GNU bash, version 3.1.16(1)-release (x86_64-suse-linux)
These shell commands are defined internally. Type `help' to see this list.
Type `help name' to find out more about the function `name'.
Use `info bash' to find out more about the shell in general.
Use `man -k' or `info' to find out more about commands not in this list.
A star (*) next to a name means that the command is disabled.
JOB_SPEC [&] (( expression ))
. filename [arguments] :
[ arg... ] [[ expression ]]
alias [-p] [name[=value] ... ] bg [job_spec ...]
bind [-lpvsPVS] [-m keymap] [-f fi break [n]
builtin [shell-builtin [arg ...]] caller [EXPR]
case WORD in [PATTERN [| PATTERN]. cd [-L|-P] [dir]
command [-pVv] command [arg ...] compgen [-abcdefgjksuv] [-o option
complete [-abcdefgjksuv] [-pr] [-o continue [n]
declare [-afFirtx] [-p] [name[=val dirs [-clpv] [+N] [-N]
disown [-h] [-ar] [jobspec ...] echo [-neE] [arg ...]
enable [-pnds] [-a] [-f filename] eval [arg ...]
exec [-cl] [-a name] file [redirec exit [n]
export [-nf] [name[=value] ...] or false
fc [-e ename] [-nlr] [first] [last fg [job_spec]
for NAME [in WORDS ... ;] do COMMA for (( exp1; exp2; exp3 )); do COM
function NAME { COMMANDS ; } or NA getopts optstring name [arg]
hash [-lr] [-p pathname] [-dt] [na help [-s] [pattern ...]
history [-c] [-d offset] [n] or hi if COMMANDS; then COMMANDS; [ elif
jobs [-lnprs] [jobspec ...] or job kill [-s sigspec | -n signum | -si
let arg [arg ...] local name[=value] ...
logout popd [+N | -N] [-n]
printf [-v var] format [arguments] pushd [dir | +N | -N] [-n]
pwd [-LP] read [-ers] [-u fd] [-t timeout] [
readonly [-af] [name[=value] ...] return [n]
select NAME [in WORDS ... ;] do CO set [--abefhkmnptuvxBCHP] [-o opti
shift [n] shopt [-pqsu] [-o long-option] opt
source filename [arguments] suspend [-f]
test [expr] time [-p] PIPELINE
times trap [-lp] [arg signal_spec ...]
true type [-afptP] name [name ...]
typeset [-afFirtx] [-p] name[=valu ulimit [-SHacdfilmnpqstuvx] [limit
umask [-p] [-S] [mode] unalias [-a] name [name ...]
unset [-f] [-v] [name ...] until COMMANDS; do COMMANDS; done
variables - Some variable names an wait [n]
while COMMANDS; do COMMANDS; done { COMMANDS ; }
find /usr/bin -name php
Dein PHP muss nicht zwingend in /usr/bin liegen...
ein find / -name php oder whereis php sollte aufschluss geben wo das php binary liegt. wurde aber glaube ich schhon oft geschrieben
a) Das ist das PHP von Plesk und nicht das PHP welches Du willst./usr/local/psa/admin/bin/php
d) Welcher User soll denn dieses Script ausführen? Da es das Plesk-PHP ist, darf dies nur root und psaadm tun./usr/local/psa/admin/bin/php: Permission denied
b) Es kann sein, daß PHP-CLI gar nicht installiert ist. Einfach mal im Yast danach suchen.
Nun wieder zurück zum Cronjob, der sehnsüchtig darauf wartet, erstellt zu werden. Die Crontab kann man tatsächlich auch mittels der Console verändern (jaha, das ist gar keine Erfindung von SWSoft!). Also tippen wir mal munterin die triste Console ein. Dem folgt eine Auflistung aller bereits aktiven Cronjobs. Je nachdem, mit welchem User ihr das macht - wahrscheinlich root (ich spare mir alle Sicherheitsbelehrungen an dieser Stelle und schreibe einfach: macht das nicht mit root!) - kommen da einige mehr, oder einige weniger und ihr seid, je nachdem was die Environment-Variable EDITOR sagt, in einem Eurem heiß geliebten Editor.Code:crontab -e
Das ist das eigentliche Problem.ich möchte mich da auch nicht so vertiefen
yastwas muss ich eingeben?
crontab -e -u UserNamewie man es macht wenn man nicht root nutzen soll.
