System: Suse 9.3 64bit mit Plesk 8.1.1Greylisting Control Panel Updater
Downloading neue Version fehlgeschlagen
Übernehme bestehende Config fehlgeschlagen
Installiere neue Version fehlgeschlagen
Anschluss der Installation fehlgeschlagen
Update fehlgeschlagen, bitte erneut versuchen
Downloading neue Version erfolgreich
Configure Command => './configure' '--disable-cgi' '--disable-debug' '--disable-display-source' '--disable-shared' '--enable-pcntl' '--enable-eaccelerator' '--enable-mbregex' '--enable-mbstring=all' '--enable-psasem' '--enable-aengine' '--enable-sockets' '--enable-static' '--enable-sysvsem' '--enable-xml' '--enable-xslt' '--prefix=/usr/local/psa/admin' '--with-apache=//home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/admin/work/apache_1.3.33' '--with-config-file-path=/usr/local/psa/admin/conf' '--with-imap=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist' '--with-imap-ssl' '--with-mcrypt=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist' '--with-mysql' '--with-openssl=/usr' '--with-regex=php' '--with-zip=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist' '--with-zlib' '--without-eaccelerator-encoder' '--without-eaccelerator-webui' '--without-pear' '--without-sablot-js' '--without-xslt-sablot' '--with-pcntl' '--enable-soap' '--with-iconv' '--with-gettext' '--with-gd' '--with-png-dir=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist' '--with-freetype-dir' '--enable-gd-native-ttf' '--enable-bcmath' '--with-libxml-dir=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist' '--with-xsl=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist' '--with-pgsql=/home/builder/buildbot/psa-aiconfig-811-suse93x64/build/plesk/lib/dist/usr' '--with-curl' '--with-_lib=lib64'
zip
LS_COLORS => no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
_SERVER["LS_COLORS"] => no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
_ENV["LS_COLORS"] => no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
zip
Zip support enabled
zlib
ZLib Support enabled
Compiled Version 1.2.2
Linked Version 1.2.2
