Wunderbar! Danke!
Leider gibt es auch neue Probleme...
Genau diese Datei hat das Problem verursacht.
So wie ich das mitbekommen habe, soll ein Passwort in einer solchen Datei unsicherer sein. Habe die Datei gelöscht und kann jetzt das Tuning Primer Script nach eingabe meiner root login Daten auf alle Tabellen anwenden!
Die Ausgabe sieht wie folgt aus:
- INITIAL LOGIN ATTEMPT FAILED -
Testing Stored for passwords: None Found
- RETRY LOGIN ATTEMPT FAILED -
Could not auto detect login info!
Do you have your login handy ? [y/N] : y
User: root
Password:
Would you like me to create a ~/.my.cnf file for you? [y/N] : n
- By: Matthew Montgomery -
MySQL Version 5.0.26-log i686
Uptime = 0 days 21 hrs 23 min 43 sec
Avg. qps = 6
Total Questions = 468104
Threads Connected = 1
Warning: Server has not been running for at least 48hrs.
It may not be safe to use these recommendations
http://dev.mysql.com/doc/refman/5.0/en/server-system-variables.html
Visit http://www.mysql.com/products/enterprise/advisors.html
for info about MySQL's Enterprise Monitoring and Advisory Service
SLOW QUERIES
The slow query log is NOT enabled.
Current long_query_time = 10 sec.
You have 2 out of 468118 that take longer than 10 sec. to complete
Your long_query_time may be too high, I typically set this under 5 sec.
BINARY UPDATE LOG
The binary update log is NOT enabled.
You will not be able to do point in time recovery
See http://dev.mysql.com/doc/refman/5.0/en/point-in-time-recovery.html
WORKER THREADS
Current thread_cache_size = 0
Current threads_cached = 0
Current threads_per_sec = 1
Historic threads_per_sec = 0
MAX CONNECTIONS
Current max_connections = 100
Current threads_connected = 1
Historic max_used_connections = 4
The number of used connections is 4% of the configured maximum.
You are using less than 10% of your configured max_connections.
Lowering max_connections could help to avoid an over-allocation of memory
See "MEMORY USAGE" section to make sure you are not over-allocating
MEMORY USAGE
Max Memory Ever Allocated : 28 M
Configured Max Per-thread Buffers : 268 M
Configured Max Global Buffers : 17 M
Configured Max Memory Limit : 286 M
Physical Memory : 503.00 M
KEY BUFFER
Current MyISAM index space = 3 M
Current key_buffer_size = 7 M
Key cache miss rate is 1 : 562
Key buffer fill ratio = 17.00 %
Your key_buffer_size seems to be too high.
Perhaps you can use these resources elsewhere
QUERY CACHE
Query cache is supported but not enabled
Perhaps you should set the query_cache_size
SORT OPERATIONS
Current sort_buffer_size = 2 M
Current read_rnd_buffer_size = 256 K
Sort buffer seems to be fine
JOINS
Current join_buffer_size = 132.00 K
You have had 299 queries where a join could not use an index properly
OPEN FILES LIMIT
Current open_files_limit = 1024 files
TABLE CACHE
Current table_cache value = 64 tables
You have a total of 265 tables
You have 64 open tables.
Current table_cache hit rate is 0%, while 100% of your table cache is in use
TEMP TABLES
Current max_heap_table_size = 16 M
Current tmp_table_size = 32 M
Of 24714 temp tables, 7% were created on disk
TABLE SCANS
Current read_buffer_size = 128 K
Current table scan ratio = 25 : 1
TABLE LOCKING
Current Lock Wait ratio = 1 : 139094
Your table locking seems to be fine
Alles schön und gut!
Es werden wie erwartet alle Tabellen berücksichtigt: "You have a total of 265 tables"
Da ist nun noch so einiges "rot".
Um sicher zu stellen, dass ich die richtige my.cnf anpasse habe ich erstmal sichergestellt, dass ich die richtige nehme:
# find -name my.cnf
./etc/my.cnf
Die my.cnf die unter /etc/ liegt habe ich wie folgt angepasst:
# Example MySQL config file for medium systems.
# This is for a system with little memory (32M - 64M) where MySQL plays
# an important part, or systems up to 128M where MySQL is used together with
# other programs (such as a web server)
# You can copy this file to
# /etc/my.cnf to set global options,
# mysql-data-dir/my.cnf to set server-specific options (in this
# installation this directory is /var/lib/mysql) or
# ~/.my.cnf to set user-specific options.
# In this file, you can use all long options that a program supports.
# If you want to know which options a program supports, run the program
# with the "--help" option.
# The following options will be passed to all MySQL clients
[client]
#password = your_password
port = 3306
socket = /var/lib/mysql/mysql.sock
# Here follows entries for some specific programs
# The MySQL server
[mysqld]
set-variable=local-infile=0
port = 3306
skip-locking
key_buffer = 16M
max_allowed_packet = 1M
table_cache = 300
sort_buffer_size = 512K
net_buffer_length = 8K
read_buffer_size = 256K
read_rnd_buffer_size = 512K
myisam_sort_buffer_size = 8M
#Eigene Aenderungen
long_query_time = 3
max_connections = 15
key_buffer_size = 4M
join_buffer_size = 512K
# Don't listen on a TCP/IP port at all. This can be a security enhancement,
# if all processes that need to connect to mysqld run on the same host.
# All interaction with mysqld must be made via Unix sockets or named pipes.
# Note that using this option without enabling named pipes on Windows
# (via the "enable-named-pipe" option) will render mysqld useless!
skip-networking
# Replication Master Server (default)
# binary logging is required for replication
# log-bin=mysql-bin
# required unique id between 1 and 2^32 - 1
# defaults to 1 if master-host is not set
# but will not function as a master if omitted
server-id = 1
# Replication Slave (comment out master section to use this)
# To configure this host as a replication slave, you can choose between
# two methods :
# 1) Use the CHANGE MASTER TO command (fully described in our manual) -
# the syntax is:
# CHANGE MASTER TO MASTER_HOST=<host>, MASTER_PORT=<port>,
# MASTER_USER=<user>, MASTER_PASSWORD=<password> ;
# where you replace <host>, <user>, <password> by quoted strings and
# <port> by the master's port number (3306 by default).
# Example:
# CHANGE MASTER TO MASTER_HOST='125.564.12.1', MASTER_PORT=3306,
# MASTER_USER='joe', MASTER_PASSWORD='secret';
# OR
# 2) Set the variables below. However, in case you choose this method, then
# start replication for the first time (even unsuccessfully, for example
# if you mistyped the password in master-password and the slave fails to
# connect), the slave will create a master.info file, and any later
# change in this file to the variables' values below will be ignored and
# overridden by the content of the master.info file, unless you shutdown
# the slave server, delete master.info and restart the slaver server.
# For that reason, you may want to leave the lines below untouched
# (commented) and instead use CHANGE MASTER TO (see above)
# required unique id between 2 and 2^32 - 1
# (and different from the master)
# defaults to 2 if master-host is set
# but will not function as a slave if omitted
#server-id = 2
# The replication master for this slave - required
#master-host = <hostname>
# The username the slave will use for authentication when connecting
# to the master - required
#master-user = <username>
# The password the slave will authenticate with when connecting to
# the master - required
#master-password = <password>
# The port the master is listening on.
# optional - defaults to 3306
#master-port = <port>
# binary logging - not required for slaves, but recommended
#log-bin=mysql-bin
# Point the following paths to different dedicated disks
#tmpdir = /tmp/
#log-update = /path-to-dedicated-directory/hostname
# Uncomment the following if you are using BDB tables
#bdb_cache_size = 4M
#bdb_max_lock = 10000
# Uncomment the following if you are using InnoDB tables
#innodb_data_home_dir = /var/lib/mysql/
#innodb_data_file_path = ibdata1:10M:autoextend
#innodb_log_group_home_dir = /var/lib/mysql/
#innodb_log_arch_dir = /var/lib/mysql/
# You can set .._buffer_pool_size up to 50 - 80 %
# of RAM but beware of setting memory usage too high
#innodb_buffer_pool_size = 16M
#innodb_additional_mem_pool_size = 2M
# Set .._log_file_size to 25 % of buffer pool size
#innodb_log_file_size = 5M
#innodb_log_buffer_size = 8M
#innodb_flush_log_at_trx_commit = 1
#innodb_lock_wait_timeout = 50
# The safe_mysqld script
skip-bdb
set-variable = innodb_buffer_pool_size=2M
set-variable = innodb_additional_mem_pool_size=500K
set-variable = innodb_log_buffer_size=500K
set-variable = innodb_thread_concurrency=2
[safe_mysqld]
err-log=/var/lib/mysql/mysqld.log
skip-bdb
[mysqldump]
quick
max_allowed_packet = 16M
[mysql]
no-auto-rehash
# Remove the next comment character if you are not familiar with SQL
#safe-updates
[isamchk]
key_buffer = 20M
sort_buffer_size = 20M
read_buffer = 2M
write_buffer = 2M
[myisamchk]
key_buffer = 20M
read_buffer = 2M
write_buffer = 2M
[mysqlhotcopy]
interactive-timeout
Soweit auch alles ok. Nachdem ich dann den mysql server mit
/etc/init.d/mysql force-reload
Restarting service MySQL
Shutting down service MySQL done
Starting service MySQL done
erneut gestartet habe bekomme ich bei der ausführung von dem Tuning Primer Script die gleichen Werte -> Die Konfigurationen wurden nicht übernommen.
Was ebenfalls noch ein Hinweis auf einen nicht erfolgten Neustart ist, ist die uptime Zeit des MySQL Servers
Uptime = 0 days 21 hrs 33 min 4 sec
Avg. qps = 6
Total Questions = 473255
Normalerweise werden ja solche werte nach dem Neustart auf 0 gesetzt!
Noch ein "Beweis" für einen nicht erfolgten Neustart:
/var/lib/mysql # cat mysqld.log
080411 11:05:02 mysqld started
080411 11:05:02 InnoDB: Started; log sequence number 0 43675
080411 11:05:02 [Note] /usr/sbin/mysqld: ready for connections.
Version: '5.0.26' socket: '/var/lib/mysql/mysql.sock' port: 3306 SUSE MySQL RPM
080411 11:36:14 [Note] /usr/sbin/mysqld: Normal shutdown
080411 11:36:14 InnoDB: Starting shutdown...
080411 11:36:15 InnoDB: Shutdown completed; log sequence number 0 43675
080411 11:36:15 [Note] /usr/sbin/mysqld: Shutdown complete
080411 11:36:15 mysqld ended
Oder gibt es eine andere Logdatei, die mir die starts und stops des mysql Servers angibt?
Was mache ich falsch?
Ich will eigentlich den Server nicht neustarten. Das wäre ja nicht die Grundphilosophie von Linux.
Kann es sein, dass ich da mit den falschen Rechten neu starte?
Wobei ja dann die Rückmeldung "done" etwas irreführend wäre...
Gruß,
gammla
