Hier erstmal die Fehlermeldung:
Libcurl ist installiert.
Was könnte denn das noch sein?
Danke
checking for curl-config... no
checking for CURL-LIB version >= 0.5.0... no
*** The curl-config script installed by CURL could not be found
*** If CURL was installed in PREFIX, make sure PREFIX/bin is in
*** your path, or set the CURL_CONFIG environment variable to the
*** full path to curl-config.
configure: error: must have libcurl installed!
Danke
