Problem mit Postfix
  • Thread starter Thread starter [GSP]TwixX
  • Start date Start date
G
[GSP]TwixX
ich habe da folgendes Problem mit meinem Mailserver:
- er sendet keine Mails raus !
in dern mail.err steht:
Feb 12 20:21:40 GSP-Herkules postfix/sendmail[6906]: fatal: No recipient addresses found in message header
Feb 13 14:39:31 GSP-Herkules postfix/sendmail[27866]: fatal: No recipient addresses found in message header
postconf -n:
GSP-Herkules:~# postconf -n
alias_maps = $alias_database
append_dot_mydomain = no
biff = no
command_directory = /usr/sbin
default_destination_concurrency_limit = 20
inet_interfaces = all
local_destination_concurrency_limit = 2
local_transport = local
mailbox_size_limit = 0
message_size_limit = 52428800
mydestination = $myhostname,    $mydomain,      localhost.$myhostname,  localhost.$mydomain,    localhost
mydomain = [COLOR="Red"]zensiert[/COLOR]
myhostname = mail.[COLOR="Red"]zensiert[/COLOR]
mynetworks = 127.0.0.0/8
smtpd_client_restrictions = permit_mynetworks,  permit_sasl_authenticated,     reject_unknown_client
smtpd_helo_required = yes
smtpd_recipient_restrictions = permit_mynetworks,       permit_sasl_authenticated,      reject_unauth_destination,      reject_unauth_pipelining,       reject_non_fqdn_recipient
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain = $myhostname
smtpd_sender_restrictions = permit_mynetworks,  permit_sasl_authenticated,     reject_unknown_hostname,         reject_unknown_recipient_domain,        reject_unknown_sender_domain
virtual_alias_maps = mysql:/etc/postfix/mysql-virtual_alias_maps.cf
virtual_gid_maps = static:2000
virtual_mailbox_base = /var/kunden/mail/
virtual_mailbox_domains = mysql:/etc/postfix/mysql-virtual_mailbox_domains.cf
virtual_mailbox_maps = mysql:/etc/postfix/mysql-virtual_mailbox_maps.cf
virtual_uid_maps = static:2000
Ich bin schon am verzweifeln. Alles totgegoogelt ! :(
lg Felix
Schickst du die Email via einem Script?
Da fehlt angeblich der Empfänger in der Email (bzw. dem Header).
R-DNS Eintrag definiert für den Host?
Ja.
Keine Ahnung ich habe darauf die Homepages von mir und 3 Kumpel alle über WBB3 und TekCMS auf meinen Servern.
lg Felix :o
Hi!
Sind das zufällig alles Mails an ganze Gruppen und alle Empfänger stehen nur im BCC? Und demnach wäre das Empfänger-Feld leer?
Grüße, fkerber
also wenn wenn mann sich jetzt z.b registrieren will bekommt man keine mail oder sonstiges sowohl bei ilch, webspell, wbb3 und tekcms nicht
lg Felix
Das Versenden einer Mail auf der Console mit "echo blah | mailx empfänger@empfänger.de" funktioniert aber, oder?
Und wie sieht der vollständige Auszug aus dem Logfile für diesen Versuch aus (das sollten mehrere Zeilen sein...)?
Mail.err:
Feb 14 11:08:04 GSP-Herkules postfix/sendmail[24861]: fatal: No recipient addresses found in message header
Feb 16 13:50:36 GSP-Herkules postfix/sendmail[4775]: fatal: No recipient addresses found in message header
Feb 18 20:09:56 GSP-Herkules postfix/sendmail[31975]: fatal: No recipient addresses found in message header
Feb 18 20:09:56 GSP-Herkules postfix/sendmail[31978]: fatal: No recipient addresses found in message header
Feb 18 21:44:43 GSP-Herkules postfix/sendmail[9613]: fatal: No recipient addresses found in message header
Mail.log:
Feb 17 20:47:14 GSP-Herkules authdaemond: modules="authmysql", daemons=5
Feb 17 20:47:14 GSP-Herkules authdaemond: Installing libauthmysql
Feb 17 20:47:14 GSP-Herkules authdaemond: Installation complete: authmysql
Feb 17 20:47:15 GSP-Herkules postfix/master[2198]: daemon started -- version 2.3.8, configuration /etc/postfix
Mail.info:
Feb 17 20:46:58 GSP-Herkules amavis[1270]: Perl version               5.008008
lg Felix
Ich habe die Vermutung, dass Dein sendmail-Programm nicht das von Postfix bereitgestellte (binäre) Programm ist, sondern ein Script, das letztendlich das Programm mit einigen Parametern aufruft.
Was ist denn die Ausgabe von
file /usr/lib/sendmail /usr/sbin/sendmail
Hey danke für deine Antwort :)
GSP-Herkules:~# file /usr/lib/sendmail /usr/sbin/sendmail
/usr/lib/sendmail:  symbolic link to `../sbin/sendmail'
/usr/sbin/sendmail: ELF 64-bit LSB executable, AMD x86-64, version 1 (SYSV), for GNU/Linux 2.6.0, dynamically linked (uses shared libs), for GNU/Linux 2.6.0, stripped
lg Felix
