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:45:01 h1120016 /usr/sbin/cron[32291]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:45:01 h1120016 /usr/sbin/cron[32293]: (root) CMD (root test -x /usr/lib/cron/run-crons && /usr/lib/cron/run-crons >/dev/null 2>&1)
Sep 30 01:48:01 h1120016 /usr/sbin/cron[461]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:51:01 h1120016 /usr/sbin/cron[1059]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:54:01 h1120016 /usr/sbin/cron[1811]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 01:57:01 h1120016 /usr/sbin/cron[2564]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 02:00:01 h1120016 /usr/sbin/cron[3555]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 02:00:01 h1120016 /usr/sbin/cron[3557]: (root) CMD (root test -x /usr/lib/cron/run-crons && /usr/lib/cron/run-crons >/dev/null 2>&1)
Sep 30 02:00:24 h1120016 sshd[3636]: Accepted keyboard-interactive/pam for root from ::ffff:212.56.244.85 port 3750 ssh2
Sep 30 02:04:25 h1120016 syslog-ng[5166]: syslog-ng version 1.6.5 starting
Sep 30 02:04:27 h1120016 named[5317]: starting BIND 9.3.1 -t /var/lib/named -u named
Sep 30 02:04:27 h1120016 named[5317]: found 1 CPU, using 1 worker thread
Sep 30 02:04:27 h1120016 named[5317]: loading configuration from '/etc/named.conf'
Sep 30 02:04:27 h1120016 named[5317]: listening on IPv6 interfaces, port 53
Sep 30 02:04:27 h1120016 named[5317]: listening on IPv4 interface lo, 127.0.0.1#53
Sep 30 02:04:27 h1120016 named[5317]: listening on IPv4 interface eth0, 85.214.77.20#53
Sep 30 02:04:27 h1120016 named[5317]: command channel listening on 127.0.0.1#953
Sep 30 02:04:27 h1120016 named[5317]: command channel listening on ::1#953
Sep 30 02:04:27 h1120016 named[5317]: zone 0.0.127.in-addr.arpa/IN: loaded serial 42
Sep 30 02:04:27 h1120016 named[5317]: zone ads-distributor.com/IN: loaded serial 2007051300
Sep 30 02:04:27 h1120016 named[5317]: zone easydistributor.com/IN: loaded serial 2007051300
Sep 30 02:04:27 h1120016 named[5317]: zone multi-anzeiger.com/IN: loaded serial 2006113000
Sep 30 02:04:27 h1120016 named[5317]: zone multi-indicator.com/IN: loaded serial 2007051300
Sep 30 02:04:27 h1120016 named[5317]: zone simply-distributor.com/IN: loaded serial 2007051300
Sep 30 02:04:27 h1120016 named[5317]: zone az-server.de/IN: loaded serial 2006120600
Sep 30 02:04:27 h1120016 named[5317]: zone bannerpartner.de/IN: loaded serial 2006120600
Sep 30 02:04:27 h1120016 named[5317]: zone berla-bauelemente.de/IN: loaded serial 2006121900
Sep 30 02:04:27 h1120016 named[5317]: zone csubmit.de/IN: loaded serial 2006121800
Sep 30 02:04:27 h1120016 named[5317]: zone mailpunkte.de/IN: loaded serial 2006120600
Sep 30 02:04:27 h1120016 named[5317]: zone myjobfinder.de/IN: loaded serial 2007070700
Sep 30 02:04:28 h1120016 named[5317]: zone pep-is.de/IN: loaded serial 2007040400
Sep 30 02:04:28 h1120016 named[5317]: zone spiderline.de/IN: loaded serial 2007031300
Sep 30 02:04:28 h1120016 named[5317]: zone superpaidmail.de/IN: loaded serial 2006120600
Sep 30 02:04:28 h1120016 named[5317]: zone localhost/IN: loaded serial 42
Sep 30 02:04:28 h1120016 named[5317]: zone classifieds4all.net/IN: loaded serial 2007051300
Sep 30 02:04:28 h1120016 named[5317]: zone supertausch.net/IN: loaded serial 2007051600
Sep 30 02:04:28 h1120016 named[5317]: zone multi-anzeiger.org/IN: loaded serial 2006113000
Sep 30 02:04:28 h1120016 named[5317]: running
Sep 30 02:04:28 h1120016 named[5317]: zone bannerpartner.de/IN: sending notifies (serial 2006120600)
Sep 30 02:04:28 h1120016 named[5317]: zone mailpunkte.de/IN: sending notifies (serial 2006120600)
Sep 30 02:04:28 h1120016 named[5317]: zone pep-is.de/IN: sending notifies (serial 2007040400)
Sep 30 02:04:28 h1120016 named[5317]: zone spiderline.de/IN: sending notifies (serial 2007031300)
Sep 30 02:04:28 h1120016 named[5317]: zone multi-indicator.com/IN: sending notifies (serial 2007051300)
Sep 30 02:04:28 h1120016 named[5317]: zone multi-anzeiger.com/IN: sending notifies (serial 2006113000)
Sep 30 02:04:28 h1120016 named[5317]: zone multi-anzeiger.org/IN: sending notifies (serial 2006113000)
Sep 30 02:04:28 h1120016 named[5317]: zone az-server.de/IN: sending notifies (serial 2006120600)
Sep 30 02:04:28 h1120016 named[5317]: zone superpaidmail.de/IN: sending notifies (serial 2006120600)
Sep 30 02:04:28 h1120016 named[5317]: zone berla-bauelemente.de/IN: sending notifies (serial 2006121900)
Sep 30 02:04:28 h1120016 named[5317]: zone csubmit.de/IN: sending notifies (serial 2006121800)
Sep 30 02:04:28 h1120016 named[5317]: zone ads-distributor.com/IN: sending notifies (serial 2007051300)
Sep 30 02:04:28 h1120016 named[5317]: zone myjobfinder.de/IN: sending notifies (serial 2007070700)
Sep 30 02:04:28 h1120016 named[5317]: zone easydistributor.com/IN: sending notifies (serial 2007051300)
Sep 30 02:04:28 h1120016 named[5317]: zone supertausch.net/IN: sending notifies (serial 2007051600)
Sep 30 02:04:28 h1120016 named[5317]: zone classifieds4all.net/IN: sending notifies (serial 2007051300)
Sep 30 02:04:28 h1120016 named[5317]: zone simply-distributor.com/IN: sending notifies (serial 2007051300)
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/bms-imap [file=/etc/xinetd.conf] [line=26]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/bms-pop3 [file=/etc/xinetd.d/bms-pop3] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/chargen [file=/etc/xinetd.d/chargen] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/chargen-udp [file=/etc/xinetd.d/chargen-udp] [line=13]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/daytime [file=/etc/xinetd.d/daytime] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/daytime-udp [file=/etc/xinetd.d/daytime-udp] [line=13]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/echo [file=/etc/xinetd.d/echo] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/echo-udp [file=/etc/xinetd.d/echo-udp] [line=13]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/netstat [file=/etc/xinetd.d/netstat] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/rsync [file=/etc/xinetd.d/rsync] [line=16]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/servers [file=/etc/xinetd.d/servers] [line=12]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/services [file=/etc/xinetd.d/services] [line=13]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/systat [file=/etc/xinetd.d/systat] [line=13]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/telnet [file=/etc/xinetd.d/telnet] [line=17]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/time [file=/etc/xinetd.d/time] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/time-udp [file=/etc/xinetd.d/time-udp] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/visasd3 [file=/etc/xinetd.d/visasd3] [line=14]
Sep 30 02:04:29 h1120016 sshd[5353]: Server listening on :: port 22.
Sep 30 02:04:29 h1120016 xinetd[5352]: Reading included configuration file: /etc/xinetd.d/vsftpd [file=/etc/xinetd.d/vsftpd] [line=14]
Sep 30 02:04:29 h1120016 xinetd[5352]: removing chargen
Sep 30 02:04:29 h1120016 xinetd[5352]: removing daytime
Sep 30 02:04:29 h1120016 xinetd[5352]: removing echo
Sep 30 02:04:29 h1120016 xinetd[5352]: removing netstat
Sep 30 02:04:29 h1120016 xinetd[5352]: removing rsync
Sep 30 02:04:29 h1120016 xinetd[5352]: removing servers
Sep 30 02:04:29 h1120016 xinetd[5352]: removing services
Sep 30 02:04:29 h1120016 xinetd[5352]: removing systat
Sep 30 02:04:29 h1120016 xinetd[5352]: removing telnet
Sep 30 02:04:29 h1120016 xinetd[5352]: removing time
Sep 30 02:04:29 h1120016 xinetd[5352]: xinetd Version 2.3.13 started with libwrap loadavg options compiled in.
Sep 30 02:04:29 h1120016 xinetd[5352]: Started working: 4 available services
Sep 30 02:04:30 h1120016 kernel: klogd 1.4.1, log source = /proc/kmsg started.
Sep 30 02:04:30 h1120016 kernel: Capability LSM initialized
Sep 30 02:04:30 h1120016 kernel: Disabled Privacy Extensions on device c038e740(lo)
Sep 30 02:04:30 h1120016 kernel: tg3.c:v3.23 (February 15, 2005)
Sep 30 02:04:30 h1120016 kernel: ACPI: PCI interrupt 0000:02:03.0[A] -> GSI 24 (level, low) -> IRQ 177
Sep 30 02:04:30 h1120016 kernel: eth0: Tigon3 [partno(BCM95704A6) rev 2100 PHY(5704)] (PCI:66MHz:64-bit) 10/100/1000BaseT Ethernet 00:30:48:59:54:56
Sep 30 02:04:30 h1120016 kernel: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[1] Split[0] WireSpeed[1] TSOcap[0]
Sep 30 02:04:30 h1120016 kernel: ACPI: PCI interrupt 0000:02:03.1[b] -> GSI 25 (level, low) -> IRQ 185
Sep 30 02:04:30 h1120016 kernel: eth1: Tigon3 [partno(BCM95704A6) rev 2100 PHY(5704)] (PCI:66MHz:64-bit) 10/100/1000BaseT Ethernet 00:30:48:59:54:57
Sep 30 02:04:30 h1120016 kernel: eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] Split[0] WireSpeed[1] TSOcap[1]
Sep 30 02:04:30 h1120016 kernel: load_module: err 0xffffffef (dont worry)
Sep 30 02:04:30 h1120016 kernel: NET: Registered protocol family 17
Sep 30 02:04:30 h1120016 kernel: tg3: eth0: Link is up at 100 Mbps, full duplex.
Sep 30 02:04:30 h1120016 kernel: tg3: eth0: Flow control is off for TX and off for RX.
Sep 30 02:04:30 h1120016 kernel: ACPI: Power Button (FF) [PWRF]
Sep 30 02:04:30 h1120016 kernel: ACPI: Sleep Button (FF) [SLPF]
Sep 30 02:04:30 h1120016 kernel: eth0: no IPv6 routers present
Sep 30 02:04:30 h1120016 authdaemond.plain: authdaemon: modules="authcustom authcram authuserdb authvchkpw authshadow authpwd", daemons=5
Sep 30 02:04:31 h1120016 ntpdate[5482]: step time server 81.169.163.102 offset -0.234277 sec
Sep 30 02:04:31 h1120016 ntpd[5489]: ntpd 4.2.0a@1.1190-r Sat Mar 19 19:20:10 UTC 2005 (1)
Sep 30 02:04:31 h1120016 ntpd[5489]: precision = 3.000 usec
Sep 30 02:04:31 h1120016 ntpd[5489]: Listening on interface wildcard, 0.0.0.0#123
Sep 30 02:04:31 h1120016 ntpd[5489]: Listening on interface wildcard, ::#123
Sep 30 02:04:31 h1120016 ntpd[5489]: Listening on interface lo, 127.0.0.1#123
Sep 30 02:04:31 h1120016 ntpd[5489]: Listening on interface eth0, 85.214.77.20#123
Sep 30 02:04:31 h1120016 ntpd[5489]: kernel time sync status 0040
Sep 30 02:04:31 h1120016 ntpd[5489]: frequency initialized 51.536 PPM from /var/lib/ntp/drift/ntp.drift
Sep 30 02:04:32 h1120016 /usr/sbin/cron[5546]: (CRON) STARTUP (V5.0)
Sep 30 02:06:00 h1120016 sshd[10344]: Accepted keyboard-interactive/pam for root from ::ffff:212.56.244.85 port 3902 ssh2
Sep 30 02:06:01 h1120016 /usr/sbin/cron[11427]: (root) CMD (/usr/local/visas/server/visas-event.sh )
Sep 30 02:06:57 h1120016 sshd[16533]: Accepted keyboard-interactive/pam for root from ::ffff:212.56.244.85 port 3905 ssh2
Sep 30 02:06:58 h1120016 sshd[16533]: subsystem request for sftp
Sep 30 02:09:01 h1120016 /usr/sbin/cron[30861]: (root) CMD (/usr/local/visas/server/visas-event.sh )
