Plesk und Munin
ich habe das Problem, seit dem ich Plesk 10 installiert habe, kann ich kein Munin mehr installieren...
(Reading database ... 108175 files and directories currently installed.)
Unpacking rrdtool (from .../rrdtool_1.3.1-4_amd64.deb) ...
dpkg: error processing /var/cache/apt/archives/rrdtool_1.3.1-4_amd64.deb (--unpack):
 trying to overwrite `/usr/share/man/man1/rrdbuild.1.gz', which is also in package sw-rrdtool
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Selecting previously deselected package munin.
Unpacking munin (from .../munin_1.2.6-10~lenny2_all.deb) ...
Processing triggers for man-db ...
Weiß einer wie ich Munin installiere, so das trotzdem noch die "Systemüberwachung" von Plesk geht, die ja sw-rrdtool benutzt?
Viele Grüße
NevaKee
Hab ich auch schon probiert, aber bringt nichts.
xxxx:~# apt-get -f install
Reading package lists... Done
Building dependency tree
Reading state information... Done
Correcting dependencies... Done
The following extra packages will be installed:
  rrdtool
The following NEW packages will be installed:
  rrdtool
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0B/598kB of archives.
After this operation, 1274kB of additional disk space will be used.
Do you want to continue [Y/n]? y
(Reading database ... 108240 files and directories currently installed.)
xxxx:~# dpkg --configure --pending
dpkg: dependency problems prevent configuration of munin:
 munin depends on rrdtool; however:
  Package rrdtool is not installed.
dpkg: error processing munin (--configure):
 dependency problems - leaving unconfigured
 munin
Warum soll ich rrdtool deinstallieren, wenn es gar nicht installiert ist? ;)
xxxx:~# apt-get remove rrdtool
Package rrdtool is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
xxxx:~# apt-get install rrdtool
  rrdtool
(Reading database ... 108224 files and directories currently installed.)
Das Problem hier ist sw-rrdtool, die Pleskeigene Variante der rrdtools, die für den Plesk Health Monitor eingesetzt wird.
Solange die installiert ist, lässt sich rrdtools nicht installieren, und die sw-rrdtools bekommt man nur weg, wenn man den PSA-Health Monitor deinstalliert.
Das geht zwar, aber ob das so sinnvoll ist, keine Ahnung, ich forsch mal weiter.
Die Frage die mich interessieren würde ist ja... Könnte man Munin dazu bringen, des RDDTool zu benutzen ?
Ja, kann man in der Tat.
Man muss dazu "nur" das Munin-Package mit apt-get install munin -d runterladen, dann manuell entpacken.
Außerdem muss man folgende symlinks erstellen:
Your system rrdtool will be replaced with our sw-rrdtool. It is the same rrdtool but with newer version.
Just create symlinks for
/usr/bin/sw-rrdcached
/usr/bin/sw-rrdtool
/usr/bin/sw-rrdupdate
to
/usr/bin/rrdcached
/usr/bin/rrdtool
/usr/bin/rrdupdate
Quelle: http://forum.parallels.com/showthread.php?t=105998&highlight=munin
Dann die config-Dateien in /etc/munin/ anpassen und dann gehts. Allerdings habe ich noch Rechteprobleme, ich bekomme bisher noch keinen Zugriff auf die /var/log/mail.info, die Einträge in der munin-node für mein Spamdyke-Plugin mit group adm gehen nicht mehr. User root oder User syslog klappen auch nicht.
Update: Der Fehler war kein Fehler, hatte auf dem neuen Server noch kein logtail installiert, was das Spamdyke-Plugin benötigt. Daher der Fehler.
Wie genau hast du das mit dem entpacken angestellt? ich bekomme nachdem ich --unpack gemacht habe immer wieder die Fehlermeldung das rrdtool für munin fehlt.
You might want to run `apt-get -f install' to correct these:
The following packages have unmet dependencies:
  munin: Depends: rrdtool but it is not going to be installed
E: Unmet dependencies. Try 'apt-get -f install' with no packages (or specify a solution).
