ich benötige bitte ein bisschen Hilfe bei der Optimierung in Sachen Geschwindigkeit für meinen vServer.
Er hat folgende Daten:
Die Apache2.conf sieht aktuell so aus (Standard):
Für einen Speedtest habe ich folgendes verwendet:
ab -c 20 -n 200 http://rassekatze.eu/
Ergebnis:
Habe den Test ein zweites mal ausgeführt, um bessere Werte zu haben:
Ich danke euch für die Hilfe und freue mich, wenn mein vServer schneller wird
LG und Danke
Toni
CPU (garantiert) 2.000 MHz (2 Kern)
RAM (garantiert) 1.024 MB
RAM (maximal) 2.048 MB
# Based upon the NCSA server configuration files originally by Rob McCool.
# This is the main Apache server configuration file. It contains the
# See http://httpd.apache.org/docs/2.2/ for detailed information about
# the directives.
# Do NOT simply read the instructions in here without understanding
# what they do. They're here only as hints or reminders. If you are unsure
# consult the online docs. You have been warned.
# The configuration directives are grouped into three basic sections:
# 1. Directives that control the operation of the Apache server process as a
# whole (the 'global environment').
# 2. Directives that define the parameters of the 'main' or 'default' server,
# which responds to requests that aren't handled by a virtual host.
# These directives also provide default values for the settings
# of all virtual hosts.
# 3. Settings for virtual hosts, which allow Web requests to be sent to
# different IP addresses or hostnames and have them handled by the
# same Apache server process.
# Configuration and logfile names: If the filenames you specify for many
# of the server's control files begin with "/" (or "drive:/" for Win32), the
# server will use that explicit path. If the filenames do *not* begin
# with "/", the value of ServerRoot is prepended -- so "foo.log"
# with ServerRoot set to "/etc/apache2" will be interpreted by the
# server as "/etc/apache2/foo.log".
### Section 1: Global Environment
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests it can handle or where it
# can find its configuration files.
# ServerRoot: The top of the directory tree under which the server's
# configuration, error, and log files are kept.
# NOTE! If you intend to place this on an NFS (or otherwise network)
# mounted filesystem then please read the LockFile documentation (available
# at <URL:http://httpd.apache.org/docs/2.2/mod/mpm_common.html#lockfile>);
# you will save yourself a lot of trouble.
# Do NOT add a slash at the end of the directory path.
#ServerRoot "/etc/apache2"
# The accept serialization lock file MUST BE STORED ON A LOCAL DISK.
LockFile ${APACHE_LOCK_DIR}/accept.lock
# PidFile: The file in which the server should record its process
# identification number when it starts.
# This needs to be set in /etc/apache2/envvars
PidFile ${APACHE_PID_FILE}
# Timeout: The number of seconds before receives and sends time out.
Timeout 300
# KeepAlive: Whether or not to allow persistent connections (more than
# one request per connection). Set to "Off" to deactivate.
KeepAlive On
# MaxKeepAliveRequests: The maximum number of requests to allow
# during a persistent connection. Set to 0 to allow an unlimited amount.
# We recommend you leave this number high, for maximum performance.
MaxKeepAliveRequests 100
# KeepAliveTimeout: Number of seconds to wait for the next request from the
# same client on the same connection.
KeepAliveTimeout 15
## Server-Pool Size Regulation (MPM specific)
# prefork MPM
# StartServers: number of server processes to start
# MinSpareServers: minimum number of server processes which are kept spare
# MaxSpareServers: maximum number of server processes which are kept spare
# MaxClients: maximum number of server processes allowed to start
# MaxRequestsPerChild: maximum number of requests a server process serves
<IfModule mpm_prefork_module>
StartServers 1
MinSpareServers 5
MaxSpareServers 10
MaxClients 10
MaxRequestsPerChild 0
</IfModule>
##StartServers 1
##MinSpareServers 5
##MaxSpareServers 10
##MaxClients 10
## MaxRequestsPerChild 0
# worker MPM
# StartServers: initial number of server processes to start
# MaxClients: maximum number of simultaneous client connections
# MinSpareThreads: minimum number of worker threads which are kept spare
# MaxSpareThreads: maximum number of worker threads which are kept spare
# ThreadLimit: ThreadsPerChild can be changed to this maximum value during a
# graceful restart. ThreadLimit can only be changed by stopping
# and starting Apache.
# ThreadsPerChild: constant number of worker threads in each server process
<IfModule mpm_worker_module>
StartServers 1
MinSpareThreads 1
MaxSpareThreads 4
ThreadLimit 64
ThreadsPerChild 25
MaxClients 10
</IfModule>
##StartServers 1
##MinSpareThreads 1
##MaxSpareThreads 4
## ThreadLimit 64
## ThreadsPerChild 25
##MaxClients 10
# event MPM
<IfModule mpm_event_module>
StartServers 1
MaxClients 10
MinSpareThreads 1
MaxSpareThreads 4
ThreadLimit 64
ThreadsPerChild 25
</IfModule>
# These need to be set in /etc/apache2/envvars
User ${APACHE_RUN_USER}
Group ${APACHE_RUN_GROUP}
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives. See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<Files ~ "^\.ht">
Order allow,deny
Deny from all
Satisfy all
</Files>
# DefaultType is the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value. If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
# HostnameLookups: Log the names of clients or just their IP addresses
# e.g., www.apache.org (on) or 204.62.129.132 (off).
# The default is off because it'd be overall better for the net if people
# had to knowingly turn this feature on, since enabling it means that
# each client request will result in AT LEAST one lookup request to the
# nameserver.
HostnameLookups Off
# logged here. If you *do* define an error logfile for a <VirtualHost>
ErrorLog ${APACHE_LOG_DIR}/error.log
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel warn
# Include module configuration:
Include mods-enabled/*.load
Include mods-enabled/*.conf
# Include all the user configurations:
Include httpd.conf
# Include ports listing
Include ports.conf
# The following directives define some format nicknames for use with
# a CustomLog directive (see below).
# If you are behind a reverse proxy, you might want to change %h into %{X-Forwarded-For}i
LogFormat "%v:%p %h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" vhost_combined
LogFormat "%h %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
LogFormat "%h %l %u %t \"%r\" %>s %O" common
LogFormat "%{Referer}i -> %U" referer
LogFormat "%{User-agent}i" agent
# Include of directories ignores editors' and dpkg's backup files,
# see README.Debian for details.
# Include generic snippets of statements
Include conf.d/
# Include the virtual host configurations:
Include sites-enabled/
GracefulShutDownTimeout 3
AddOutputFilter INCLUDES .shtml
AddType text/html .shtml
AddType application/x-httpd-php .php
AddType application/x-httpd-php-source .phps
Ergebnis:
Benchmarking rassekatze.eu (be patient)
Completed 100 requests
Completed 200 requests
Finished 200 requests
Server Software: Apache
Server Hostname: rassekatze.eu
Server Port: 80
Document Path: /
Document Length: 40016 bytes
Concurrency Level: 20
Time taken for tests: 56.110 seconds
Complete requests: 200
Failed requests: 0
Write errors: 0
Total transferred: 8088600 bytes
HTML transferred: 8003200 bytes
Requests per second: 3.56 [#/sec] (mean)
Time per request: 5610.977 [ms] (mean)
Time per request: 280.549 [ms] (mean, across all concurrent requests)
Transfer rate: 140.78 [Kbytes/sec] received
Connection Times (ms)
min mean[+/-sd] median max
Connect: 0 0 0.2 0 1
Processing: 749 5398 1343.7 5151 8222
Waiting: 689 5326 1339.2 5063 8187
Total: 750 5398 1343.6 5151 8222
Percentage of the requests served within a certain time (ms)
50% 5151
66% 5519
75% 6106
80% 6651
90% 7426
95% 7692
98% 8073
99% 8147
100% 8222 (longest request)
Server Port: 80
Document Path: /
Time taken for tests: 51.007 seconds
Failed requests: 0
Write errors: 0
Requests per second: 3.92 [#/sec] (mean)
Time per request: 5100.677 [ms] (mean)
Time per request: 255.034 [ms] (mean, across all concurrent requests)
Transfer rate: 154.86 [Kbytes/sec] received
Connect: 0 0 0.7 0 3
Processing: 1742 4903 722.1 4987 6591
Waiting: 1641 4806 725.7 4885 6496
Total: 1743 4903 721.8 4987 6594
50% 4987
66% 5148
75% 5234
80% 5304
90% 5516
95% 5855
98% 6167
99% 6378
100% 6594 (longest request)
LG und Danke
Toni
