Jan 11 19:59:37 AAB20848-04 courierpop3login: Connection, ip=[::ffff:127.0.0.1]
Jan 11 19:59:37 AAB20848-04 courierpop3login: Disconnected, ip=[::ffff:127.0.0.1]
Jan 11 19:59:37 AAB20848-04 imapd: Connection, ip=[::ffff:127.0.0.1]
Jan 11 19:59:37 AAB20848-04 imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Jan 11 19:59:40 AAB20848-04 courierpop3login: Connection, ip=[::ffff:127.0.0.1]
Jan 11 19:59:40 AAB20848-04 courierpop3login: Disconnected, ip=[::ffff:127.0.0.1]
Jan 11 19:59:40 AAB20848-04 imapd: Connection, ip=[::ffff:127.0.0.1]
Jan 11 19:59:40 AAB20848-04 imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Jan 11 19:59:55 AAB20848-04 courierpop3login: Connection, ip=[::ffff:127.0.0.1]
Jan 11 19:59:55 AAB20848-04 courierpop3login: Disconnected, ip=[::ffff:127.0.0.1]
Jan 11 19:59:55 AAB20848-04 imapd: Connection, ip=[::ffff:127.0.0.1]
Jan 11 19:59:55 AAB20848-04 imapd: Disconnected, ip=[::ffff:127.0.0.1], time=0
Jan 11 20:00:24 AAB20848-04 courierpop3login: Connection, ip=[::ffff:xx.xxxx.22.182]
Jan 11 20:00:24 AAB20848-04 courierpop3login: LOGIN, user=info@xxxxxx.de, ip=[::ffff:xx.xxxx.22.182]
Jan 11 20:00:25 AAB20848-04 courierpop3login: LOGOUT, user=info@xxxxxx.de, ip=[::ffff:xx.xxxx.22.182], top=0, retr=0, rcvd=12, sent=39, ti
me=1
Jan 11 20:01:28 AAB20848-04 courierpop3login: Connection, ip=[::ffff:xx.xxxx.22.182]
Jan 11 20:01:28 AAB20848-04 courierpop3login: LOGIN, user=info@xxxxxx.de, ip=[::ffff:xx.xxxx.22.182]
Jan 11 20:01:28 AAB20848-04 courierpop3login: LOGOUT, user=info@xxxxxx.de, ip=[::ffff:xx.xxxx.22.182], top=0, retr=0, rcvd=12, sent=39, ti
me=0
Jan 11 16:15:11AAB20848-04 postfix/master[19607]: warning: /usr/lib/postfix/anvil: bad command startup -- throttling
Jan 11 16:15:39AAB20848-04 master[18315]: fatal: master_spawn: exec /usr/lib/postfix/trivial-rewrite: Cannot allocate memory
Jan 11 16:15:40AAB20848-04 postfix/master[19607]: warning: process /usr/lib/postfix/trivial-rewrite pid 18315 exit status 1
Jan 11 16:15:40AAB20848-04 postfix/master[19607]: warning: /usr/lib/postfix/trivial-rewrite: bad command startup -- throttling
Jan 11 16:15:58AAB20848-04 courierpop3login: exec(/usr/lib/courier/courier/courierpop3d) failed!!
Jan 11 16:16:10AAB20848-04 master[18423]: fatal: master_spawn: exec /usr/lib/postfix/smtpd: Cannot allocate memory
Jan 11 16:16:11AAB20848-04 postfix/master[19607]: warning: master_spawn: fork: Cannot allocate memory -- throttling
Jan 11 16:16:11AAB20848-04 postfix/master[19607]: warning: process /usr/lib/postfix/smtpd pid 18423 exit status 1
Jan 11 16:16:11AAB20848-04 postfix/master[19607]: warning: /usr/lib/postfix/smtpd: bad command startup -- throttling
Jan 11 16:16:40AAB20848-04 postfix/master[19607]: warning: master_spawn: fork: Cannot allocate memory -- throttling
Jan 11 16:17:11AAB20848-04 postfix/master[19607]: warning: master_spawn: fork: Cannot allocate memory -- throttling
Jan 11 16:18:11AAB20848-04 last message repeated 3 times
Jan 11 16:34:27AAB20848-04 postfix/smtpd[25982]: warning: 222.252.219.154: address not listed for hostname localhost
Jan 11 17:04:36AAB20848-04 postfix/master[3098]: warning: master_spawn: fork: Cannot allocate memory -- throttling
Jan 11 17:27:49AAB20848-04 postfix[18172]: fatal: /etc/postfix/main.cf, line 21: missing '=' after attribute name: "???#?"
Jan 11 17:28:33AAB20848-04 postgrey[21597]: 2009/01/11-17:28:33 Pid_file already exists for running process (20218)... aborting at line
298 in file /usr/share/perl5/Net/Server.pm
Jan 11 19:18:25AAB20848-04 postfix/sendmail[5672]: fatal: /etc/postfix/main.cf, line 21: missing '=' after attribute name: "???#?"
Jan 11 19:30:38AAB20848-04 postgrey[11609]: 2009/01/11-19:30:38 Pid_file already exists for running process (9762)... aborting at line
Jan 11 19:31:17AAB20848-04 postgrey[11673]: 2009/01/11-19:31:17 Pid_file already exists for running process (11647)... aborting at line
Jan 11 19:31:35AAB20848-04 postfix/policyd-weight[11681]: Couldn't remove /var/run/policyd-weight.pid, a process with pid 9757 exists! Use
"restart" to force.
Jan 11 19:31:35AAB20848-04 postfix/policyd-weight[11681]: err: Couldn't remove /var/run/policyd-weight.pid, a process with pid 9757 exists
! Use "restart" to force.
Jan 11 19:31:44AAB20848-04 postfix/policyd-weight[11691]: Couldn't remove /var/run/policyd-weight.pid, a process with pid 9757 exists! Use
"restart" to force.
Jan 11 19:31:44AAB20848-04 postfix/policyd-weight[11691]: err: Couldn't remove /var/run/policyd-weight.pid, a process with pid 9757 exists
Jan 11 20:03:40AAB20848-04 postgrey[18019]: 2009/01/11-20:03:40 Pid_file already exists for running process (11647)... aborting at line
Jan 11 21:11:07AAB20848-04 postfix/sendmail[32137]: fatal: /etc/postfix/main.cf, line 21: missing '=' after attribute name: "???#?"
Jan 11 21:18:38AAB20848-04 postfix[32721]: fatal: /etc/postfix/main.cf, line 21: missing '=' after attribute name: "???#?"
# ispCP ω (OMEGA) a Virtual Hosting Control System
# @copyright 2001-2006 by moleSoftware GmbH
# @copyright 2006-2008 by ispCP | http://isp-control.net
# @version SVN: $Id$
# @link http://isp-control.net
# @author ispCP Team
# @license
# This program is free software; you can redistribute it and/or modify it under
# the terms of the MPL General Public License as published by the Free Software
# Foundation; either version 1.1 of the License, or (at your option) any later
# version.
# You should have received a copy of the MPL Mozilla Public License along with
# this program; if not, write to the Open Source Initiative (OSI)
# http://opensource.org | osi@opensource.org
# Postfix directory settings; These are critical for normal Postfix MTA functionallity
command_directory = /usr/sbin
# Some common configuration parameters
inet_interfaces = all
mynetworks_style = host
myhostname = xxxxxxxxxx.de
mydomain = xxxxxxxxxx.de.local
myorigin = $myhostname
smtpd_banner = $myhostname ESMTP ispCP 1.0.0 RC7 OMEGA Managed
setgid_group = postdrop
# Receiving messages parameters
mydestination = $myhostname, $mydomain
append_dot_mydomain = no
append_at_myorigin = yes
local_transport = local
virtual_transport = virtual
transport_maps = hash:/etc/postfix/ispcp/transport
# Delivering local messages parameters
# Mailboxquota
# => 0 for unlimited
# => 104857600 for 100 MB
mailbox_size_limit = 0
# Message size limit
message_size_limit = 0
biff = no
recipient_delimiter = +
local_destination_recipient_limit = 1
local_recipient_maps = unix:passwd.byname $alias_database
# ispCP Autoresponder parameters
ispcp-arpl_destination_recipient_limit = 1
# Delivering virtual messages parameters
virtual_mailbox_base = /var/mail/virtual
virtual_mailbox_limit = 0
virtual_mailbox_domains = hash:/etc/postfix/ispcp/domains
virtual_mailbox_maps = hash:/etc/postfix/ispcp/mailboxes
virtual_alias_maps = hash:/etc/postfix/ispcp/aliases
virtual_minimum_uid = 1000
virtual_uid_maps = static:1000
virtual_gid_maps = static:8
# SASL paramters
smtpd_sasl_auth_enable = yes
smtpd_sasl_local_domain =
smtpd_helo_required = yes
smtpd_helo_restrictions = permit_mynetworks,
permit_sasl_authenticated,
reject_invalid_helo_hostname,
reject_non_fqdn_helo_hostname
smtpd_sender_restrictions = reject_non_fqdn_sender,
reject_unknown_sender_domain,
permit_mynetworks,
smtpd_recipient_restrictions = reject_non_fqdn_recipient,
reject_unknown_recipient_domain,
permit_mynetworks,
reject_unauth_destination,
reject_unlisted_recipient,
check_policy_service inet:127.0.0.1:12525,
check_policy_service inet:127.0.0.1:60000,
permit
smtpd_data_restrictions = reject_multi_recipient_bounce,
reject_unauth_pipelining
# TLS parameters; activate, if avaible/used
#smtpd_use_tls = yes
#smtpd_tls_loglevel = 2
#smtpd_tls_cert_file = /etc/postfix/cert.pem
#smtpd_tls_key_file = /etc/postfix/privkey.pem
#smtpd_tls_auth_only = no
#smtpd_tls_received_header = yes
# AMaViS parameters; activate, if available/used
#content_filter = amavis:[127.0.0.1]:10024
# Quota support; activate, if available/used
#virtual_create_maildirsize = yes
#virtual_mailbox_extended = yes
#virtual_mailbox_limit_maps = mysql:/etc/postfix/mysql_virtual_mailbox_limit_maps.cf
#virtual_mailbox_limit_override = yes
#virtual_maildir_limit_message = "The user you're trying to reach is over mailbox quota."
#virtual_overquota_bounce = yes
Welcher Mail-Server?Ich habe ein problem mit dem SMTP server
Heißt was genau? Getestet mit welchem Client, welche Fehlermeldung? Schon per Telnet versucht eine Verbindung herzustellen?der ist down
Schon mal einen manuellen Start auf der Console probiert?selbst nach serverneustart geht er nicht
Schau mal in Zeile 21 nach.fatal: /etc/postfix/main.cf, line 21: missing '=' after attribute name: "???#?"
Das ist ein ernsthaftes Problem.master_spawn: fork: Cannot allocate memory -- throttling
/etc/init.d/postfix start
Starting Postfix Mail Transport Agent: postfixpostconf: fatal: /etc/postfix/main.cf, line 20: missing '=' after attribute name: "???#?"
