Temporary Problem
  • Thread starter Thread starter MaxivB
  • Start date Start date
auth.log:
Jul  3 12:28:19 server1 su[4979]: Successful su for clamav by root
Jul  3 12:28:19 server1 su[4979]: + console root:clamav
Jul  3 12:28:19 server1 su[4979]: pam_unix(su:session): session opened for user clamav by (uid=0)
Jul  3 12:28:19 server1 su[4979]: pam_unix(su:session): session closed for user clamav
Jul  3 12:28:19 server1 su[5076]: Successful su for clamav by root
Jul  3 12:28:19 server1 su[5076]: + console root:clamav
Jul  3 12:28:19 server1 su[5076]: pam_unix(su:session): session opened for user clamav by (uid=0)
Jul  3 12:28:19 server1 su[5076]: pam_unix(su:session): session closed for user clamav
Jul  3 12:28:23 server1 saslauthd[5268]: detach_tty      : master pid is: 5268
Jul  3 12:28:23 server1 saslauthd[5268]: ipc_init        : listening on socket: /var/spool/postfix/var/run/saslauthd/mux
Jul  3 12:28:32 server1 login[5387]: pam_unix(login:session): session opened for user root by LOGIN(uid=0)
Jul  3 12:28:32 server1 login[5394]: ROOT LOGIN  on 'tty1'
Jul  3 12:39:01 server1 CRON[5422]: pam_unix(cron:session): session opened for user root by (uid=0)
Jul  3 12:39:01 server1 CRON[5422]: pam_unix(cron:session): session closed for user root
Jul  3 12:41:41 server1 postfix/smtpd[5432]: sql auxprop plugin using mysql engine
Und hier die main.cf:
# is /etc/mailname.
#myorigin = /etc/mailname
smtpd_banner = $myhostname ESMTP $mail_name (Ubuntu)
biff = no
append_dot_mydomain = no
#delay_warning_time = 4h
readme_directory = /usr/share/doc/postfix
# TLS parameters
smtpd_tls_cert_file = /etc/postfix/smtpd.cert
smtpd_tls_key_file = /etc/postfix/smtpd.key
smtpd_use_tls = yes
myhostname = server1.meinesubdomain.dyndns.org
mydestination = server1.meinesubdomain.dyndns.org, localhost, localhost.localdomain
relayhost =
mynetworks = 127.0.0.0/8
mailbox_size_limit = 0
recipient_delimiter = +
inet_interfaces = all
html_directory = /usr/share/doc/postfix/html
virtual_alias_domains =
virtual_alias_maps = proxy:mysql:/etc/postfix/mysql-virtual_forwardings.cf, mysql:/etc/postfix/mysql-virtual_email2email.cf
virtual_mailbox_domains = proxy:mysql:/etc/postfix/mysql-virtual_domains.cf
virtual_mailbox_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailboxes.cf
virtual_mailbox_base = /home/vmail
virtual_uid_maps = static:5000
virtual_gid_maps = static:5000
smtpd_sasl_auth_enable = yes
smtpd_sasl_authenticated_header = yes
transport_maps = proxy:mysql:/etc/postfix/mysql-virtual_transports.cf
virtual_create_maildirsize = yes
virtual_mailbox_extended = yes
virtual_mailbox_limit_maps = proxy:mysql:/etc/postfix/mysql-virtual_mailbox_limit_maps.cf
virtual_mailbox_limit_override = yes
virtual_mailbox_limit_message = "The user you are trying to reach is over quota."
virtual_overquota_bounce = yes
proxy_read_maps = $local_recipient_maps $mydestination $virtual_alias_maps $virtual_alias_domains $virtual_mailbox_maps $virtual_mailbox_domains $relay_recipient_maps $relay_domains $canonical_maps $sender_canonical_maps $recipient_canonical_maps $relocated_maps $transport_maps $mynetworks $virtual_mailbox_limit_maps
interessant wäre ein Auszug aus /var/log/mail oder /var/log/mail.info (heißen je nach Distribution ähnlich) zu dem Zeitpunkt, an dem Du eine Mail empfängst.
Ansonsten fällt auf, dass relayhost nicht gesetzt ist. Da wirst Du mit den meisten Empfängern ziemlich Probleme bekommen, wenn Du über Deine dynamische Adresse versendest und nicht über einen Provider schickst.
An Deiner Stelle würde ich mir irgendwo ein kleines billigstes Webhosting-Paket mieten, da kannst Du dann deren SMTP-Server als Relay verwenden. Gleichzeitig kannst Du da auch ein IMAP-Postfach einrichten, dass alle Mails bekommt und sie von dort per fetchmail abholen und so in Dein lokales Mailsystem einpflegen, das habe ich früher auch so gemacht, bevor ich mir einen externen vServer gemietet habe. Das hat den Vorteil, dass die Mails auch wirklich bei Dir ankommen und nicht durch falsch ge-cachte MX-Einträge bei der dynamischen Adresse verloren gehen. Und die paar wenigen Euronen, die das pro Monat kostet, hast Du schnell mehrfach dadurch eingespart, dass der Rechner nicht permanent laufen muss. (Ich war bisher mit der 1&1-Webvisitenkarte sehr zufrieden).
