Ich hab bei meiner Routineuntersuchung gerade festgestellt, dass eine Festplatte Fehler ausspuckt.
Die Platte hat rund 731 Tage auf dem Buckel, geht also eigentlich noch.
dmesg.log
Den betroffenen Sector (45323315) kann ich mittels hdparm erfolgreich auslesen.
Sollte ich mir Sorgen machen?
root@server # smartctl -a /dev/sda
smartctl 5.41 2011-06-09 r3365 [x86_64-linux-3.2.0-4-amd64] (local build)
Copyright (C) 2002-11 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model: ST33000650NS
Serial Number: Z292S9CJ
LU WWN Device Id: 5 000c50 04d2fee04
Firmware Version: 0004
User Capacity: 3,000,592,982,016 bytes [3.00 TB]
Sector Size: 512 bytes logical/physical
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: 8
ATA Standard is: ATA-8-ACS revision 4
Local Time is: Sun Mar 1 13:00:11 2015 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status: ( 241) Self-test routine in progress...
10% of test remaining.
Total time to complete Offline
data collection: ( 609) seconds.
capabilities: (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 255) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x10bd) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000f 082 060 044 Pre-fail Always - 170593875
3 Spin_Up_Time 0x0003 092 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 12
5 Reallocated_Sector_Ct 0x0033 100 100 036 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 084 060 030 Pre-fail Always - 317789849
9 Power_On_Hours 0x0032 080 080 000 Old_age Always - 17551
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 12
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 097 097 000 Old_age Always - 3
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 058 054 045 Old_age Always - 42 (Min/Max 24/44)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 6
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 12
194 Temperature_Celsius 0x0022 042 046 000 Old_age Always - 42 (0 13 0 0)
195 Hardware_ECC_Recovered 0x001a 031 004 000 Old_age Always - 170593875
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 6 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 6 occurred at disk power-on lifetime: 17491 hours (728 days + 19 hours)
When the command that caused the error occurred, the device was active or idle.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
40 51 00 33 94 b3 02 Error: UNC at LBA = 0x02b39433 = 45323315
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
60 00 00 80 92 b3 42 00 19d+21:46:16.679 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 19d+21:46:16.679 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 19d+21:46:16.679 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 19d+21:46:16.678 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 19d+21:46:16.678 READ NATIVE MAX ADDRESS EXT
Error 5 occurred at disk power-on lifetime: 17491 hours (728 days + 19 hours)
40 51 00 d4 93 b3 02 Error: UNC at LBA = 0x02b393d4 = 45323220
60 00 00 80 92 b3 42 00 19d+21:46:06.887 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 19d+21:46:06.887 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 19d+21:46:06.886 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 19d+21:46:06.886 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 19d+21:46:06.886 READ NATIVE MAX ADDRESS EXT
Error 4 occurred at disk power-on lifetime: 17491 hours (728 days + 19 hours)
40 51 00 2c 94 b3 02 Error: UNC at LBA = 0x02b3942c = 45323308
60 00 00 80 92 b3 42 00 19d+21:45:56.777 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 19d+21:45:56.777 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 19d+21:45:56.776 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 19d+21:45:56.745 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 19d+21:45:56.745 READ NATIVE MAX ADDRESS EXT
Error 3 occurred at disk power-on lifetime: 17491 hours (728 days + 19 hours)
40 51 00 f1 93 b3 02 Error: UNC at LBA = 0x02b393f1 = 45323249
60 00 00 80 92 b3 42 00 19d+21:45:46.644 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 19d+21:45:46.644 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 19d+21:45:46.643 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 19d+21:45:46.643 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 19d+21:45:46.643 READ NATIVE MAX ADDRESS EXT
Error 2 occurred at disk power-on lifetime: 17491 hours (728 days + 19 hours)
40 51 00 e2 93 b3 02 Error: UNC at LBA = 0x02b393e2 = 45323234
60 00 00 80 92 b3 42 00 19d+21:45:36.468 READ FPDMA QUEUED
27 00 00 00 00 00 e0 00 19d+21:45:36.468 READ NATIVE MAX ADDRESS EXT
ec 00 00 00 00 00 a0 00 19d+21:45:36.467 IDENTIFY DEVICE
ef 03 46 00 00 00 a0 00 19d+21:45:36.427 SET FEATURES [Set transfer mode]
27 00 00 00 00 00 e0 00 19d+21:45:36.427 READ NATIVE MAX ADDRESS EXT
SMART Self-test log structure revision number 1
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 17551 -
# 2 Extended offline Completed without error 00% 16615 -
# 3 Short offline Completed without error 00% 16448 -
# 4 Extended offline Completed without error 00% 15633 -
# 5 Extended offline Completed without error 00% 15602 -
# 6 Extended offline Completed without error 00% 15321 -
# 7 Extended offline Completed without error 00% 15290 -
# 8 Extended offline Completed without error 00% 10518 -
# 9 Extended offline Completed without error 00% 7 -
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
dmesg.log
[6000019.061087] ata1.00: exception Emask 0x0 SAct 0x40 SErr 0x0 action 0x0
[6000019.061119] ata1.00: irq_stat 0x40000008
[6000019.061142] ata1.00: failed command: READ FPDMA QUEUED
[6000019.061171] ata1.00: cmd 60/00:30:80:92:b3/04:00:02:00:00/40 tag 6 ncq 524288 in
[6000019.061172] res 41/40:00:2d:94:b3/00:04:02:00:00/00 Emask 0x409 (media error) <F>
[6000019.061268] ata1.00: status: { DRDY ERR }
[6000019.061291] ata1.00: error: { UNC }
[6000019.110357] ata1.00: configured for UDMA/133
[6000019.110395] ata1: EH complete
[6000029.246300] ata1.00: exception Emask 0x0 SAct 0x100 SErr 0x0 action 0x0
[6000029.246331] ata1.00: irq_stat 0x40000008
[6000029.246356] ata1.00: failed command: READ FPDMA QUEUED
[6000029.246384] ata1.00: cmd 60/00:40:80:92:b3/04:00:02:00:00/40 tag 8 ncq 524288 in
[6000029.246386] res 41/40:00:e2:93:b3/00:04:02:00:00/00 Emask 0x409 (media error) <F>
[6000029.246466] ata1.00: status: { DRDY ERR }
[6000029.246488] ata1.00: error: { UNC }
[6000029.279571] ata1.00: configured for UDMA/133
[6000029.279610] ata1: EH complete
[6000039.259377] ata1.00: exception Emask 0x0 SAct 0x800 SErr 0x0 action 0x0
[6000039.259408] ata1.00: irq_stat 0x40000008
[6000039.259433] ata1.00: failed command: READ FPDMA QUEUED
[6000039.259462] ata1.00: cmd 60/00:58:80:92:b3/04:00:02:00:00/40 tag 11 ncq 524288 in
[6000039.259463] res 41/40:00:f1:93:b3/00:04:02:00:00/00 Emask 0x409 (media error) <F>
[6000039.259544] ata1.00: status: { DRDY ERR }
[6000039.259565] ata1.00: error: { UNC }
[6000039.405830] ata1.00: configured for UDMA/133
[6000039.405868] ata1: EH complete
[6000049.475251] ata1.00: exception Emask 0x0 SAct 0x4000 SErr 0x0 action 0x0
[6000049.475282] ata1.00: irq_stat 0x40000008
[6000049.475306] ata1.00: failed command: READ FPDMA QUEUED
[6000049.475335] ata1.00: cmd 60/00:70:80:92:b3/04:00:02:00:00/40 tag 14 ncq 524288 in
[6000049.475336] res 41/40:00:2c:94:b3/00:04:02:00:00/00 Emask 0x409 (media error) <F>
[6000049.475416] ata1.00: status: { DRDY ERR }
[6000049.475438] ata1.00: error: { UNC }
[6000049.508524] ata1.00: configured for UDMA/133
[6000049.508563] ata1: EH complete
[6000059.261045] ata1.00: exception Emask 0x0 SAct 0x20000 SErr 0x0 action 0x0
[6000059.261075] ata1.00: irq_stat 0x40000008
[6000059.261100] ata1.00: failed command: READ FPDMA QUEUED
[6000059.261128] ata1.00: cmd 60/00:88:80:92:b3/04:00:02:00:00/40 tag 17 ncq 524288 in
[6000059.261130] res 41/40:00:d4:93:b3/00:04:02:00:00/00 Emask 0x409 (media error) <F>
[6000059.261210] ata1.00: status: { DRDY ERR }
[6000059.261232] ata1.00: error: { UNC }
[6000059.294301] ata1.00: configured for UDMA/133
[6000059.294337] ata1: EH complete
[6000068.978670] ata1.00: exception Emask 0x0 SAct 0x100000 SErr 0x0 action 0x0
[6000068.978700] ata1.00: irq_stat 0x40000008
[6000068.978726] ata1.00: failed command: READ FPDMA QUEUED
[6000068.978755] ata1.00: cmd 60/00:a0:80:92:b3/04:00:02:00:00/40 tag 20 ncq 524288 in
[6000068.978756] res 41/40:00:33:94:b3/00:04:02:00:00/00 Emask 0x409 (media error) <F>
[6000068.980257] ata1.00: status: { DRDY ERR }
[6000068.980279] ata1.00: error: { UNC }
[6000069.112684] ata1.00: configured for UDMA/133
[6000069.112727] sd 0:0:0:0: [sda] Unhandled sense code
[6000069.112751] sd 0:0:0:0: [sda] Result: hostbyte=DID_OK driverbyte=DRIVER_SENSE
[6000069.112792] sd 0:0:0:0: [sda] Sense Key : Medium Error [current] [descriptor]
[6000069.112836] Descriptor sense data with sense descriptors (in hex):
[6000069.112862] 72 03 11 04 00 00 00 0c 00 0a 80 00 00 00 00 00
[6000069.112904] 02 b3 94 33
[6000069.112929] sd 0:0:0:0: [sda] Add. Sense: Unrecovered read error - auto reallocate failed
[6000069.112974] sd 0:0:0:0: [sda] CDB: Read(10): 28 00 02 b3 92 80 00 04 00 00
[6000069.113015] end_request: I/O error, dev sda, sector 45323315
[6000069.113055] ata1: EH complete
root@server # hdparm --read-sector 45323315 /dev/sda
/dev/sda:
reading sector 45323315: succeeded
0000 0000 0000 0000 0000 0000 0000 0000
