Power der vServer im Vergleich
Final Score: 0
Na, dann werde ich auch mal:
BYTE UNIX Benchmarks (Version 4.1-wht.1)
System -- Linux xxx.ncsrv.de 2.6.9-023stab044.11-smp #1 SMP Sat Sep 29 13:36:25 MSD 2007 i686 GNU/Linux
vzfs                   4718592   3379740   1338852  72% /
Start Benchmark Run: Di 6. Nov 12:42:24 CET 2007
 12:42:24 up 11:23,  2 users,  load average: 0.64, 0.98, 0.91
End Benchmark Run: Di 6. Nov 12:43:22 CET 2007
 12:43:22 up 11:24,  2 users,  load average: 0.39, 0.84, 0.87
                     INDEX VALUES
TEST                                        BASELINE     RESULT      INDEX
Dhrystone 2 using register variables        376783,0        0,0        0,0
Double-Precision Whetstone                      83,0        0,0        0,0
Execl Throughput                               188,0        0,0        0,0
Pipe-based Context Switching                 15448,0        0,0        0,0
Pipe Throughput                             111814,0        0,0        0,0
Process Creation                               569,0        0,0        0,0
Shell Scripts (8 concurrent)                    44,0        0,0        0,0
System Call Overhead                        114433,0        0,0        0,0
     FINAL SCORE
:) Das entspricht nicht ganz der gefühlten Performance. Was könnte da los sein?
# cat /proc/user_beancounters |sed -e 's/uid//g' -e 's/$($UIDNUM)\://g' -e 's/numpty/numpty./g'|awk '{print " "$1"\t""\t""\t"$4"\t""\t"$5}'|grep -v dummy
 Version:
 resource                       barrier         limit
 kmemsize                       12582912      14680064
 lockedpages                    344             344
 privvmpages                    65536           67072
 shmpages                       19567           19567
 numproc                        128             128
 physpages                      0               2147483647
 vmguarpages                    24576           2147483647
 oomguarpages                   24576           2147483647
 numtcpsock                     128             128
 numflock                       224             246
 numpty                         16              16
 numsiginfo                     256             256
 tcpsndbuf                      1416560         2768240
 tcprcvbuf                      1416560         2768240
 othersockbuf                   655717          1153621
 dgramrcvbuf                    132096          132096
 numothersock                   128             128
 dcachesize                     3002127         3032191
 numfile                        2500            2500
 numiptent                      64              64
/vpsmem
 ----- VPS Speichernutzung ----      ---- Hardware Node Memory ----
 [XXXXXXXXXXXXXXXXXXXXX=======]      Total:                 7950 MB
 Momentan:         72% Barriere      Frei:                   866 MB
 Fehlversuche:       320 Fehler      Buffers:                603 MB
 ------------------------------      Cached:                2521 MB
 Momentan genutzt:       185 MB      ------- +/- buff/cache -------
 Maximal  genutzt:       185 MB      Used:                  4008 MB
 Barriere:               256 MB      Free:                  3942 MB
 Limit:                  262 MB      ------------ Swap ------------
 ------------------------------      Total Swap:           10001 MB
 Zugesichert:             96 MB      Free  Swap:            9995 MB
# vzfree
VPS Speichernutzung:
Momentan genutzt:       184,422 MB
Zugesichert:            96 MB
Maximal nutzbar:        262 MB
Pretago: go_serv_one
Ich habe massive Probleme mit privvmpages, lockedpages und vor allem numfiles.
Hier laufen apache 1.3.x, postfix, mysql und ein paar kleinere Dienste wie munin-node, portmap, atop, cron etc.
Was verursacht denn lockedpages? Ich habe hier schon beancounters gesehen mit lockedpages 0.
UBC auxiliary parameters - OpenVZ Wiki
Das hilft mir auch nicht weiter. man mlock ebenso wenig.
Gibt es so etwas wie lsof für numfile, das den zugreifenden Prozess der lockedpages anzeigt?
Hmmm...
# time
real    0m0.000s
user    0m0.001s
sys     0m0.000s
# apt-cache policy time
time:
  Installed: (none)
  Candidate: 1.7-21
  Version table:
     1.7-21 0
        500 http://ftp.de.debian.org stable/main Packages
pv10:/home/gerhard# apt-cache show time|grep -A1 Description\:
Description: The GNU time program for measuring cpu resource usage
 The `time' command runs another program, then displays information
# dpkg -S "time"|egrep "\/time\$"
tclx8.3: /usr/lib/tclX8.3/help/tcl/time/time
# bash -c "help time"
time: time [-p] PIPELINE
     Execute PIPELINE and print a summary of the real time, user CPU time,
    and system CPU time spent executing PIPELINE when it terminates.
    The return status is the return status of PIPELINE.  The `-p' option
    prints the timing summary in a slightly different format.  This uses
    the value of the TIMEFORMAT variable as the output format.
times: times
     Print the accumulated user and system times for processes run from
    the shell.
Also, doch:
# aptitude install time
The following NEW packages will be installed:
  time
Setting up time (1.7-21) ...
vzfs                   4718592   3337807   1380785  71% /
Start Benchmark Run: Mi 7. Nov 01:40:21 CET 2007
 01:40:21 up 25 min,  1 user,  load average: 1.29, 0.95, 0.81
End Benchmark Run: Mi 7. Nov 01:58:28 CET 2007
 01:58:28 up 43 min,  1 user,  load average: 12.21, 7.39, 4.73
                     INDEX VALUES
Dhrystone 2 using register variables        376783,0   923098,9       24,5
Double-Precision Whetstone                      83,0     1265,9      152,5
Execl Throughput                               188,0      517,2       27,5
File Copy 1024 bufsize 2000 maxblocks         2672,0    14404,0       53,9
File Copy 256 bufsize 500 maxblocks           1077,0     4282,0       39,8
File Read 4096 bufsize 8000 maxblocks        15382,0    97137,0       63,1
Pipe-based Context Switching                 15448,0    35696,8       23,1
Pipe Throughput                             111814,0   112237,6       10,0
Process Creation                               569,0     1533,7       27,0
Shell Scripts (8 concurrent)                    44,0       80,0       18,2
System Call Overhead                        114433,0    87459,2        7,6
     FINAL SCORE                                                      29,0
Naja...
Weist Du etwas zu den lockedpages?
Ich habe nun nochmals den benchmark und alles wiederholt nach einem
 invoke-rc.d mysql stop
 invoke-rc.d postfix stop
 invoke-rc.d apache stop
bin/vpsmem
 [XX==========================]      Total:                 7950 MB
 Momentan:         8% Barriere      Frei:                   772 MB
 Fehlversuche:     13870 Fehler      Buffers:                692 MB
 ------------------------------      Cached:                2585 MB
 Momentan genutzt:        22 MB      ------- +/- buff/cache -------
 Maximal  genutzt:        22 MB      Used:                  3900 MB
 Barriere:               256 MB      Free:                  4050 MB
Version: 2.5
       uid  resource                     held              maxheld              barrier                limit              failcnt
     54546: kmemsize                  1876190              1891811             12582912             14680064                    0
            lockedpages                   256                  256                  344                  344                  196
            privvmpages                  5470                 5521                65536                67072                13870
            shmpages                     1281                 1281                19567                19567                    0
            dummy                           0                    0                    0                    0                    0
            numproc                        19                   19                  128                  128                    0
            physpages                    3179                 3179                    0           2147483647                    0
            vmguarpages                     0                    0                24576           2147483647                    0
            oomguarpages                 3179                 3179                24576           2147483647                    0
            numtcpsock                      4                    4                  128                  128                    0
            numflock                        2                    2                  224                  246                    0
            numpty                          2                    2                   16                   16                    0
            numsiginfo                      0                    0                  256                  256                    0
            tcpsndbuf                   44536                44536              1416560              2768240                    0
            tcprcvbuf                   65536                65536              1416560              2768240                    0
            othersockbuf                 2344                 2344               655717              1153621                    0
            dgramrcvbuf                     0                    0               132096               132096                 3517
            numothersock                    8                    8                  128                  128                   71
            dcachesize                      0                    0              3002127              3032191                    0
            numfile                       769                  769                 2500                 2500                46606
            dummy                           0                    0                    0                    0                    0
            dummy                           0                    0                    0                    0                    0
            dummy                           0                    0                    0                    0                    0
            numiptent                      14                   14                   64                   64                    0
vzfs                   4718592   3348862   1369730  71% /
Start Benchmark Run: Mi 7. Nov 12:04:20 CET 2007
 12:04:20 up 10:49,  2 users,  load average: 0.90, 1.15, 0.83
End Benchmark Run: Mi 7. Nov 12:24:52 CET 2007
 12:24:52 up 11:10,  2 users,  load average: 11.46, 6.98, 4.73
                     INDEX VALUES
Dhrystone 2 using register variables        376783,0  1179342,7       31,3
Double-Precision Whetstone                      83,0     1203,2      145,0
Execl Throughput                               188,0      496,9       26,4
File Copy 1024 bufsize 2000 maxblocks         2672,0    15097,0       56,5
File Copy 256 bufsize 500 maxblocks           1077,0     3979,0       36,9
File Read 4096 bufsize 8000 maxblocks        15382,0   135841,0       88,3
Pipe-based Context Switching                 15448,0    37551,4       24,3
Pipe Throughput                             111814,0   109443,3        9,8
Process Creation                               569,0     1110,4       19,5
Shell Scripts (8 concurrent)                    44,0       64,0       14,5
System Call Overhead                        114433,0   110069,3        9,6
     FINAL SCORE                                                      29,4
Der FINAL SCORE ist mit 29,4 nur unwesentlich höher als vorher.
EDIT:
cat /proc/meminfo
MemTotal: 8140556 kB
MemFree: 1089412 kB
Buffers: 370828 kB
Cached: 2708256 kB
SwapCached: 96 kB
Active: 4855920 kB
Inactive: 1157504 kB
HighTotal: 0 kB
HighFree: 0 kB
LowTotal: 8140556 kB
LowFree: 1089412 kB
SwapTotal: 10241428 kB
SwapFree: 10233972 kB
Dirty: 482924 kB
Writeback: 0 kB
Mapped: 3857104 kB
Slab: 612924 kB
CommitLimit: 14311704 kB
Committed_AS: 164340948 kB
PageTables: 81460 kB
VmallocTotal: 536870908 kB
VmallocUsed: 330068 kB
VmallocChunk: 536540040 kB
Basis-vServer - vSell
System -- Linux vadminX 2.6.18-xen #2 SMP Wed Oct 24 02:00:20 CEST 2007 x86_64 GNU/Linux
/dev/hda1              7478760   1993648   5105208  29% /
Start Benchmark Run: Sat Nov 10 01:27:10 CET 2007
 01:27:10 up 8 days, 23:32,  2 users,  load average: 0.00, 0.00, 0.00
End Benchmark Run: Sat Nov 10 01:38:46 CET 2007
 01:38:46 up 8 days, 23:44,  2 users,  load average: 15.87, 6.90, 3.12
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  7495131.7      198.9
Double-Precision Whetstone                      83.1     2556.7      307.7
Execl Throughput                               188.3     2083.5      110.6
File Copy 1024 bufsize 2000 maxblocks         2672.0    49812.0      186.4
File Copy 256 bufsize 500 maxblocks           1077.0    15205.0      141.2
File Read 4096 bufsize 8000 maxblocks        15382.0   384987.0      250.3
Pipe Throughput                             111814.6   357078.2       31.9
Pipe-based Context Switching                 15448.6    98438.7       63.7
Process Creation                               569.3     4577.1       80.4
Shell Scripts (8 concurrent)                    44.8      550.7      122.9
System Call Overhead                        114433.5   324255.6       28.3
     FINAL SCORE                                                     108.9
Webserver/Mailserver/MySQL wurden dabei nicht beendet
# cat meminfo
MemTotal:       204984 kB
MemFree:         35656 kB
Buffers:         12600 kB
Cached:          51892 kB
SwapCached:       3404 kB
Active:          65036 kB
Inactive:        28348 kB
HighTotal:           0 kB
HighFree:            0 kB
LowTotal:       204984 kB
LowFree:         35656 kB
SwapTotal:      255992 kB
SwapFree:       235520 kB
Dirty:               0 kB
Writeback:           0 kB
AnonPages:       28528 kB
Mapped:          13396 kB
Slab:            59928 kB
PageTables:       3228 kB
NFS_Unstable:        0 kB
Bounce:              0 kB
CommitLimit:    358484 kB
Committed_AS:   338916 kB
VmallocTotal: 34359738367 kB
VmallocUsed:       352 kB
VmallocChunk: 34359738015 kB
Root-Server DS 3000 (Hetzner); 49,99€/Monat
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  5844675.8      155.1
Double-Precision Whetstone                      83.1     1766.1      212.5
Execl Throughput                               188.3     3947.2      209.6
File Copy 1024 bufsize 2000 maxblocks         2672.0    60668.0      227.1
File Copy 256 bufsize 500 maxblocks           1077.0    15048.0      139.7
File Read 4096 bufsize 8000 maxblocks        15382.0   366817.0      238.5
Pipe-based Context Switching                 15448.6   157275.9      101.8
Pipe Throughput                             111814.6   395848.5       35.4
Process Creation                               569.3    11430.0      200.8
Shell Scripts (8 concurrent)                    44.8      578.7      129.2
System Call Overhead                        114433.5  1282351.8      112.1
     FINAL SCORE                                                     143.9
vServer VPS Start (United Hoster); 9,95€/Monat
 INDEX VALUES
Dhrystone 2 using register variables        376783.7  5162653.0      137.0
Double-Precision Whetstone                      83.1     1656.6      199.4
Execl Throughput                               188.3     1510.1       80.2
File Copy 1024 bufsize 2000 maxblocks         2672.0    18542.0       69.4
File Copy 256 bufsize 500 maxblocks           1077.0     6283.0       58.3
File Read 4096 bufsize 8000 maxblocks        15382.0   139592.0       90.8
Pipe Throughput                             111814.6   182344.5       16.3
Pipe-based Context Switching                 15448.6    59000.2       38.2
Process Creation                               569.3     4651.4       81.7
Shell Scripts (8 concurrent)                    44.8      283.7       63.3
System Call Overhead                        114433.5   250081.9       21.9
     FINAL SCORE                                                      62.5
Hallo, zwar nicht ganz objektiv (da ein Freund von mir die Firma betreibt) aber dennoch erwähnenswert meine ich. Der Benchmark ist von einem VPS Testsystem das er mir mal zur Verfügung gestellt hat, das aber bei weitem nicht die Leistungsdaten hatte wie seine aktuellen Server.
9,-- Euro/Monat 30GB Hdd
Carrot Server :: virtual Server :: virtuelles Server Hosting zu Studentenpreisen
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  6964462.7      184.8
Double-Precision Whetstone                      83.1     1830.9      220.3
Execl Throughput                               188.3     3448.2      183.1
File Copy 1024 bufsize 2000 maxblocks         2672.0    75773.0      283.6
File Copy 256 bufsize 500 maxblocks           1077.0    23868.0      221.6
File Read 4096 bufsize 8000 maxblocks        15382.0   462385.0      300.6
Pipe Throughput                             111814.6   697523.6       62.4
Pipe-based Context Switching                 15448.6   239159.0      154.8
Process Creation                               569.3     9513.9      167.1
Shell Scripts (8 concurrent)                    44.8      629.2      140.4
System Call Overhead                        114433.5   920893.5       80.5
     FINAL SCORE                                                     165.6
root@carrot-test:~/unixbench-4.1.0-wht-1#
Hallo, Hier die Werte für den aktuellen Carrot Server C30 für 9 EURO:
Start Benchmark Run: Mon Dec 17 10:56:07 UTC 2007
 10:56:07 up  1:59,  1 user,  load average: 0.14, 0.07, 0.02
End Benchmark Run: Mon Dec 17 11:06:57 UTC 2007
 11:06:57 up  2:10,  1 user,  load average: 13.02, 5.66, 2.54
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7 18717833.2      496.8
Double-Precision Whetstone                      83.1     2542.3      305.9
Execl Throughput                               188.3     6275.5      333.3
File Copy 1024 bufsize 2000 maxblocks         2672.0   141084.0      528.0
File Copy 256 bufsize 500 maxblocks           1077.0    44405.0      412.3
File Read 4096 bufsize 8000 maxblocks        15382.0   974597.0      633.6
Pipe Throughput                             111814.6  1666067.2      149.0
Pipe-based Context Switching                 15448.6   444389.8      287.7
Process Creation                               569.3    16591.3      291.4
Shell Scripts (8 concurrent)                    44.8     1847.4      412.4
System Call Overhead                        114433.5  2434115.5      212.7
     FINAL SCORE                                                     342.7
und hier vpsmem:
 [----------------------------]      Total:                 2282 MB
 Momentan:          0% Barriere      Frei:                  2273 MB
 Fehlversuche:         0 Fehler      Buffers:                  0 MB
 ------------------------------      Cached:                   0 MB
 Momentan genutzt:         9 MB      ------- +/- buff/cache -------
 Maximal  genutzt:       217 MB      Used:                     9 MB
 Barriere:              2282 MB      Free:                  2273 MB
 Limit:                 2511 MB      ------------ Swap ------------
 ------------------------------      Total Swap:               0 MB
 Zugesichert:            380 MB      Free  Swap:               0 MB
Läuft wirklich gut, muss er aber auch mit den Werten. Und der Preis stimmt.
Mein VPS Start (8,95 E/mon) bei United-Hoster hat doch etwas mehr Saft als der meiner Vorposter oO
                     INDEX VALUES
Dhrystone 2 using register variables        376783,0  9673962,6      256,8
Double-Precision Whetstone                      83,0     1668,6      201,0
Execl Throughput                               188,0     1775,5       94,4
File Copy 1024 bufsize 2000 maxblocks         2672,0    37136,0      139,0
File Copy 256 bufsize 500 maxblocks           1077,0     7911,0       73,5
File Read 4096 bufsize 8000 maxblocks        15382,0   233645,0      151,9
Pipe-based Context Switching                 15448,0    96946,3       62,8
Pipe Throughput                             111814,0   264603,0       23,7
Process Creation                               569,0     7383,6      129,8
Shell Scripts (8 concurrent)                    44,0      419,0       95,2
System Call Overhead                        114433,0   449893,4       39,3
     FINAL SCORE                                                      94,6
naja, meiner ist auch gut Ausgelastet ;-)
ca. 800-1300 TS-User
ca. 400-460 Vent-User
und dazu nochmal ein paar aufwendige IRC-Bots, des bremst schon bissal aus *g, dennoch bin ich mit diesem erziehlten wert ganz zufrieden.
Äh, weil es soviel Spaß gemacht hat, habe ich mal (fast) alle Kisten die ich in die Griffel bekommen konnte gebenchmarkt :o
Ich fange mal mit dem Virtual-Server XXL von 1&1 an:
Start Benchmark Run: Tue Mar  4 20:02:33 CET 2008
 20:02:33 up 48 days, 21:09,  1 user,  load average: 0.41, 0.17, 0.06
End Benchmark Run: Tue Mar  4 20:14:39 CET 2008
 20:14:39 up 48 days, 21:21,  1 user,  load average: 14.79, 7.33, 3.68
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  3833113.2      101.7
Double-Precision Whetstone                      83.1     1699.3      204.5
Execl Throughput                               188.3     1718.0       91.2
File Copy 1024 bufsize 2000 maxblocks         2672.0    40641.0      152.1
File Copy 256 bufsize 500 maxblocks           1077.0    10490.0       97.4
File Read 4096 bufsize 8000 maxblocks        15382.0   252542.0      164.2
Pipe-based Context Switching                 15448.6   150691.7       97.5
Pipe Throughput                             111814.6   543614.6       48.6
Process Creation                               569.3     4278.6       75.2
Shell Scripts (8 concurrent)                    44.8      247.9       55.3
System Call Overhead                        114433.5   661026.3       57.8
     FINAL SCORE                                                      94.3
Dann, aus Interesse, wollte ich mal wissen, wie es meinem DS5000 bei Hetzner geht :)
Start Benchmark Run: Di 4. Mär 19:46:01 CET 2008
 19:46:01 up 65 days, 21:17,  1 user,  load average: 0.05, 0.05, 0.01
End Benchmark Run: Di 4. Mär 19:56:20 CET 2008
 19:56:20 up 65 days, 21:27,  2 users,  load average: 14.17, 6.22, 2.74
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7 19734429.9      523.8
Double-Precision Whetstone                      83.1     2718.6      327.1
Execl Throughput                               188.3     7651.0      406.3
File Copy 1024 bufsize 2000 maxblocks         2672.0   140465.0      525.7
File Copy 256 bufsize 500 maxblocks           1077.0    46038.0      427.5
File Read 4096 bufsize 8000 maxblocks        15382.0   977817.0      635.7
Pipe-based Context Switching                 15448.6   479722.4      310.5
Pipe Throughput                             111814.6  1810571.3      161.9
Process Creation                               569.3    19139.1      336.2
Shell Scripts (8 concurrent)                    44.8     1248.4      278.7
System Call Overhead                        114433.5  3156877.7      275.9
     FINAL SCORE                                                     359.4
Dann hab ich einen HP ProLiant Pizza-Schachtel-Server mit zwei 2 GHz Xeons hergenommen:
Start Benchmark Run: Di 4. Mär 20:04:57 CET 2008
 20:04:57 up 48 days,  9:38,  1 user,  load average: 0.08, 0.03, 0.00
End Benchmark Run: Di 4. Mär 20:15:30 CET 2008
 20:15:30 up 48 days,  9:49,  1 user,  load average: 11.55, 5.46, 2.50
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7 21503646.7      570.7
Double-Precision Whetstone                      83.1     1815.3      218.4
Execl Throughput                               188.3     7247.5      384.9
File Copy 1024 bufsize 2000 maxblocks         2672.0   171029.0      640.1
File Copy 256 bufsize 500 maxblocks           1077.0    59276.0      550.4
File Read 4096 bufsize 8000 maxblocks        15382.0   869167.0      565.1
Pipe-based Context Switching                 15448.6   597129.7      386.5
Pipe Throughput                             111814.6  2177216.8      194.7
Process Creation                               569.3    21956.3      385.7
Shell Scripts (8 concurrent)                    44.8     1223.6      273.1
System Call Overhead                        114433.5  2749563.5      240.3
     FINAL SCORE                                                     370.8
Und zum Abschluß - sorry, für die vielen Off-Topic-Teile, es geht ja eigentlich um VPSe - noch einen alten IBM-Server mit einer einzelnen CPU, 1 GHz, Pentium III:
Start Benchmark Run: Di 4. Mär 20:20:37 CET 2008
 20:20:37 up 104 days,  5:16,  1 user,  load average: 0.61, 0.29, 0.11
End Benchmark Run: Di 4. Mär 20:32:19 CET 2008
 20:32:19 up 104 days,  5:28,  1 user,  load average: 13.16, 6.08, 2.87
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  2195882.9       58.3
Double-Precision Whetstone                      83.1      743.0       89.4
Execl Throughput                               188.3     1383.6       73.5
File Copy 1024 bufsize 2000 maxblocks         2672.0    22806.0       85.4
File Copy 256 bufsize 500 maxblocks           1077.0     9463.0       87.9
File Read 4096 bufsize 8000 maxblocks        15382.0   121084.0       78.7
Pipe-based Context Switching                 15448.6   137740.1       89.2
Pipe Throughput                             111814.6   374186.2       33.5
Process Creation                               569.3     6776.5      119.0
Shell Scripts (8 concurrent)                    44.8      190.8       42.6
System Call Overhead                        114433.5   878202.7       76.7
     FINAL SCORE                                                      71.8
Alle Benchmarks liefen unter Debian 4.0.
Schönen Feierabend :D
vsell.de
Habe mal einen Demo-Server von vsell.de für einen Testdurchlauf benutzt:
System -- Linux vadmin3 2.6.18-xen #2 SMP Fri Aug 24 17:06:53 CEST 2007 x86_64 GNU/Linux
/dev/hda1              7478760    786292   6312564  12% /
Start Benchmark Run: Thu Mar  6 14:21:27 CET 2008
 14:21:27 up 11 min,  1 user,  load average: 0.62, 0.83, 0.48
End Benchmark Run: Thu Mar  6 14:33:25 CET 2008
 14:33:25 up 23 min,  1 user,  load average: 14.76, 6.62, 3.24
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  6784264.8      180.1
Double-Precision Whetstone                      83.1     2383.2      286.8
Execl Throughput                               188.3     1933.2      102.7
File Copy 1024 bufsize 2000 maxblocks         2672.0    45730.0      171.1
File Copy 256 bufsize 500 maxblocks           1077.0    13490.0      125.3
File Read 4096 bufsize 8000 maxblocks        15382.0   275484.0      179.1
Pipe Throughput                             111814.6   301904.4       27.0
Pipe-based Context Switching                 15448.6    83814.7       54.3
Process Creation                               569.3     4038.4       70.9
Shell Scripts (8 concurrent)                    44.8      475.8      106.2
System Call Overhead                        114433.5   286143.0       25.0
     FINAL SCORE                                                      94.9
Installiert war ein jungfräuliches Debian 4.0 minimal. Laut /proc/cpuinfo war das ein AMD Athlon64 X2 Dual Core 5600+.
das habe ich auch gemacht und hatte gleiche Ergebnisse. (96.7 auf einem Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz)
Dann habe ich mal 100MB RAM dazugebucht und das hat bei Debian32Bit ein Endergebnis von 115.2 gebracht, obwohl schon Confixx, apache und alles was dazugehört lief)
Gruß Fritz
[Edit] der nächste, den ich gebucht habe, ist auf einem neuen Host gelandet mit Athlon(tm) 64 X2 Dual Core Processor 5600+
der bringt schon mit 200MB RAM und Ubuntu64Bit 109.6 Punkte....naja, nun genug gespielt ;)
Habe mich inzwischen für einen vServer von vsell.de als "Backup-Server" entschieden, im Gegensatz zu dem Rechner auf dem der Demo-Zugang lief ist der auf dem ich gelandet bin ein AMD Athlon 64 X2 Dual Core Processor 6000+. Hier das Ergebnis:
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  7303204.3      193.8
Double-Precision Whetstone                      83.1     2538.0      305.4
Execl Throughput                               188.3     2174.4      115.5
File Copy 1024 bufsize 2000 maxblocks         2672.0    50402.0      188.6
File Copy 256 bufsize 500 maxblocks           1077.0    14758.0      137.0
File Read 4096 bufsize 8000 maxblocks        15382.0   362020.0      235.4
Pipe-based Context Switching                 15448.6    93258.0       60.4
Pipe Throughput                             111814.6   327950.7       29.3
Process Creation                               569.3     4569.5       80.3
Shell Scripts (8 concurrent)                    44.8      475.4      106.1
System Call Overhead                        114433.5   314819.3       27.5
     FINAL SCORE                                                     105.1
Keyweb RootDS Premium:
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  9275235.4      246.2
Double-Precision Whetstone                      83.1     1946.5      234.2
Execl Throughput                               188.3     2523.8      134.0
File Copy 1024 bufsize 2000 maxblocks         2672.0    55230.0      206.7
File Copy 256 bufsize 500 maxblocks           1077.0    17239.0      160.1
File Read 4096 bufsize 8000 maxblocks        15382.0   415190.0      269.9
Pipe Throughput                             111814.6   746859.7       66.8
Pipe-based Context Switching                 15448.6   221337.9      143.3
Process Creation                               569.3     7907.8      138.9
Shell Scripts (8 concurrent)                    44.8      620.8      138.6
System Call Overhead                        114433.5   693611.6       60.6
     FINAL SCORE                                                     148.4
VPSmem Info:
 Momentan:         36% Barriere      Frei:                   494 MB
 Fehlversuche:         0 Fehler      Buffers:                101 MB
 ------------------------------      Cached:                2534 MB
 Momentan genutzt:       366 MB      ------- +/- buff/cache -------
 Maximal  genutzt:       367 MB      Used:                   635 MB
 Barriere:              1024 MB      Free:                  3129 MB
 Limit:                 1028 MB      ------------ Swap ------------
 ------------------------------      Total Swap:            8197 MB
 Zugesichert:           2048 MB      Free  Swap:            8197 MB
Es läuft drauf: Plesk 8.3.0
INDEX VALUES
Dhrystone 2 using register variables        376783.7  7415606.3      196.8
Double-Precision Whetstone                      83.1     1848.2      222.4
Execl Throughput                               188.3     2331.6      123.8
File Copy 1024 bufsize 2000 maxblocks         2672.0    67838.0      253.9
File Copy 256 bufsize 500 maxblocks           1077.0    18160.0      168.6
File Read 4096 bufsize 8000 maxblocks        15382.0   444096.0      288.7
Pipe Throughput                             111814.6   360114.9       32.2
Pipe-based Context Switching                 15448.6   104496.8       67.6
Process Creation                               569.3     5254.6       92.3
Shell Scripts (8 concurrent)                    44.8      575.7      128.5
System Call Overhead                        114433.5   283124.5       24.7
     FINAL SCORE                                                     114.1
Ist ein VServer von Domain-Offensive.de
Besonders der Standpunkt ist gut ;-)
MOD : Bilder bitte immer als Anhang. Danke.
1&1 Vserver L:
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  4682321.2      124.3
Double-Precision Whetstone                      83.1     2281.7      274.6
Execl Throughput                               188.3        1.0        0.1
File Copy 1024 bufsize 2000 maxblocks         2672.0    26975.0      101.0
File Copy 256 bufsize 500 maxblocks           1077.0     8200.0       76.1
File Read 4096 bufsize 8000 maxblocks        15382.0   188514.0      122.6
Pipe Throughput                             111814.6   475722.8       42.5
Pipe-based Context Switching                 15448.6   102474.3       66.3
Process Creation                               569.3     3015.7       53.0
Shell Scripts (8 concurrent)                    44.8      211.6       47.2
System Call Overhead                        114433.5   873282.5       76.3
     FINAL SCORE                                                      43.0
Schneider-Consulting
Vserver: v-Srv02
System -- Linux vadmin541 2.6.20-xen-r6 #2 SMP Tue Mar 11 21:58:58 CET 2008 x86_64 GNU/Linux
/dev/hda1             23512956   1462980  20855584   7% /
Start Benchmark Run: So 6. Apr 12:16:25 CEST 2008
 12:16:25 up 20:07,  1 user,  load average: 0.01, 0.10, 0.06
End Benchmark Run: So 6. Apr 12:27:46 CEST 2008
 12:27:46 up 20:18,  1 user,  load average: 16.97, 6.86, 3.06
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7 12795404.8      339.6
Double-Precision Whetstone                      83.1     2166.6      260.7
Execl Throughput                               188.3     2030.7      107.8
File Copy 1024 bufsize 2000 maxblocks         2672.0    72846.0      272.6
File Copy 256 bufsize 500 maxblocks           1077.0    22102.0      205.2
File Read 4096 bufsize 8000 maxblocks        15382.0   475572.0      309.2
Pipe-based Context Switching                 15448.6   124391.7       80.5
Pipe Throughput                             111814.6   472650.7       42.3
Process Creation                               569.3     4368.9       76.7
Shell Scripts (8 concurrent)                    44.8      477.8      106.7
System Call Overhead                        114433.5   399445.8       34.9
     FINAL SCORE                                                     128.7
