DBD::mysql::db do failed: Incorrect key file for table './confixx/pop3.MYI'; try to repair it at /var/www/confixx/admin/updates/db_update.pl line 1466.
DBD::mysql::db do failed: Table 'kunden' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1466.
Updating /var/www/web18/html//.htaccess
Updating /var/www/web18/html/error/.htaccess
Updating /var/www/web18/html/cgi-bin/.htaccess
Updating /var/www/web16/html/bin/archiv/.htaccess
Updating /var/www/web20/html//.htaccess
Updating /var/www/web20/html/test_schutz/.htaccess
Updating /var/www/web4/html/images/admin/.htaccess
Updating /var/www/web26/html/Uploads/.htaccess
Updating /var/www/web1/html/db/.htaccess
DBD::mysql::db do failed: Table 'admin' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1518.
DBD::mysql::db do failed: Table 'admin' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1524.
DBD::mysql::db do failed: Table 'admin' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1544.
DBD::mysql::db do failed: Table 'admin' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1547.
DBD::mysql::db do failed: Table 'admin' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1552.
DBD::mysql::db do failed: Table 'kunden' is marked as crashed and should be repaired at /var/www/confixx/admin/updates/db_update.pl line 1591.
DBD::mysql::st execute failed: Table 'kunden' is marked as crashed and should be repaired at /var/www/confixx/admin/subs/lib_module_common.pm line 823.
DBD::mysql::st fetchrow_array failed: fetch() without execute() at /var/www/confixx/admin/subs/lib_module_common.pm line 824.
