# To have more informations about Proftpd configuration
# look at : http://www.proftpd.org/
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use. It establishes a single server
# and a single anonymous login. It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName "ProFTPD"
ServerType inetd
ServerType inetd
DefaultServer on
<Global>
DefaultRoot ~ psacln
AllowOverwrite on
</Global>
DefaultTransferMode binary
UseFtpUsers on
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# (such as xinetd)
MaxInstances 30
#Following part of this config file were generate by PSA automatically
#Any changes in this part will be overwritten by next manipulation
#with Anonymous FTP feature in PSA control panel.
#Include directive should point to place where FTP Virtual Hosts configurations
#preserved
ScoreboardFile /var/run/proftpd/scoreboard
# Primary log file mest be outside of system logrotate province
TransferLog /usr/local/psa/var/log/xferlog
#Change default group for new files and directories in vhosts dir to psacln
<Directory /var/www/vhosts>
GroupOwner psacln
</Directory>
# Disable PAM authentication
AuthPAM off
# delay on login off
IdentLookups off
UseReverseDNS off
Include /etc/proftpd.include
aus und probiere es nochmal.DefaultTransferMode binary
# xinetd.conf
# Copyright (c) 1998-2001 SuSE GmbH Nuernberg, Germany.
# Copyright (c) 2002 SuSE Linux AG, Nuernberg, Germany.
defaults
log_type = FILE /var/log/xinetd.log
log_on_success = HOST EXIT DURATION
log_on_failure = HOST ATTEMPT
# only_from = localhost
instances = 30
cps = 50 10
# The specification of an interface is interesting, if we are on a firewall.
# For example, if you only want to provide services from an internal
# network interface, you may specify your internal interfaces IP-Address.
# interface = 127.0.0.1
includedir /etc/xinetd.d
