vsftpd und 500 OOPS: vsftpd: refusing to run with writable root inside chroot()
giabbatino
Hallo Zusammen,
ich habe vsftpd nach dieser Anleitung installiert und konfiguriert.
http://www.netcup-wiki.de/wiki/VSFTPD_Installation_und_Einrichtung
Wenn ich mich via Filezilla anmelden will bekomme ich folgenden Fehler:
Befehl: USER XXXXXX
Antwort: 331 Please specify the password.
Befehl: PASS ********
Antwort: 500 OOPS: vsftpd: refusing to run with writable root inside chroot()
Fehler: Kritischer Fehler
Fehler: Herstellen der Verbindung zum Server fehlgeschlagen
Im vsftpd log steht
Fri Jan 17 19:54:34 2014 [pid 2] CONNECT: Client "78.xx.xxx.xx"
Fri Jan 17 19:54:34 2014 [pid 1] [USERNAME] OK LOGIN: Client "78.xx.xxx.xx"
Was ist der Fehler? Ichkomme nicht weiter:-(
Gruss
Alex
danke für die schnelle Antwort
#Example config file /etc/vsftpd.conf
# The default compiled in settings are fairly paranoid. This sample file
# loosens things up a bit, to make the ftp daemon more usable.
# Please see vsftpd.conf.5 for all compiled in defaults.
# READ THIS: This example file is NOT an exhaustive list of vsftpd options.
# Please read the vsftpd.conf.5 manual page to get a full idea of vsftpd's
# capabilities.
# Run standalone?  vsftpd can run either from an inetd or as a standalone
# daemon started from an initscript.
listen=YES
# Run standalone with IPv6?
# Like the listen parameter, except vsftpd will listen on an IPv6 socket
# instead of an IPv4 one. This parameter and the listen parameter are mutually
# exclusive.
#listen_ipv6=YES
# Allow anonymous FTP? (Beware - allowed by default if you comment this out).
anonymous_enable=NO
# Uncomment this to allow local users to log in.
local_enable=YES
# Uncomment this to enable any form of FTP write command.
write_enable=YES
# Default umask for local users is 077. You may wish to change this to 022,
# if your users expect that (022 is used by most other ftpd's)
#local_umask=022
# Uncomment this to allow the anonymous FTP user to upload files. This only
# has an effect if the above global write enable is activated. Also, you will
# obviously need to create a directory writable by the FTP user.
#anon_upload_enable=YES
# new directories.
#anon_mkdir_write_enable=YES
# Activate directory messages - messages given to remote users when they
# go into a certain directory.
dirmessage_enable=YES
# If enabled, vsftpd will display directory listings with the time
# in  your  local  time  zone.  The default is to display GMT. The
# times returned by the MDTM FTP command are also affected by this
# option.
use_localtime=YES
# Activate logging of uploads/downloads.
xferlog_enable=YES
# Make sure PORT transfer connections originate from port 20 (ftp-data).
connect_from_port_20=YES
# If you want, you can arrange for uploaded anonymous files to be owned by
# a different user. Note! Using "root" for uploaded files is not
# recommended!
#chown_uploads=YES
#chown_username=whoever
# You may override where the log file goes if you like. The default is shown
# below.
#xferlog_file=/var/log/vsftpd.log
# If you want, you can have your log file in standard ftpd xferlog format.
# Note that the default log file location is /var/log/xferlog in this case.
#xferlog_std_format=YES
# You may change the default value for timing out an idle session.
#idle_session_timeout=600
# You may change the default value for timing out a data connection.
#data_connection_timeout=120
# ftp server can use as a totally isolated and unprivileged user.
#nopriv_user=ftpsecure
# Enable this and the server will recognise asynchronous ABOR requests. Not
# recommended for security (the code is non-trivial). Not enabling it,
# however, may confuse older FTP clients.
#async_abor_enable=YES
# By default the server will pretend to allow ASCII mode but in fact ignore
# the request. Turn on the below options to have the server actually do ASCII
# mangling on files when in ASCII mode.
# Beware that on some FTP servers, ASCII support allows a denial of service
# attack (DoS) via the command "SIZE /big/file" in ASCII mode. vsftpd
# predicted this attack and has always been safe, reporting the size of the
# raw file.
# ASCII mangling is a horrible feature of the protocol.
#ascii_upload_enable=YES
#ascii_download_enable=YES
# You may fully customise the login banner string:
#ftpd_banner=Welcome to blah FTP service.
# You may specify a file of disallowed anonymous e-mail addresses. Apparently
# useful for combatting certain DoS attacks.
#deny_email_enable=YES
# (default follows)
#banned_email_file=/etc/vsftpd.banned_emails
# You may restrict local users to their home directories.  See the FAQ for
# the possible risks in this before using chroot_local_user or
# chroot_list_enable below.
chroot_local_user=YES
# You may specify an explicit list of local users to chroot() to their home
# directory. If chroot_local_user is YES, then this list becomes a list of
# users to NOT chroot().
# (Warning! chroot'ing can be very dangerous. If using chroot, make sure that
# the user does not have write access to the top level directory within the
# chroot)
#chroot_list_enable=YES
# (default follows)
#chroot_list_file=/etc/vsftpd.chroot_list
# You may activate the "-R" option to the builtin ls. This is disabled by
# default to avoid remote users being able to cause excessive I/O on large
# sites. However, some broken FTP clients such as "ncftp" and "mirror" assume
# the presence of the "-R" option, so there is a strong case for enabling it.
#ls_recurse_enable=YES
# Customization
# Some of vsftpd's settings don't fit the filesystem layout by
# default.
# This option should be the name of a directory which is empty.  Also, the
# directory should not be writable by the ftp user. This directory is used
# as a secure chroot() jail at times vsftpd does not require filesystem
# access.
secure_chroot_dir=/var/run/vsftpd/empty
# This string is the name of the PAM service vsftpd will use.
pam_service_name=vsftpd
# This option specifies the location of the RSA certificate to use for SSL
# encrypted connections.
rsa_cert_file=/etc/ssl/private/vsftpd.pem
allow_writeable_chroot=YES
Die letzte Zeile sollte das eigentlich fixen. Hast Du nach der Änderung der Config den FTP Daemon neugestartet?
Was mir spontan einfällt: welche Version ist das denn?
habs jetzt noch einmal neu gestartet, bekomme aber dann
Auflösen der IP-Adresse für domain.de
Status: Verbinde mit xxx.xxx.xxx.xxx:21...
Status: Verbindungsversuch fehlgeschlagen mit "ECONNREFUSED - Connection refused by server".
Dann bräuchten wir bitte die Version von vsftpd und die Version/Name der verwendeten Distribution.
Scheint mir so, als ob der FTP gar nicht gestartet ist. Was sagt denn der Status des Dienstes?
Es ist auf ubuntu 12.04 LTS vsftpd in der version 2.3.5 installiert
wenn ich initctl list
aufrufe zeigt mir der letzte Eintrag
vsftpd stop/waiting
auch wenn ich ihn versuche mit /etc/init.d/vsftpd start zu starten
Ich bin mir gerade nicht sicher, ob die Option zu dieser Version backportet wurde oder nicht, ich vermute aber nicht, was dann eine Erklärung für dieses Verhalten wäre.
Ich würde jetzt - am besten in einer VM testen - eine aktuellere Version des Pakets nehmen, ggfls. über ein Drittrepo und dann sehen, ob es mit dieser Konfiguration rennt.
Bei manueller Kompilierung musst Du natürlich regelmäßig nach Updates suchen aber dürfte genug zuverlässige Drittrepos geben, Ubuntu ist ja wahnsinnig beliebt.
Kill den Prozess bitte, er scheint zu hängen.
Einmal ein "ps aux", dann schauen welche PID der Prozess hat, dann ein kill -9 PID
Der scheint ja - aus welchen Gründen auch immer - festzuhängen.
Ich weiss nicht warum, aber ich hatte vor der installation ein update audgeführt (hatte das System gerade neu installiert)
Jetzt habe ich erneut ein update gemacht und es läuft ....
Danke für die Mühe die du sir gegeben hast! Finde ich echt super, dass es noch Menschen wie dich gibt!
Na dann, die besten Probleme sind die, die sich von selbst erledigen:D, viel Spaß noch mit Deinem Server.
