ich habe ein Problem, mein Spamassassin macht kein autolearn, in jeder email steht autolearn=no
Woran kann dies liegen?
hier die conf:
sa-learn --dump magic gibt folgendes aus:
und ein emailheader sieht in etwa so aus...
und noch ein problem...
Warum lernt er keine emails? Waran kann dies liegen?
Danke für die hilfe, habe mich hier im Forum schon eingelesen, jedoch ohne erfolg.
greets
tj
hier die conf:
# How many hits before a message is considered spam.
required_hits 5.0
# Whether to change the subject of suspected spam
rewrite_subject 1
# Text to prepend to subject if rewrite_subject is used
subject_tag *****SPAM*****
# Encapsulate spam in an attachment
report_safe 1
# Use terse version of the spam report
use_terse_report 0
# Enable the Bayes system
use_bayes 1
bayes_path /var/spool
bayes_file_mode 777
bayes_auto_learn 1
bayes_auto_learn_threshold_spam 6.5
# Enable Bayes auto-learning
auto_learn 1
# Enable or disable network checks
skip_rbl_checks 0
use_razor2 1
use_dcc 1
use_pyzor 1
# Mail using languages used in these country codes will not be marked
# as being possibly spam in a foreign language.
ok_languages all
# Mail using locales used in these country codes will not be marked
ok_locales all
0.000 0 2 0 non-token data: bayes db version
0.000 0 10635 0 non-token data: nspam
0.000 0 907 0 non-token data: nham
0.000 0 74683 0 non-token data: ntokens
0.000 0 1177049360 0 non-token data: oldest atime
0.000 0 1200323627 0 non-token data: newest atime
0.000 0 0 0 non-token data: last journal sync atime
0.000 0 1178179062 0 non-token data: last expiry atime
0.000 0 43200 0 non-token data: last expire atime delta
0.000 0 190597 0 non-token data: last expire reduction count
X-Spam-Level:
X-Spam-Status: No, hits=-4.9 required=5.0 tests=BAYES_00 autolearn=no
version=2.64
X-Spam-Checker-Version: SpamAssassin 2.64 (2004-01-11) on
X-UIDL: <6n"!Np^"!Dh2"!D'f"!
spamassassin --lint
Failed to parse line in SpamAssassin configuration, skipping: loadplugin FuzzyOc r FuzzyOcr.pm
Failed to parse line in SpamAssassin configuration, skipping: focr_word stock
Failed to parse line in SpamAssassin configuration, skipping: focr_word investor
Failed to parse line in SpamAssassin configuration, skipping: focr_word internat ional
Failed to parse line in SpamAssassin configuration, skipping: focr_word company
Failed to parse line in SpamAssassin configuration, skipping: focr_word money
Failed to parse line in SpamAssassin configuration, skipping: focr_word million
Failed to parse line in SpamAssassin configuration, skipping: focr_word thousand
Failed to parse line in SpamAssassin configuration, skipping: focr_word buy
Failed to parse line in SpamAssassin configuration, skipping: focr_word price
Failed to parse line in SpamAssassin configuration, skipping: focr_word trade
Failed to parse line in SpamAssassin configuration, skipping: focr_word banking
Failed to parse line in SpamAssassin configuration, skipping: focr_word service
Failed to parse line in SpamAssassin configuration, skipping: focr_word kunde
Failed to parse line in SpamAssassin configuration, skipping: focr_word volksban k
Failed to parse line in SpamAssassin configuration, skipping: focr_word sparkass e
Failed to parse line in SpamAssassin configuration, skipping: focr_word software
Failed to parse line in SpamAssassin configuration, skipping: focr_word viagra
Failed to parse line in SpamAssassin configuration, skipping: focr_word cialis
Failed to parse line in SpamAssassin configuration, skipping: focr_word levitra
Failed to parse line in SpamAssassin configuration, skipping: focr_word medicine
Failed to parse line in SpamAssassin configuration, skipping: focr_word legal
Failed to parse line in SpamAssassin configuration, skipping: focr_word medicati on
Failed to parse line in SpamAssassin configuration, skipping: focr_word click he re
Failed to parse line in SpamAssassin configuration, skipping: focr_word penis
Failed to parse line in SpamAssassin configuration, skipping: focr_word growth
Failed to parse line in SpamAssassin configuration, skipping: focr_word drugs
Failed to parse line in SpamAssassin configuration, skipping: focr_word pharmacy
Failed to parse line in SpamAssassin configuration, skipping: focr_tmp_path /tmp
Failed to run FUZZY_OCR_CORRUPT_IMG SpamAssassin test, skipping:
(Can't locate object method "dummy_check" via package "Mail::SpamAssassi n:erMsgStatus" at /usr/lib/perl5/vendor_perl/5.8.1/Mail/SpamAssassin/PerMsgSta tus.pm line 2293.
Failed to run FUZZY_OCR SpamAssassin test, skipping:
(Can't locate object method "check_fuzzy_ocr" via package "Mail::SpamAss assin:erMsgStatus" at /usr/lib/perl5/vendor_perl/5.8.1/Mail/SpamAssassin/PerMs gStatus.pm line 2293.
Failed to run FUZZY_OCR_WRONG_CTYPE SpamAssassin test, skipping:
greets
tj
