# /etc/apache2/httpd.conf
# This is the main Apache server configuration file. It contains the
# See <URL:http://httpd.apache.org/docs-2.0/> for detailed information about
# the directives.
# Based upon the default apache configuration file that ships with apache,
# which is based upon the NCSA server configuration files originally by Rob
# McCool. This file was knocked together by Peter Poeml <poeml+apache@suse.de>.
# If possible, avoid changes to this file. It does mainly contain Include
# statements and global settings that can/should be overridden in the
# configuration of your virtual hosts.
# Overview of include files, chronologically:
# httpd.conf
# |-- uid.conf . . . . . . . . . . . . . . UserID/GroupID to run under
# |-- server-tuning.conf . . . . . . . . . sizing of the server (how many processes to start, ...)
# |-- sysconfig.d/loadmodule.conf . . . . . [*] load these modules
# |-- listen.conf . . . . . . . . . . . . . IP adresses / ports to listen on
# |-- mod_log_config.conf . . . . . . . . . define logging formats
# |-- sysconfig.d/global.conf . . . . . . . [*] server-wide general settings
# |-- mod_status.conf . . . . . . . . . . . restrict access to mod_status (server monitoring)
# |-- mod_info.conf . . . . . . . . . . . . restrict access to mod_info
# |-- mod_usertrack.conf . . . . . . . . . defaults for cookie-based user tracking
# |-- mod_autoindex-defaults.conf . . . . . defaults for displaying of server-generated directory listings
# |-- mod_mime-defaults.conf . . . . . . . defaults for mod_mime configuration
# |-- errors.conf . . . . . . . . . . . . . customize error responses
# |-- ssl-global.conf . . . . . . . . . . . SSL conf that applies to default server _and all_ virtual hosts
# |-- default-server.conf . . . . . . . . . set up the default server that replies to non-virtual-host requests
# | |--mod_userdir.conf . . . . . . . . enable UserDir (if mod_userdir is loaded)
# | `--conf.d/apache2-manual?conf . . . add the docs ('?' = if installed)
# |-- sysconfig.d/include.conf . . . . . . [*] your include files
# | (for each file to be included here, put its name
# | into APACHE_INCLUDE_* in /etc/sysconfig/apache2)
# `-- vhosts.d/ . . . . . . . . . . . . . . for each virtual host, place one file here
# `-- *.conf . . . . . . . . . . . . . (*.conf is automatically included)
# Files marked [*] are created from sysconfig upon server restart: instead of
# these files, you edit /etc/sysconfig/apache2
# Filesystem layout:
# /etc/apache2/
# |-- conf.d/
# | |-- apache2-manual.conf . . . . . . . conf that comes with apache2-doc
# | |-- mod_php4.conf . . . . . . . . . . (example) conf that comes with apache2-mod_php4
# | `-- ... . . . . . . . . . . . . . . . other configuration added by packages
# |-- errors.conf
# |-- httpd.conf . . . . . . . . . . . . . top level configuration file
# |-- listen.conf
# |-- magic
# |-- mime.types -> ../mime.types
# |-- mod_info.conf
# |-- mod_perl-startup.pl
# |-- mod_userdir.conf
# |-- ssl.crl/ . . . . . . . . . . . . . . PEM-encoded X.509 Certificate Revocation Lists (CRL)
# |-- ssl.crt/ . . . . . . . . . . . . . . PEM-encoded X.509 Certificates
# |-- ssl.csr/ . . . . . . . . . . . . . . PEM-encoded X.509 Certificate Signing Requests
# |-- ssl.key/ . . . . . . . . . . . . . . PEM-encoded RSA Private Keys
# |-- ssl.prm/ . . . . . . . . . . . . . . public DSA Parameter Files
# |-- sysconfig.d/ . . . . . . . . . . . . files that are created from /etc/sysconfig/apache2
# | |-- global.conf
# | |-- include.conf
# | `-- loadmodule.conf
# |-- uid.conf
# `-- vhosts.d/ . . . . . . . . . . . . . . put your virtual host configuration (*.conf) here
# |-- vhost-ssl.template
# `-- vhost.template
### Global Environment ######################################################
# The directives in this section affect the overall operation of Apache,
# such as the number of concurrent requests.
# run under this user/group id
Include /etc/apache2/uid.conf
# - how many server processes to start (server pool regulation)
# - usage of KeepAlive
Include /etc/apache2/server-tuning.conf
# logged here. If you *do* define an error logfile for a <VirtualHost>
ErrorLog /var/log/apache2/error_log
# generated from APACHE_MODULES in /etc/sysconfig/apache2
Include /etc/apache2/sysconfig.d/loadmodule.conf
# IP addresses / ports to listen on
Include /etc/apache2/listen.conf
# predefined logging formats
Include /etc/apache2/mod_log_config.conf
# generated from global settings in /etc/sysconfig/apache2
Include /etc/apache2/sysconfig.d/global.conf
# optional mod_status, mod_info
Include /etc/apache2/mod_status.conf
Include /etc/apache2/mod_info.conf
# optional cookie-based user tracking
# read the documentation before using it!!
Include /etc/apache2/mod_usertrack.conf
# configuration of server-generated directory listings
Include /etc/apache2/mod_autoindex-defaults.conf
# associate MIME types with filename extensions
TypesConfig /etc/apache2/mime.types
DefaultType text/plain
Include /etc/apache2/mod_mime-defaults.conf
# set up (customizable) error responses
Include /etc/apache2/errors.conf
# global (server-wide) SSL configuration, that is not specific to
# any virtual host
Include /etc/apache2/ssl-global.conf
# forbid access to the entire filesystem by default
<Directory />
Options None
AllowOverride None
Order deny,allow
Deny from all
</Directory>
# use .htaccess files for overriding,
AccessFileName .htaccess
# and never show them
<Files ~ "^\.ht">
Order allow,deny
Deny from all
</Files>
# List of resources to look for when the client requests a directory
DirectoryIndex index.html index.shtml index.html.var
### 'Main' server configuration #############################################
# The directives in this section set up the values used by the 'main'
# server, which responds to any requests that aren't handled by a
# <VirtualHost> definition. These values also provide defaults for
# any <VirtualHost> containers you may define later in the file.
# All of these directives may appear inside <VirtualHost> containers,
# in which case these default settings will be overridden for the
# virtual host being defined.
Include /etc/apache2/default-server.conf
# Another way to include your own files
# The file below is generated from /etc/sysconfig/apache2,
# include arbitrary files as named in APACHE_CONF_INCLUDE_FILES and
# APACHE_CONF_INCLUDE_DIRS
Include /etc/apache2/sysconfig.d/include.conf
### Virtual server configuration ############################################
# VirtualHost: If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs-2.0/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
Include /etc/apache2/vhosts.d/*.conf
# Note: instead of adding your own configuration here, consider
# adding it in your own file (/etc/apache2/httpd.conf.local)
# putting its name into APACHE_CONF_INCLUDE_FILES in
# /etc/sysconfig/apache2 -- this will make system updates
# easier :)
## CONFIXX
Include /etc/apache2/confixx_mhost.conf
# It is imperative that this entry remain at the end of the file
## /CONFIXX
