Update Problem Debian 6.0
bypit
Hallo
ich habe einen Debian 6.0 server
ich wollte heute ein update (über apt-get update && upgrade) machen und dann kam folgende fehlermeldung:
Nach dieser Operation werden 0 B Plattenplatz zusätzlich benutzt.
Möchten Sie fortfahren [J/n]? j
apache2.2-common (2.2.16-6+squeeze11) wird eingerichtet ...
insserv: warning: script 'K02drwebd' missing LSB tags and overrides
insserv: warning: script 'ctmilter_initd' missing LSB tags and overrides
insserv: warning: script 'kavehost' missing LSB tags and overrides
insserv: script psa-health-monitor-notificationd: service Parallels already prov        ided!
insserv: script psa-health-monitor-notificationd: service Panel already provided        !
insserv: script psa-health-monitor-notificationd: service Health already provide        d!
insserv: script psa-health-monitor-notificationd: service Monitor already provid        ed!
insserv: script psa-health-monitor-notificationd: service Notification already p        rovided!
insserv: script psa-health-monitor-notificationd: service Daemon already provide        d!
insserv: warning: script 'drwebd' missing LSB tags and overrides
insserv: There is a loop between service munin-node and ctmilter_initd if stoppe        d
insserv:  loop involving service ctmilter_initd at depth 2
insserv:  loop involving service munin-node at depth 1
insserv: Stopping ctmilter_initd depends on munin-node and therefore on system f        acility `$all' which can not be true!
insserv: Stopping kavehost depends on munin-node and therefore on system facilit        y `$all' which can not be true!
insserv: exiting now without changing boot order!
update-rc.d: error: insserv rejected the script header
dpkg: Fehler beim Bearbeiten von apache2.2-common (--configure):
 Unterprozess installiertes post-installation-Skript gab den Fehlerwert 1 zurüc        k
configured to not write apport reports
                                      dpkg: Abhängigkeitsprobleme verhindern Ko        nfiguration von apache2-mpm-prefork:
 apache2-mpm-prefork hängt ab von apache2.2-common (= 2.2.16-6+squeeze11); aber        :
  Paket apache2.2-common ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten von apache2-mpm-prefork (--configure):
 Abhängigkeitsprobleme - verbleibt unkonfiguriert
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von apache2:
 apache2 hängt ab von apache2-mpm-worker (= 2.2.16-6+squeeze11) | apache2-mpm-p        refork (= 2.2.16-6+squeeze11) | apache2-mpm-event (= 2.2.16-6+squeeze11) | apach        e2-mpm-itk (= 2.2.16-6+squeeze11); aber:
  Paket apache2-mpm-worker ist nicht installiert.
  Paket apache2-mpm-prefork ist noch nicht konfiguriert.
  Paket apache2-mpm-event ist nicht installiert.
  Paket apache2-mpm-itk ist nicht installiert.
 apache2 hängt ab von apache2.2-common (= 2.2.16-6+squeeze11); aber:
dpkg: Fehler beim Bearbeiten von apache2 (--configure):
 Abhängigkeitsprobleme -configured to not write apport reports
                                                            verbleibt unkonfigur        iert
dpkg: Abhängigkeitsprobleme verhindern Konfiguration von apache2-prefork-dev:
 apache2-prefork-dev hängt ab von apache2.2-common (= 2.2.16-6+squeeze11); aber        :
dpkg: Fehler beim Bearbeiten von apache2-prefork-dev (--configure):
bind9 (1:9.7.3.dfsg-1~squeeze9) wird eingerichtet ...
Stopping domain name service...: bind9.
Starting domain name service...: bind9.
dpkg: Fehler beim Bearbeiten von bind9 (--configure):
                                      dbus (1.2.24-4+squeeze2) wird eingerichtet        ...
Reloading system message bus config...done.
dpkg: Fehler beim Bearbeiten von dbus (--configure):
                                      dpkg: Abhängigkeitsprobleme verhindern Ko        nfiguration von libapache2-mod-php5:
 libapache2-mod-php5 hängt ab von apache2-mpm-prefork (>> 2.0.52) | apache2-mpm        -itk; aber:
 libapache2-mod-php5 hängt ab von apache2.2-common; aber:
dpkg: Fehler beim Bearbeiten von libapache2-mod-php5 (--configure):
openssh-server (1:5.5p1-6+squeeze3) wird eingerichtet ...
                                      insserv: warning: script 'K02drwebd' missi        ng LSB tags and overrides
dpkg: Fehler beim Bearbeiten von openssh-server (--configure):
                                      samba (2:3.5.6~dfsg-3squeeze9) wird einger        ichtet ...
dpkg: Fehler beim Bearbeiten von samba (--configure):
                                      dpkg: Abhängigkeitsprobleme verhindern Ko        nfiguration von ssh:
 ssh hängt ab von openssh-server; aber:
  Paket openssh-server ist noch nicht konfiguriert.
dpkg: Fehler beim Bearbeiten von ssh (--configure):
                                      Fehler traten auf beim Bearbeiten von:
 apache2.2-common
 apache2-mpm-prefork
 apache2
 apache2-prefork-dev
 bind9
 dbus
 libapache2-mod-php5
 openssh-server
 samba
 ssh
bitte um hilfe
Dein Paketmanagement ist vollkommen verbastelt. Mindestens die Quellen von Plesk passen nicht mit dem Rest, wenn nicht noch mehr.
Wie installierst du im Allgemeinen Pakete? Was für Repos benutzt du? Auf welche Versionen sind die Repos eingestellt? Benutzt du APT-Pinning?
als Paketmanager nutze ich Apt-get.
ich bin noch ein relativer anfänger in debian und kann grad nix mit dem begriff Repos anfangen. wie kann ich evtl defaults wiederherstellen wenn das verbastelt sein sollte??
Google ist dein Freund.
Du allein weißt, was du auf deinem Server angefasst hast. Du allein weißt, was du für Repos hinzugefügt hast und wo. Da du Plesk benutzt, würde ich nicht einfach die Debian-Defaults zurücksetzen, da du dir sonst in nullkommanix dein Plesk zerhaust.
