Wollte x-window und gnome auf meinem server installieren dazu vnc.
Fehler:
Wenn ich startx eingebe kommt:
Hat wer ne idee? Ist ein VPS (Virtuozzo) debian 4
Fehler:
udev
hal
gnome-volume-manager
gnome-desktop-environment
gnome-power-manager
gnome
xauth: creating new authority file /root/.serverauth.28288
X: warning; process set to priority -1 instead of requested priority 0
X Window System Version 7.1.1
Release Date: 12 May 2006
X Protocol Version 11, Revision 0, Release 7.1.1
Build Operating System: UNKNOWN
Current Operating System: Linux km2blablaxx.keymachine.de 2.6.18-028stab060.8-ent #1 SMP Mon Feb 9 20:49:42 MSK 2009 i686
Build Date: 29 May 2008
Before reporting problems, check [URL="http://wiki.x.org"]X.Org Wiki - Home[/URL]
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Fri Apr 24 22:27:24 2009
(==) Using config file: "/etc/X11/xorg.conf"
Fatal server error:
xf86OpenConsole: Cannot open /dev/tty0 (No such file or directory)
XIO: fatal IO error 104 (Connection reset by peer) on X server ":0.0"
after 0 requests (0 known processed) with 0 events remaining.
Couldnt get a file descriptor referring to the console
