/var/log/munin# tail -n 10 *
==> munin-graph.log <==
Sep 05 16:00:02 - Starting munin-graph
Sep 05 16:00:02 - Processing domain: localdomain
Sep 05 16:00:02 - Processed node: localhost.localdomain (0.00 sec)
Sep 05 16:00:02 - Processed domain: localdomain (0.00 sec)
Sep 05 16:00:02 - Munin-graph finished (0.00 sec)
Sep 05 16:05:01 - Starting munin-graph
Sep 05 16:05:01 - Processing domain: localdomain
Sep 05 16:05:01 - Processed node: localhost.localdomain (0.00 sec)
Sep 05 16:05:01 - Processed domain: localdomain (0.00 sec)
Sep 05 16:05:01 - Munin-graph finished (0.00 sec)
==> munin-html.log <==
Sep 05 15:55:01 - processing node: localhost.localdomain
Sep 05 15:55:01 - munin-html finished
Sep 05 16:00:02 - Starting munin-html, checking lock
Sep 05 16:00:02 - processing domain: localdomain
Sep 05 16:00:02 - processing node: localhost.localdomain
Sep 05 16:00:02 - munin-html finished
Sep 05 16:05:01 - Starting munin-html, checking lock
Sep 05 16:05:01 - processing domain: localdomain
Sep 05 16:05:01 - processing node: localhost.localdomain
Sep 05 16:05:01 - munin-html finished
==> munin-limits.log <==
Sep 05 16:00:02 - Starting munin-limits, checking lock
Sep 05 16:00:02 - Created lock: /var/run/munin/munin-limits.lock
Sep 05 16:00:02 - munin-limits finished (0.00 sec)
Sep 05 16:05:01 - Starting munin-limits, checking lock
Sep 05 16:05:01 - Created lock: /var/run/munin/munin-limits.lock
Sep 05 16:05:01 - munin-limits finished (0.00 sec)
==> munin-node.log <==
2009/09/05-15:20:01 CONNECT TCP Peer: "127.0.0.1:55798" Local: "127.0.0.1:4949"
2009/09/05-15:25:01 CONNECT TCP Peer: "127.0.0.1:51945" Local: "127.0.0.1:4949"
2009/09/05-15:30:02 CONNECT TCP Peer: "127.0.0.1:50187" Local: "127.0.0.1:4949"
2009/09/05-15:35:01 CONNECT TCP Peer: "127.0.0.1:60561" Local: "127.0.0.1:4949"
2009/09/05-15:40:01 CONNECT TCP Peer: "127.0.0.1:59443" Local: "127.0.0.1:4949"
2009/09/05-15:45:01 CONNECT TCP Peer: "127.0.0.1:42998" Local: "127.0.0.1:4949"
2009/09/05-15:50:01 CONNECT TCP Peer: "127.0.0.1:51087" Local: "127.0.0.1:4949"
2009/09/05-15:55:01 CONNECT TCP Peer: "127.0.0.1:37413" Local: "127.0.0.1:4949"
2009/09/05-16:00:01 CONNECT TCP Peer: "127.0.0.1:56687" Local: "127.0.0.1:4949"
2009/09/05-16:05:01 CONNECT TCP Peer: "127.0.0.1:50929" Local: "127.0.0.1:4949"
==> munin-update.log <==
Sep 05 16:05:01 - Starting munin-update
Sep 05 16:05:01 [9829] - Processing domain: localdomain
Sep 05 16:05:01 [9829] - Processing node: localhost.localdomain
Sep 05 16:05:01 [9837] - Configured node: localhost.localdomain (0.00 sec)
Sep 05 16:05:01 [9837] - Fetched node: localhost.localdomain (0.00 sec)
Sep 05 16:05:01 [9829] - Processed node: localhost.localdomain (0.00 sec)
Sep 05 16:05:01 [9829] - Processed domain: localdomain (0.01 sec)
Sep 05 16:05:01 [9829] - connection from localdomain -> localhost.localdomain (9837)
Sep 05 16:05:01 [9829] - connection from localdomain -> localhost.localdomain (9837) closed
Sep 05 16:05:01 [9829] - Munin-update finished (0.02 sec)
ls -Rla /etc/munin/plugins/
/etc/munin/plugins/:
total 8
drwxr-xr-x 2 root root 4096 Sep 5 15:24 .
drwxr-xr-x 5 root root 4096 Sep 5 15:02 ..
lrwxrwxrwx 1 root root 36 Sep 5 15:24 mysql_bytes -> /usr/share/munin/plugins/mysql_bytes
lrwxrwxrwx 1 root root 42 Sep 5 15:24 mysql_isam_space_ -> /usr/share/munin/plugins/mysql_isam_space_
lrwxrwxrwx 1 root root 38 Sep 5 15:24 mysql_queries -> /usr/share/munin/plugins/mysql_queries
lrwxrwxrwx 1 root root 38 Sep 5 15:24 mysql_threads -> /usr/share/munin/plugins/mysql_threads
lrwxrwxrwx 1 root root 37 Sep 5 15:06 vserver_cpu_ -> /usr/share/munin/plugins/vserver_cpu_
lrwxrwxrwx 1 root root 40 Sep 5 15:06 vserver_loadavg -> /usr/share/munin/plugins/vserver_loadavg
lrwxrwxrwx 1 root root 42 Sep 5 15:06 vserver_resources -> /usr/share/munin/plugins/vserver_resources
2009/09/05-16:50:01 CONNECT TCP Peer: "127.0.0.1:41978" Local: "127.0.0.1:4949"
find: `/proc/virtual/*': No such file or directory
2009/09/05-16:50:02 Plugin "vserver_resources" exited with status 256. -- not defined.
