Mar 13 12:50:29 pq42 syslogd 1.4.1#18: restart.
Mar 13 12:50:29 pq42 kernel: klogd 1.4.1#18, log source = /proc/kmsg started.
Mar 13 12:50:29 pq42 kernel: Bootdata ok (command line is auto BOOT_IMAGE=Linux ro root=902)
Mar 13 12:50:29 pq42 kernel: Linux version 2.6.18-5-amd64 (Debian 2.6.18.dfsg.1-13etch4) (dannf@debian.org) (gcc version 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)) #1 SMP Tue Oct 2 20:37:02 UTC 2007
Mar 13 12:50:29 pq42 kernel: BIOS-provided physical RAM map:
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 0000000000100000 - 000000007fef0000 (usable)
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 000000007fef0000 - 000000007fef3000 (ACPI NVS)
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 000000007fef3000 - 000000007ff00000 (ACPI data)
Mar 13 12:50:29 pq42 kernel: BIOS-e820: 00000000fec00000 - 0000000100000000 (reserved)
Mar 13 12:50:29 pq42 kernel: DMI 2.3 present.
Mar 13 12:50:29 pq42 kernel: SRAT: PXM 0 -> APIC 0 -> Node 0
Mar 13 12:50:29 pq42 kernel: SRAT: Node 0 PXM 0 0-a0000
Mar 13 12:50:29 pq42 kernel: SRAT: Node 0 PXM 0 0-80000000
Mar 13 12:50:29 pq42 kernel: Bootmem setup node 0 0000000000000000-000000007fef0000
Mar 13 12:50:29 pq42 kernel: ACPI: PM-Timer IO Port: 0x4008
Mar 13 12:50:29 pq42 kernel: ACPI: LAPIC (acpi_id[0x00] lapic_id[0x00] enabled)
Mar 13 12:50:29 pq42 kernel: Processor #0 15:7 APIC version 16
Mar 13 12:50:29 pq42 kernel: ACPI: LAPIC (acpi_id[0x01] lapic_id[0x01] disabled)
Mar 13 12:50:29 pq42 kernel: ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
Mar 13 12:50:29 pq42 kernel: ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
Mar 13 12:50:29 pq42 kernel: ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
Mar 13 12:50:29 pq42 kernel: IOAPIC[0]: apic_id 2, version 3, address 0xfec00000, GSI 0-23
Mar 13 12:50:29 pq42 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
Mar 13 12:50:29 pq42 kernel: ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
Mar 13 12:50:29 pq42 kernel: Setting APIC routing to physical flat
Mar 13 12:50:29 pq42 kernel: Using ACPI (MADT) for SMP configuration information
Mar 13 12:50:29 pq42 kernel: Allocating PCI resources starting at 80000000 (gap: 7ff00000:7ed00000)
Mar 13 12:50:29 pq42 kernel: SMP: Allowing 2 CPUs, 1 hotplug CPUs
Mar 13 12:50:29 pq42 kernel: Built 1 zonelists. Total pages: 514584
Mar 13 12:50:29 pq42 kernel: Kernel command line: auto BOOT_IMAGE=Linux ro root=902
Mar 13 12:50:29 pq42 kernel: Initializing CPU#0
Mar 13 12:50:29 pq42 kernel: PID hash table entries: 4096 (order: 12, 32768 bytes)
Mar 13 12:50:29 pq42 kernel: time.c: Using 3.579545 MHz WALL PM GTOD PIT/TSC timer.
Mar 13 12:50:29 pq42 kernel: time.c: Detected 2199.833 MHz processor.
Mar 13 12:50:29 pq42 kernel: Console: colour dummy device 80x25
Mar 13 12:50:29 pq42 kernel: Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
Mar 13 12:50:29 pq42 kernel: Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
Mar 13 12:50:29 pq42 kernel: Checking aperture...
Mar 13 12:50:29 pq42 kernel: CPU 0: aperture @ f0000000 size 128 MB
Mar 13 12:50:29 pq42 kernel: Memory: 2055080k/2096064k available (1927k kernel code, 40596k reserved, 868k data, 176k init)
Mar 13 12:50:29 pq42 kernel: Calibrating delay using timer specific routine.. 4404.60 BogoMIPS (lpj=8809216)
Mar 13 12:50:29 pq42 kernel: Security Framework v1.0.0 initialized
Mar 13 12:50:29 pq42 kernel: SELinux: Disabled at boot.
Mar 13 12:50:29 pq42 kernel: Capability LSM initialized
Mar 13 12:50:29 pq42 kernel: Mount-cache hash table entries: 256
Mar 13 12:50:29 pq42 kernel: CPU: L1 I Cache: 64K (64 bytes/line), D cache 64K (64 bytes/line)
Mar 13 12:50:29 pq42 kernel: CPU: L2 Cache: 1024K (64 bytes/line)
Mar 13 12:50:29 pq42 kernel: CPU 0/0 -> Node 0
Mar 13 12:50:29 pq42 kernel: SMP alternatives: switching to UP code
Mar 13 12:50:29 pq42 kernel: ACPI: Core revision 20060707
Mar 13 12:50:29 pq42 kernel: Using local APIC timer interrupts.
Mar 13 12:50:29 pq42 kernel: result 12499052
Mar 13 12:50:29 pq42 kernel: Detected 12.499 MHz APIC timer.
Mar 13 12:50:29 pq42 kernel: Brought up 1 CPUs
Mar 13 12:50:29 pq42 kernel: testing NMI watchdog ... OK.
Mar 13 12:50:29 pq42 kernel: migration_cost=0
Mar 13 12:50:29 pq42 kernel: checking if image is initramfs... it is
Mar 13 12:50:29 pq42 kernel: Freeing initrd memory: 5136k freed
Mar 13 12:50:29 pq42 kernel: NET: Registered protocol family 16
Mar 13 12:50:29 pq42 kernel: ACPI: bus type pci registered
Mar 13 12:50:29 pq42 kernel: PCI: Using configuration type 1
Mar 13 12:50:29 pq42 kernel: ACPI: Interpreter enabled
Mar 13 12:50:29 pq42 kernel: ACPI: Using IOAPIC for interrupt routing
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 6 7 *10 11 12)
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 6 7 10 *11 12)
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 6 7 10 11 12) *5
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNK0] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [LNK1] (IRQs 3 4 6 7 10 11 12) *0, disabled.
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [ALKA] (IRQs *20)
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [ALKB] (IRQs *21)
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [ALKC] (IRQs *22), disabled.
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [ALKD] (IRQs *23), disabled.
Mar 13 12:50:29 pq42 kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Mar 13 12:50:29 pq42 kernel: pnp: PnP ACPI init
Mar 13 12:50:29 pq42 kernel: pnp: PnP ACPI: found 13 devices
Mar 13 12:50:29 pq42 kernel: usbcore: registered new driver usbfs
Mar 13 12:50:29 pq42 kernel: usbcore: registered new driver hub
Mar 13 12:50:29 pq42 kernel: PCI: Using ACPI for IRQ routing
Mar 13 12:50:29 pq42 kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Mar 13 12:50:29 pq42 kernel: agpgart: Detected AGP bridge 0
Mar 13 12:50:29 pq42 kernel: agpgart: AGP aperture is 128M @ 0xf0000000
Mar 13 12:50:29 pq42 kernel: PCI-DMA: Disabling IOMMU.
Mar 13 12:50:29 pq42 kernel: pnp: 00:02: ioport range 0x4000-0x407f could not be reserved
Mar 13 12:50:29 pq42 kernel: pnp: 00:02: ioport range 0x5000-0x500f has been reserved
Mar 13 12:50:29 pq42 kernel: PCI: Bridge: 0000:00:01.0
Mar 13 12:50:29 pq42 kernel: IO window: disabled.
Mar 13 12:50:29 pq42 kernel: MEM window: fa000000-fcffffff
Mar 13 12:50:29 pq42 kernel: PREFETCH window: f8000000-f9ffffff
Mar 13 12:50:29 pq42 kernel: NET: Registered protocol family 2
Mar 13 12:50:29 pq42 kernel: IP route cache hash table entries: 65536 (order: 7, 524288 bytes)
Mar 13 12:50:29 pq42 kernel: TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
Mar 13 12:50:29 pq42 kernel: TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
Mar 13 12:50:29 pq42 kernel: TCP: Hash tables configured (established 262144 bind 65536)
Mar 13 12:50:29 pq42 kernel: TCP reno registered
Mar 13 12:50:29 pq42 kernel: audit: initializing netlink socket (disabled)
Mar 13 12:50:29 pq42 kernel: audit(1300020615.652:1): initialized
Mar 13 12:50:29 pq42 kernel: VFS: Disk quotas dquot_6.5.1
Mar 13 12:50:29 pq42 kernel: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
Mar 13 12:50:29 pq42 kernel: Initializing Cryptographic API
Mar 13 12:50:29 pq42 kernel: io scheduler noop registered
Mar 13 12:50:29 pq42 kernel: io scheduler anticipatory registered
Mar 13 12:50:29 pq42 kernel: io scheduler deadline registered
Mar 13 12:50:29 pq42 kernel: io scheduler cfq registered (default)
Mar 13 12:50:29 pq42 kernel: vesafb: framebuffer at 0xf8000000, mapped to 0xffffc20000100000, using 3072k, total 16384k
Mar 13 12:50:29 pq42 kernel: vesafb: mode is 1024x768x16, linelength=2048, pages=9
Mar 13 12:50:29 pq42 kernel: vesafb: scrolling: redraw
Mar 13 12:50:29 pq42 kernel: vesafb: Truecolor: size=0:5:6:5, shift=0:11:5:0
Mar 13 12:50:29 pq42 kernel: Console: switching to colour frame buffer device 128x48
Mar 13 12:50:29 pq42 kernel: fb0: VESA VGA frame buffer device
Mar 13 12:50:29 pq42 kernel: Real Time Clock Driver v1.12ac
Mar 13 12:50:29 pq42 kernel: Linux agpgart interface v0.101 (c) Dave Jones
Mar 13 12:50:29 pq42 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing enabled
Mar 13 12:50:29 pq42 kernel: serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Mar 13 12:50:29 pq42 kernel: serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Mar 13 12:50:29 pq42 kernel: 00:09: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Mar 13 12:50:29 pq42 kernel: 00:0a: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
Mar 13 12:50:29 pq42 kernel: RAMDISK driver initialized: 16 RAM disks of 65536K size 1024 blocksize
Mar 13 12:50:29 pq42 kernel: PNP: PS/2 Controller [PNP0f13:PS2M] at 0x60,0x64 irq 12
Mar 13 12:50:29 pq42 kernel: PNP: PS/2 controller doesn't have KBD irq; using default 1
Mar 13 12:50:29 pq42 kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Mar 13 12:50:29 pq42 kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Mar 13 12:50:29 pq42 kernel: mice: PS/2 mouse device common for all mice
Mar 13 12:50:29 pq42 kernel: TCP bic registered
Mar 13 12:50:29 pq42 kernel: NET: Registered protocol family 17
Mar 13 12:50:29 pq42 kernel: NET: Registered protocol family 8
Mar 13 12:50:29 pq42 kernel: NET: Registered protocol family 20
Mar 13 12:50:29 pq42 kernel: ACPI: (supports S0 S1 S4 S5)
Mar 13 12:50:29 pq42 kernel: Freeing unused kernel memory: 176k freed
Mar 13 12:50:29 pq42 kernel: input: AT Raw Set 2 keyboard as /class/input/input0
Mar 13 12:50:29 pq42 kernel: SGI XFS with ACLs, security attributes, realtime, large block/inode numbers, no debug enabled
Mar 13 12:50:29 pq42 kernel: SGI XFS Quota Management subsystem
Mar 13 12:50:29 pq42 kernel: SCSI subsystem initialized
Mar 13 12:50:29 pq42 kernel: 3ware Storage Controller device driver for Linux v1.26.02.001.
Mar 13 12:50:29 pq42 kernel: 3ware 9000 Storage Controller device driver for Linux v2.26.02.007.
Mar 13 12:50:29 pq42 kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Mar 13 12:50:29 pq42 kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Mar 13 12:50:29 pq42 kernel: VP_IDE: IDE controller at PCI slot 0000:00:0f.1
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [ALKA] enabled at IRQ 20
Mar 13 12:50:29 pq42 kernel: GSI 16 sharing vector 0xA9 and IRQ 16
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:0f.1[A] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 169
Mar 13 12:50:29 pq42 kernel: PCI: VIA IRQ fixup for 0000:00:0f.1, from 255 to 9
Mar 13 12:50:29 pq42 kernel: VP_IDE: chipset revision 6
Mar 13 12:50:29 pq42 kernel: VP_IDE: not 100%% native mode: will probe irqs later
Mar 13 12:50:29 pq42 kernel: VP_IDE: VIA vt8237 (rev 00) IDE UDMA133 controller on pci0000:00:0f.1
Mar 13 12:50:29 pq42 kernel: ide0: BM-DMA at 0xe700-0xe707, BIOS settings: hda:pio, hdb:pio
Mar 13 12:50:29 pq42 kernel: ide1: BM-DMA at 0xe708-0xe70f, BIOS settings: hdc:pio, hdd:pio
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:0f.0[B] -> Link [ALKA] -> GSI 20 (level, low) -> IRQ 169
Mar 13 12:50:29 pq42 kernel: sata_via 0000:00:0f.0: routed to hard irq line 11
Mar 13 12:50:29 pq42 kernel: ata1: SATA max UDMA/133 cmd 0xE100 ctl 0xE202 bmdma 0xE500 irq 169
Mar 13 12:50:29 pq42 kernel: ata2: SATA max UDMA/133 cmd 0xE300 ctl 0xE402 bmdma 0xE508 irq 169
Mar 13 12:50:29 pq42 kernel: scsi0 : sata_via
Mar 13 12:50:29 pq42 kernel: ata1: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Mar 13 12:50:29 pq42 kernel: ata1.00: ATA-7, max UDMA7, 312581808 sectors: LBA48 NCQ (depth 0/32)
Mar 13 12:50:29 pq42 kernel: ata1.00: ata1: dev 0 multi count 16
Mar 13 12:50:29 pq42 kernel: ata1.00: configured for UDMA/133
Mar 13 12:50:29 pq42 kernel: scsi1 : sata_via
Mar 13 12:50:29 pq42 kernel: ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Mar 13 12:50:29 pq42 kernel: ata2.00: ATA-7, max UDMA7, 312581808 sectors: LBA48 NCQ (depth 0/32)
Mar 13 12:50:29 pq42 kernel: ata2.00: ata2: dev 0 multi count 16
Mar 13 12:50:29 pq42 kernel: ata2.00: configured for UDMA/133
Mar 13 12:50:29 pq42 kernel: Vendor: ATA Model: SAMSUNG HD160JJ Rev: ZM10
Mar 13 12:50:29 pq42 kernel: Type: Direct-Access ANSI SCSI revision: 05
Mar 13 12:50:29 pq42 kernel: md: md driver 0.90.3 MAX_MD_DEVS=256, MD_SB_DISKS=27
Mar 13 12:50:29 pq42 kernel: md: bitmap version 4.39
Mar 13 12:50:29 pq42 kernel: md: raid0 personality registered for level 0
Mar 13 12:50:29 pq42 kernel: md: raid1 personality registered for level 1
Mar 13 12:50:29 pq42 kernel: ACPI Exception (acpi_processor-0681): AE_NOT_FOUND, Processor Device is not present [20060707]
Mar 13 12:50:29 pq42 kernel: powernow-k8: Found 1 AMD Athlon(tm) 64 Processor 3700+ processors (version 2.00.00)
Mar 13 12:50:29 pq42 kernel: powernow-k8: 0 : fid 0x2 (1000 MHz), vid 0x12
Mar 13 12:50:29 pq42 kernel: powernow-k8: 1 : fid 0xa (1800 MHz), vid 0xa
Mar 13 12:50:29 pq42 kernel: powernow-k8: 2 : fid 0xc (2000 MHz), vid 0x8
Mar 13 12:50:29 pq42 kernel: powernow-k8: 3 : fid 0xe (2200 MHz), vid 0x8
Mar 13 12:50:29 pq42 kernel: SCSI device sda: 312581808 512-byte hdwr sectors (160042 MB)
Mar 13 12:50:29 pq42 kernel: sda: Write Protect is off
Mar 13 12:50:29 pq42 kernel: SCSI device sda: drive cache: write back
Mar 13 12:50:29 pq42 kernel: sda: sda1 sda2 sda3
Mar 13 12:50:29 pq42 kernel: sd 0:0:0:0: Attached scsi disk sda
Mar 13 12:50:29 pq42 kernel: SCSI device sdb: 312581808 512-byte hdwr sectors (160042 MB)
Mar 13 12:50:29 pq42 kernel: sdb: Write Protect is off
Mar 13 12:50:29 pq42 kernel: SCSI device sdb: drive cache: write back
Mar 13 12:50:29 pq42 kernel: sdb: sdb1 sdb2 sdb3
Mar 13 12:50:29 pq42 kernel: sd 1:0:0:0: Attached scsi disk sdb
Mar 13 12:50:29 pq42 kernel: r8169 Gigabit Ethernet driver 2.2LK-NAPI loaded
Mar 13 12:50:29 pq42 kernel: GSI 17 sharing vector 0xB1 and IRQ 17
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:0d.0[A] -> GSI 16 (level, low) -> IRQ 177
Mar 13 12:50:29 pq42 kernel: eth0: RTL8169sb/8110sb at 0xffffc2000001c000, 00:16:17:6b:35:20, IRQ 177
Mar 13 12:50:29 pq42 kernel: USB Universal Host Controller Interface driver v3.0
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt Link [ALKB] enabled at IRQ 21
Mar 13 12:50:29 pq42 kernel: GSI 18 sharing vector 0xB9 and IRQ 18
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:10.0[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
Mar 13 12:50:29 pq42 kernel: PCI: VIA IRQ fixup for 0000:00:10.0, from 10 to 9
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.0: UHCI Host Controller
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.0: new USB bus registered, assigned bus number 1
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.0: irq 185, io base 0x0000e800
Mar 13 12:50:29 pq42 kernel: usb usb1: configuration #1 chosen from 1 choice
Mar 13 12:50:29 pq42 kernel: hub 1-0:1.0: USB hub found
Mar 13 12:50:29 pq42 kernel: hub 1-0:1.0: 2 ports detected
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:10.1[A] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
Mar 13 12:50:29 pq42 kernel: PCI: VIA IRQ fixup for 0000:00:10.1, from 10 to 9
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.1: UHCI Host Controller
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.1: new USB bus registered, assigned bus number 2
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.1: irq 185, io base 0x0000e900
Mar 13 12:50:29 pq42 kernel: usb usb2: configuration #1 chosen from 1 choice
Mar 13 12:50:29 pq42 kernel: hub 2-0:1.0: USB hub found
Mar 13 12:50:29 pq42 kernel: hub 2-0:1.0: 2 ports detected
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:10.2[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
Mar 13 12:50:29 pq42 kernel: PCI: VIA IRQ fixup for 0000:00:10.2, from 11 to 9
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.2: UHCI Host Controller
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.2: new USB bus registered, assigned bus number 3
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.2: irq 185, io base 0x0000ea00
Mar 13 12:50:29 pq42 kernel: usb usb3: configuration #1 chosen from 1 choice
Mar 13 12:50:29 pq42 kernel: hub 3-0:1.0: USB hub found
Mar 13 12:50:29 pq42 kernel: hub 3-0:1.0: 2 ports detected
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:10.3[B] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
Mar 13 12:50:29 pq42 kernel: PCI: VIA IRQ fixup for 0000:00:10.3, from 11 to 9
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.3: UHCI Host Controller
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.3: new USB bus registered, assigned bus number 4
Mar 13 12:50:29 pq42 kernel: uhci_hcd 0000:00:10.3: irq 185, io base 0x0000eb00
Mar 13 12:50:29 pq42 kernel: usb usb4: configuration #1 chosen from 1 choice
Mar 13 12:50:29 pq42 kernel: hub 4-0:1.0: USB hub found
Mar 13 12:50:29 pq42 kernel: hub 4-0:1.0: 2 ports detected
Mar 13 12:50:29 pq42 kernel: ACPI: PCI Interrupt 0000:00:10.4[C] -> Link [ALKB] -> GSI 21 (level, low) -> IRQ 185
Mar 13 12:50:29 pq42 kernel: PCI: VIA IRQ fixup for 0000:00:10.4, from 5 to 9
Mar 13 12:50:29 pq42 kernel: ehci_hcd 0000:00:10.4: EHCI Host Controller
Mar 13 12:50:29 pq42 kernel: ehci_hcd 0000:00:10.4: new USB bus registered, assigned bus number 5
Mar 13 12:50:29 pq42 kernel: ehci_hcd 0000:00:10.4: irq 185, io mem 0xfd020000
Mar 13 12:50:29 pq42 kernel: ehci_hcd 0000:00:10.4: USB 2.0 started, EHCI 1.00, driver 10 Dec 2004
Mar 13 12:50:29 pq42 kernel: usb usb5: configuration #1 chosen from 1 choice
Mar 13 12:50:29 pq42 kernel: hub 5-0:1.0: USB hub found
Mar 13 12:50:29 pq42 kernel: hub 5-0:1.0: 8 ports detected
Mar 13 12:50:29 pq42 kernel: md: md0 stopped.
Mar 13 12:50:29 pq42 kernel: md: bind<sdb1>
Mar 13 12:50:29 pq42 kernel: md: bind<sda1>
Mar 13 12:50:29 pq42 kernel: raid1: raid set md0 active with 2 out of 2 mirrors
Mar 13 12:50:29 pq42 kernel: md: md1 stopped.
Mar 13 12:50:29 pq42 kernel: md: bind<sdb2>
Mar 13 12:50:29 pq42 kernel: md: bind<sda2>
Mar 13 12:50:29 pq42 kernel: raid1: raid set md1 active with 2 out of 2 mirrors
Mar 13 12:50:29 pq42 kernel: md: md2 stopped.
Mar 13 12:50:29 pq42 kernel: md: bind<sdb3>
Mar 13 12:50:29 pq42 kernel: md: bind<sda3>
Mar 13 12:50:29 pq42 kernel: raid1: raid set md2 active with 2 out of 2 mirrors
Mar 13 12:50:29 pq42 kernel: Attempting manual resume
Mar 13 12:50:29 pq42 kernel: EXT3-fs: INFO: recovery required on readonly filesystem.
Mar 13 12:50:29 pq42 kernel: EXT3-fs: write access will be enabled during recovery.
Mar 13 12:50:29 pq42 kernel: kjournald starting. Commit interval 5 seconds
Mar 13 12:50:29 pq42 kernel: EXT3-fs: md2: orphan cleanup on readonly fs
Mar 13 12:50:29 pq42 kernel: EXT3-fs: md2: 5 orphan inodes deleted
Mar 13 12:50:29 pq42 kernel: EXT3-fs: recovery complete.
Mar 13 12:50:29 pq42 kernel: EXT3-fs: mounted filesystem with ordered data mode.
Mar 13 12:50:29 pq42 kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Mar 13 12:50:29 pq42 kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Mar 13 12:50:29 pq42 kernel: input: PC Speaker as /class/input/input1
Mar 13 12:50:29 pq42 kernel: parport: PnPBIOS parport detected.
Mar 13 12:50:29 pq42 kernel: parport0: PC-style at 0x378, irq 7 [PCSPP]
Mar 13 12:50:29 pq42 kernel: FDC 0 is a post-1991 82077
Mar 13 12:50:29 pq42 kernel: Adding 4200888k swap on /dev/md0. Priority:-1 extents:1 across:4200888k
Mar 13 12:50:29 pq42 kernel: EXT3 FS on md2, internal journal
Mar 13 12:50:29 pq42 kernel: loop: loaded (max 8 devices)
Mar 13 12:50:29 pq42 kernel: device-mapper: ioctl: 4.7.0-ioctl (2006-06-24) initialised: dm-devel@redhat.com
Mar 13 12:50:29 pq42 kernel: EXT3-fs warning: maximal mount count reached, running e2fsck is recommended
Mar 13 12:50:29 pq42 kernel: EXT3 FS on md1, internal journal
Mar 13 12:50:29 pq42 kernel: r8169: eth0: link up
Mar 13 12:50:29 pq42 kernel: NET: Registered protocol family 10
Mar 13 12:50:29 pq42 kernel: lo: Disabled Privacy Extensions
Mar 13 12:50:29 pq42 kernel: IPv6 over IPv4 tunneling driver
Mar 13 12:50:40 pq42 kernel: ACPI: Power Button (FF) [PWRF]
Mar 13 12:50:40 pq42 kernel: ACPI: Power Button (CM) [PWRB]
Mar 13 12:51:09 pq42 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Mar 13 12:51:09 pq42 kernel: Netfilter messages via NETLINK v0.30.
Mar 13 12:51:09 pq42 kernel: ip_conntrack version 2.4 (8192 buckets, 65536 max) - 304 bytes per conntrack
Mar 13 13:10:30 pq42 -- MARK --
Mar 13 13:30:30 pq42 -- MARK --
Mar 13 13:50:30 pq42 -- MARK --
Mar 13 14:10:30 pq42 -- MARK --
Mar 13 14:30:30 pq42 -- MARK --
