Das sagt er wenn ich den befehl für den start eintippe.:
Starting drwebd done
sponsor-games:~ #
sponsor-games:~ # sponsor-games:~ # /etc/init.d/psa start
-bash: sponsor-games:~: command not found
xinetd off
sponsor-games:~ # xinetd off
Usage: xinetd [-d] [-f config_file] [-filelog filename] [-syslog facility] [-reuse] [-limit proc_limit] [-pidfile filename] [-logprocs limit] [-shutdownprocs limit] [-cc interval]
dones:~ # Starting INET services. (xinetd)
-bash: syntax error near unexpected token `('
sponsor-games:~ # named off
usage: named [-4|-6] [-c conffile] [-d debuglevel] [-f|-g] [-n number_of_cpus]
[-p port] [-s] [-t chrootdir] [-u username]
[-m {usage|trace|record}]
named: extra command line arguments
Starting name server BIND - Warning: named already running! cp: `/etc/named.conf' and `/var/lib/named//etc/named.conf' are the same file
done
mysql off
: `/etc/named.conf' and `/var/lib/named//etc/named.conf' are the same fileng! cp
> done
> mysql off
> Starting service MySQL done
> postgresql off
he trotzdem zu starteng_ctl: ein anderer postmaster läuft möglicherweise; versuc
> pg_ctl: konnte postmaster nicht starten
> Prüfen Sie die Logausgabe.
> failed
> psa-spamassassin off
> Starting psa-spamassassin service: done
> apache2 off
> /usr/local/psa/admin/bin/httpsdctl start: httpd (pid 13765) already running
> Starting Plesk: done
> drwebd off
> Starting drwebd
> help
