infernus
Da musst du in den Serverlogs von Apache nachsehen, was der genaue Fehler ist.
Der errlog hat das hier ausgespuckt:
apache2: Could not reliably determine the server's fully qualified domain name, using confixx.gbs4u.de for ServerName
[Wed Dec 24 18:35:12 2008] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Dec 24 18:35:12 2008] [warn] RSA server certificate CommonName (CN) `confixx' does NOT match server name!?
[Wed Dec 24 18:35:12 2008] [warn] Init: SSL server IP/port conflict: confixx.gbs4u.de:443 (/etc/apache2/confixx_mhost.conf:85) vs. web1.confixx.gbs4u.de:443 (/etc/apache2/confixx_vhosts/web1.conf:31)
[Wed Dec 24 18:35:12 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Dec 24 18:35:12 2008] [notice] Apache/2.2.3 (Debian) mod_ssl/2.2.3 OpenSSL/0.9.8c configured -- resuming normal operations
[Wed Dec 24 18:35:12 2008] [warn] long lost child came home! (pid 16240)
[Wed Dec 24 18:35:12 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/home/photobook/favicon.ico, referer: http://www.gbs4u.de/
[Wed Dec 24 18:35:17 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/home/photobook/favicon.ico, referer: http://www.gbs4u.de/
[Wed Dec 24 18:35:22 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/home/photobook/favicon.ico, referer: http://gbs4u.de/
[Wed Dec 24 18:37:22 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/home/photobook/favicon.ico, referer: http://gbs4u.de/
[Wed Dec 24 18:41:05 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/home/photobook/favicon.ico, referer: http://gbs4u.de/
[Wed Dec 24 18:43:06 2008] [notice] SIGUSR1 received. Doing graceful restart
[Wed Dec 24 18:43:08 2008] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Dec 24 18:43:08 2008] [warn] RSA server certificate CommonName (CN) `confixx' does NOT match server name!?
[Wed Dec 24 18:43:08 2008] [warn] Init: SSL server IP/port conflict: confixx.gbs4u.de:443 (/etc/apache2/confixx_mhost.conf:85) vs. web1.confixx.gbs4u.de:443 (/etc/apache2/confixx_vhosts/web1.conf:31)
[Wed Dec 24 18:43:08 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Dec 24 18:43:08 2008] [notice] Apache/2.2.3 (Debian) mod_ssl/2.2.3 OpenSSL/0.9.8c configured -- resuming normal operations
[Wed Dec 24 18:43:08 2008] [warn] long lost child came home! (pid 20097)
[Wed Dec 24 18:44:23 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://gbs4u.de/
[Wed Dec 24 21:12:31 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/
[Wed Dec 24 21:22:27 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/
[Wed Dec 24 21:30:56 2008] [notice] caught SIGTERM, shutting down
[Wed Dec 24 21:31:34 2008] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Dec 24 21:31:34 2008] [warn] RSA server certificate CommonName (CN) `confixx' does NOT match server name!?
[Wed Dec 24 21:31:34 2008] [warn] Init: SSL server IP/port conflict: confixx.gbs4u.de:443 (/etc/apache2/confixx_mhost.conf:85) vs. web1.confixx.gbs4u.de:443 (/etc/apache2/confixx_vhosts/web1.conf:31)
[Wed Dec 24 21:31:34 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Dec 24 21:31:34 2008] [notice] suEXEC mechanism enabled (wrapper: /usr/lib/apache2/suexec)
[Wed Dec 24 21:31:36 2008] [warn] RSA server certificate is a CA certificate (BasicConstraints: CA == TRUE !?)
[Wed Dec 24 21:31:36 2008] [warn] RSA server certificate CommonName (CN) `confixx' does NOT match server name!?
[Wed Dec 24 21:31:36 2008] [warn] Init: SSL server IP/port conflict: confixx.gbs4u.de:443 (/etc/apache2/confixx_mhost.conf:85) vs. web1.confixx.gbs4u.de:443 (/etc/apache2/confixx_vhosts/web1.conf:31)
[Wed Dec 24 21:31:36 2008] [warn] Init: You should not use name-based virtual hosts in conjunction with SSL!!
[Wed Dec 24 21:31:36 2008] [notice] Apache/2.2.3 (Debian) mod_ssl/2.2.3 OpenSSL/0.9.8c configured -- resuming normal operations
[Wed Dec 24 21:31:40 2008] [error] [client 77.180.20.147] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/
[Wed Dec 24 22:38:56 2008] [error] [client 84.179.20.31] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 00:38:15 2008] [error] [client 66.249.71.146] File does not exist: /var/www/web1/html/html/photobook/robots.txt
[Thu Dec 25 07:16:22 2008] [error] [client 72.30.142.171] File does not exist: /var/www/web1/html/html/photobook/robots.txt
[Thu Dec 25 12:16:39 2008] [error] [client 77.190.183.250] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 12:16:42 2008] [error] [client 77.190.183.250] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 14:21:42 2008] [error] [client 91.67.169.57] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 14:21:45 2008] [error] [client 91.67.169.57] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 14:59:58 2008] [error] server reached MaxClients setting, consider raising the MaxClients setting
[Thu Dec 25 15:01:26 2008] [error] [client 80.142.110.254] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 15:04:10 2008] [error] [client 87.164.133.174] File does not exist: /var/www/web1/html/html/photobook/favicon.ico
[Thu Dec 25 15:54:30 2008] [error] [client 91.67.169.57] File does not exist: /var/www/web1/html/html/photobook/photobook
[Thu Dec 25 15:54:32 2008] [error] [client 91.67.169.57] File does not exist: /var/www/web1/html/html/photobook/photobook
[Thu Dec 25 16:17:10 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/index.php" is writeable by group
[Thu Dec 25 16:17:10 2008] [error] [client 77.180.12.132] Premature end of script headers: index.php
[Thu Dec 25 16:17:10 2008] [error] [client 77.180.12.132] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/
[Thu Dec 25 16:17:32 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/install.php" is writeable by group
[Thu Dec 25 16:17:32 2008] [error] [client 77.180.12.132] Premature end of script headers: install.php
[Thu Dec 25 16:17:33 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/install.php" is writeable by group
[Thu Dec 25 16:17:33 2008] [error] [client 77.180.12.132] Premature end of script headers: install.php
[Thu Dec 25 16:17:33 2008] [error] [client 77.180.12.132] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:18:36 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/install.php" is writeable by group
[Thu Dec 25 16:18:36 2008] [error] [client 77.180.12.132] Premature end of script headers: install.php
[Thu Dec 25 16:18:36 2008] [error] [client 77.180.12.132] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:20:17 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/install.php" is writeable by group
[Thu Dec 25 16:20:17 2008] [error] [client 77.180.12.132] Premature end of script headers: install.php
[Thu Dec 25 16:20:17 2008] [error] [client 77.180.12.132] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:21:08 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/install.php" is writeable by group
[Thu Dec 25 16:21:08 2008] [error] [client 77.180.12.132] Premature end of script headers: install.php
[Thu Dec 25 16:21:08 2008] [error] [client 77.180.12.132] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:22:39 2008] [error] [client 77.180.12.132] SoftException in Application.cpp:245: File "/var/www/web1/html/html/photobook/install.php" is writeable by group
[Thu Dec 25 16:22:39 2008] [error] [client 77.180.12.132] Premature end of script headers: install.php
[Thu Dec 25 16:22:39 2008] [error] [client 77.180.12.132] File does not exist: /var/www/web1/html/html/photobook/favicon.ico, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:25:03 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:25:03 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:25:06 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:25:48 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:25:48 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:31:16 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:31:16 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:31:18 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:36:45 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:36:45 2008] [alert] [client 77.180.12.132] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here, referer: http://www.gbs4u.de/install.php
[Thu Dec 25 16:40:31 2008] [alert] [client 77.188.210.69] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here, referer: http://serversupportforum.de/forum/confixx/29809-domain-problem.html
[Thu Dec 25 16:40:32 2008] [alert] [client 77.188.210.69] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:40:35 2008] [alert] [client 77.188.210.69] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here
[Thu Dec 25 16:41:29 2008] [alert] [client 77.188.210.69] /var/www/web1/html/html/photobook/.htaccess: Options not allowed here, referer: http://serversupportforum.de/forum/confixx/29809-domain-problem.html
Hab so langsam keine lust mehr, immer diese ständigen Probleme!
[EDIT]
Das steht in der .htaccess
Options +FollowSymLinks
RewriteEngine On
RewriteBase /
RewriteRule view-(.*) view.php?filename=$1
