nachdem ich auf meinem RootServer mit SUSE 9.1 den RootKit Hunter haben laufen lassen erhalte ich folgende "Sicherheitslücke" angezeigt:
In der Forensuche konnte ich das Problem so leider nicht genau finden.
* Check: SSH
Searching for sshd_config...
Found /etc/ssh/sshd_config
Checking for allowed root login... Watch out Root login possible. Possible risk!
info: No 'PermitRootLogin' entry found in file /etc/ssh/sshd_config
Hint: See logfile for more information about this issue
Checking for allowed protocols... [ Warning (SSH v1 allowed) ]
Hmm... meine sshd_config sieht so aus:
--- snip ---
#Port 22
#Protocol 2,1
#ListenAddress 0.0.0.0
#ListenAddress ::
# HostKey for protocol version 1
#HostKey /etc/ssh/ssh_host_key
# HostKeys for protocol version 2
#HostKey /etc/ssh/ssh_host_rsa_key
#HostKey /etc/ssh/ssh_host_dsa_key
#KeyRegenerationInterval 1h
#ServerKeyBits 768
# Logging
#obsoletes QuietMode and FascistLogging
#SyslogFacility AUTH
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
#PermitRootLogin yes
#StrictModes yes
#RSAAuthentication yes
#PubkeyAuthentication yes
#AuthorizedKeysFile .ssh/authorized_keys
# Change to no to disable s/key passwords
#ChallengeResponseAuthentication yes
# Kerberos options
#KerberosAuthentication no
#KerberosOrLocalPasswd yes
#KerberosTicketCleanup yes
#KerberosGetAFSToken no
# GSSAPI options
#GSSAPIAuthentication no
#GSSAPICleanupCredentials yes
#GSSAPIEnableMITMAttack no
UsePAM yes
#AllowTcpForwarding yes
#GatewayPorts no
X11Forwarding no
#X11DisplayOffset 10
#X11UseLocalhost yes
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#UsePrivilegeSeparation yes
#PermitUserEnvironment no
#Compression yes
#ClientAliveInterval 0
#ClientAliveCountMax 3
#UseDNS yes
#PidFile /var/run/sshd.pid
#MaxStartups 10
# no default banner path
#Banner /some/path
# override default of no subsystems
Subsystem sftp /usr/lib/ssh/sftp-server
Wie ich nun gelesen haben soll man das Problem mit Änderung des obigen "fett markiert" eintrages ändern können.
Oder muss ich am "Rot" markierten etwas ändern ?
Nur möcht ich mich nun nicht aussperrren !!
Was muss ich tun um das Problem zu beseitigen ?
Hoffe daher dass Ihr mir weiterhelfen könnt.
Vielen Dank.
Gruß, PHPman
* Check: SSH
--- snip ---
#Port 22
#Protocol 2,1
#ListenAddress ::
#ServerKeyBits 768
# Logging
#LogLevel INFO
# Authentication:
#LoginGraceTime 2m
#StrictModes yes
# Kerberos options
# GSSAPI options
UsePAM yes
#GatewayPorts no
X11Forwarding no
#PrintMotd yes
#PrintLastLog yes
#TCPKeepAlive yes
#UseLogin no
#Compression yes
#UseDNS yes
#MaxStartups 10
#Banner /some/path
Vielen Dank.
Gruß, PHPman
