Power der vServer im Vergleich
United-Hoster Linux VPS Start
                     INDEX VALUES
TEST                                        BASELINE     RESULT      INDEX
Dhrystone 2 using register variables        376783,0  4528699,7      120,2
Double-Precision Whetstone                      83,0     1410,2      169,9
Execl Throughput                               188,0     2347,3      124,9
File Copy 1024 bufsize 2000 maxblocks         2672,0    42974,0      160,8
File Copy 256 bufsize 500 maxblocks           1077,0    11635,0      108,0
File Read 4096 bufsize 8000 maxblocks        15382,0   403880,0      262,6
Pipe-based Context Switching                 15448,0    93895,7       60,8
Pipe Throughput                             111814,0   204688,4       18,3
Process Creation                               569,0     8830,0      155,2
Shell Scripts (8 concurrent)                    44,0      520,0      118,2
System Call Overhead                        114433,0   292651,6       25,6
     FINAL SCORE                                                      95,6
Erst mein Homerouter mit PIII-1000EB, 512MB ECC, 2x40GB, 1x80GB HDD
BYTE UNIX Benchmarks (Version 4.1-wht.2)
System -- Linux redlinux 2.4.37 #2 Die Mär 10 22:54:09 CET 2009 i686 i686 i386 GNU/Linux
/dev/hda3             37418388  15812328  19705276  45% /
Start Benchmark Run: Sam Mär 28 14:23:41 CET 2009
 14:23:41 up 16:01,  1 user,  load average: 0.06, 0.07, 0.01
End Benchmark Run: Sam Mär 28 14:34:59 CET 2009
 14:34:59 up 16:12,  1 user,  load average: 14.67, 6.24, 2.84
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  1418159.6       37.6
Double-Precision Whetstone                      83.1      435.7       52.4
Execl Throughput                               188.3     2583.1      137.2
File Copy 1024 bufsize 2000 maxblocks         2672.0    24127.0       90.3
File Copy 256 bufsize 500 maxblocks           1077.0     9195.0       85.4
File Read 4096 bufsize 8000 maxblocks        15382.0   136688.0       88.9
Pipe-based Context Switching                 15448.6   237287.6      153.6
Pipe Throughput                             111814.6   559102.8       50.0
Process Creation                               569.3     7804.0      137.1
Shell Scripts (8 concurrent)                    44.8      259.9       58.0
System Call Overhead                        114433.5   520316.6       45.5
     FINAL SCORE                                                      76.4
Nun ein vServer 1536 von netcup
System -- Linux xxxxxxxx.yourvserver.net 2.6.26-1-vserver-amd64 #1 SMP Sat Jan 17 17:17:17 UTC 2009 x86_64 GNU/Linux
/dev/hdv1             30720000    982776  28177224   4% /
Start Benchmark Run: Sa 28. Mär 14:46:17 CET 2009
 14:46:17 up 6 days, 15:24,  1 user,  load average: 0.03, 0.02, 0.00
End Benchmark Run: Sa 28. Mär 14:57:02 CET 2009
 14:57:02 up 6 days, 15:35,  1 user,  load average: 12.54, 5.33, 2.47
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  7708455.3      204.6
Double-Precision Whetstone                      83.1     1612.5      194.0
Execl Throughput                               188.3     5656.7      300.4
File Copy 1024 bufsize 2000 maxblocks         2672.0   100996.0      378.0
File Copy 256 bufsize 500 maxblocks           1077.0    29811.0      276.8
File Read 4096 bufsize 8000 maxblocks        15382.0   753021.0      489.5
Pipe-based Context Switching                 15448.6   115316.0       74.6
Pipe Throughput                             111814.6  1149816.6      102.8
Process Creation                               569.3     9908.4      174.0
Shell Scripts (8 concurrent)                    44.8      933.3      208.3
System Call Overhead                        114433.5  2211573.7      193.3
     FINAL SCORE                                                     208.8
Das ist doch ganz ordentlich :D Lob!
FileMedia
File Media, Super Server !
Ich habe schon viele Server ausprobiert aber das ist der Beste !
Dhrystone 2 using register variables 376783.7 17405290.3 461.9
Double-Precision Whetstone 83.1 1304.3 157.0
Execl Throughput 188.3 6950.8 369.1
File Copy 1024 bufsize 2000 maxblocks 2672.0 170210.0 637.0
File Copy 256 bufsize 500 maxblocks 1077.0 58589.0 544.0
File Read 4096 bufsize 8000 maxblocks 15382.0 1302919.0 847.0
Pipe Throughput 111814.6 1418025.6 126.8
Pipe-based Context Switching 15448.6 361417.9 233.9
Process Creation 569.3 16337.9 287.0
Shell Scripts (8 concurrent) 44.8 1860.8 415.4
System Call Overhead 114433.5 1114037.6 97.4
FINAL SCORE 311.8
Ich habe mir grade einen Server Bestellt. :)
Elk vServer Upgrade 1 von HKN
System -- Linux ********** 2.6.18.8-xenU #3 SMP Wed Aug 6 12:23:02 BST 2008 x86_64 GNU/Linux
/dev/xvda2            41922560   3270848  38651712   8% /
Start Benchmark Run: Sat May 30 08:31:22 CEST 2009
 08:31:22 up 22:25,  1 user,  load average: 0.40, 0.22, 0.08
End Benchmark Run: Sat May 30 08:43:17 CEST 2009
 08:43:17 up 22:37,  1 user,  load average: 16.85, 6.99, 3.16
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  3676894.3       97.6
Double-Precision Whetstone                      83.1     1147.9      138.1
Execl Throughput                               188.3     1586.0       84.2
File Copy 1024 bufsize 2000 maxblocks         2672.0    52285.0      195.7
File Copy 256 bufsize 500 maxblocks           1077.0    15322.0      142.3
File Read 4096 bufsize 8000 maxblocks        15382.0   284757.0      185.1
Pipe Throughput                             111814.6   327257.6       29.3
Pipe-based Context Switching                 15448.6    97824.0       63.3
Process Creation                               569.3     4508.7       79.2
Shell Scripts (8 concurrent)                    44.8      158.9       35.5
System Call Overhead                        114433.5   192540.8       16.8
     FINAL SCORE                                                      76.3
DJW-Hosting, XEN, vServer3
Start Benchmark Run: Sat May 30 11:25:36 CEST 2009
 11:25:36 up 3 days, 20:20,  1 user,  load average: 0.29, 0.10, 0.03
End Benchmark Run: Sat May 30 11:36:59 CEST 2009
 11:36:59 up 3 days, 20:31,  1 user,  load average: 18.41, 8.27, 3.86
                     INDEX VALUES
Dhrystone 2 using register variables        376783.7  4699564.9      124.7
Double-Precision Whetstone                      83.1     1167.9      140.5
Execl Throughput                               188.3     2288.8      121.6
File Copy 1024 bufsize 2000 maxblocks         2672.0    63851.0      239.0
File Copy 256 bufsize 500 maxblocks           1077.0    18366.0      170.5
File Read 4096 bufsize 8000 maxblocks        15382.0   439017.0      285.4
Pipe Throughput                             111814.6   371380.7       33.2
Pipe-based Context Switching                 15448.6   102910.1       66.6
Process Creation                               569.3     5074.9       89.1
Shell Scripts (8 concurrent)                    44.8      591.8      132.1
System Call Overhead                        114433.5   278887.1       24.4
     FINAL SCORE                                                     104.2
Da sich über die Jahre vieles in diesem Bereich geändert hat, erlaube ich mir mal den Thread auszugraben.
V-Server XS ip-projects.de
1 CPU in system; running 1 parallel copy of tests
Dhrystone 2 using register variables       36918704.9 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                     4087.0 MWIPS (9.9 s, 7 samples)
Execl Throughput                               2366.6 lps   (29.9 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        391840.3 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks          100645.0 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks       1153527.2 KBps  (30.0 s, 2 samples)
Pipe Throughput                              627279.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                 115488.8 lps   (10.0 s, 7 samples)
Process Creation                               4646.7 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   4979.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    665.9 lpm   (60.0 s, 2 samples)
System Call Overhead                         627352.6 lps   (10.0 s, 7 samples)
System Benchmarks Index Values               BASELINE       RESULT    INDEX
Dhrystone 2 using register variables         116700.0   36918704.9   3163.6
Double-Precision Whetstone                       55.0       4087.0    743.1
Execl Throughput                                 43.0       2366.6    550.4
File Copy 1024 bufsize 2000 maxblocks          3960.0     391840.3    989.5
File Copy 256 bufsize 500 maxblocks            1655.0     100645.0    608.1
File Copy 4096 bufsize 8000 maxblocks          5800.0    1153527.2   1988.8
Pipe Throughput                               12440.0     627279.2    504.2
Pipe-based Context Switching                   4000.0     115488.8    288.7
Process Creation                                126.0       4646.7    368.8
Shell Scripts (1 concurrent)                     42.4       4979.2   1174.3
Shell Scripts (8 concurrent)                      6.0        665.9   1109.8
System Call Overhead                          15000.0     627352.6    418.2
System Benchmarks Index Score                                         772.7
PowerServer A STRATO AG
Dhrystone 2 using register variables        3830619.4 lps   (10.0 s, 7 samples)
Double-Precision Whetstone                      895.4 MWIPS (11.0 s, 7 samples)
Execl Throughput                               1043.4 lps   (29.4 s, 2 samples)
File Copy 1024 bufsize 2000 maxblocks        133623.4 KBps  (30.0 s, 2 samples)
File Copy 256 bufsize 500 maxblocks           49351.7 KBps  (30.0 s, 2 samples)
File Copy 4096 bufsize 8000 maxblocks        292261.6 KBps  (30.0 s, 2 samples)
Pipe Throughput                              427357.2 lps   (10.0 s, 7 samples)
Pipe-based Context Switching                  67084.5 lps   (10.1 s, 7 samples)
Process Creation                               3190.8 lps   (30.0 s, 2 samples)
Shell Scripts (1 concurrent)                   1000.2 lpm   (60.0 s, 2 samples)
Shell Scripts (8 concurrent)                    106.4 lpm   (60.7 s, 2 samples)
System Call Overhead                         265577.0 lps   (10.1 s, 7 samples)
Dhrystone 2 using register variables         116700.0    3830619.4    328.2
Double-Precision Whetstone                       55.0        895.4    162.8
Execl Throughput                                 43.0       1043.4    242.6
File Copy 1024 bufsize 2000 maxblocks          3960.0     133623.4    337.4
File Copy 256 bufsize 500 maxblocks            1655.0      49351.7    298.2
File Copy 4096 bufsize 8000 maxblocks          5800.0     292261.6    503.9
Pipe Throughput                               12440.0     427357.2    343.5
Pipe-based Context Switching                   4000.0      67084.5    167.7
Process Creation                                126.0       3190.8    253.2
Shell Scripts (1 concurrent)                     42.4       1000.2    235.9
Shell Scripts (8 concurrent)                      6.0        106.4    177.3
System Call Overhead                          15000.0     265577.0    177.1
System Benchmarks Index Score                                         253.7
update,
Proplay.biz
Premium VPS Maxi für 6,99,-
System -- Linux shiek 2.6.32-042stab057.1 #1 SMP Fri Jun 22 02:17:07 MSD 2012 x86_64 x86_64 x86_64 GNU/Linux
/dev/ploop38p1 24768892 941368 22569336 5% /
Start Benchmark Run: Thu Jul 5 19:09:33 UTC 2012
19:09:33 up 50 min, 1 user, load average: 0.18, 0.06, 0.01
End Benchmark Run: Thu Jul 5 19:20:00 UTC 2012
19:20:00 up 1:00, 1 user, load average: 19.22, 7.99, 3.49
INDEX VALUES
Dhrystone 2 using register variables 376783.7 21062542.4 559.0
Double-Precision Whetstone 83.1 2311.6 278.2
Execl Throughput 188.3 8460.0 449.3
File Copy 1024 bufsize 2000 maxblocks 2672.0 361429.0 1352.7
File Copy 256 bufsize 500 maxblocks 1077.0 103701.0 962.9
File Read 4096 bufsize 8000 maxblocks 15382.0 1885492.0 1225.8
Pipe Throughput 111814.6 4471203.5 399.9
Pipe-based Context Switching 15448.6 344978.5 223.3
Process Creation 569.3 23226.2 408.0
Shell Scripts (8 concurrent) 44.8 2084.0 465.2
System Call Overhead 114433.5 7984313.3 697.7
FINAL SCORE 547.3
Wie albern ist das denn? Fällt hier irgend jemandem auf, dass Benchmarks auf vServern nicht den geringsten Sinn ergeben?
sorry, dass ich den Thread hier ausgrabe, aber kann mir jemand erklären wie man diese Ergebnisse liest?
Je kleine der Index Score desto besser?
Oder umgekehrt?
