Sind diese SMART-Werte in Ordnung?
  • Thread starter Thread starter Deleted member 11691
  • Start date Start date
D
Wollte 'mal nachfragen, ob diese SMART-Werte in Ordnung sind oder ob ich mir doch Gedanken machen soll, stündlich ein Backup zu machen... Ich weiß leider nicht, wie gute/schlechte Werte aussehen und sehe mir so etwas sehr selten an aber bei OVH bzw. IsGenug muss ich dann doch noch in die Runde nachfragen. Vielen Dank für jegliche Informationen.
smartctl 5.40 2010-07-12 r3124 [x86_64-unknown-linux-gnu] (local build)
Copyright (C) 2002-10 by Bruce Allen, http://smartmontools.sourceforge.net
=== START OF INFORMATION SECTION ===
Device Model:     Hitachi HDS723020BLA642
Serial Number:    MN1220F32UE3JD
Firmware Version: MN6OA5C0
User Capacity:    2,000,398,934,016 bytes
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   8
ATA Standard is:  ATA-8-ACS revision 4
Local Time is:    Mon Apr 30 21:07:59 2012 CEST
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84)	Offline data collection activity
					was suspended by an interrupting command from host.
					Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					without error or no self-test has ever
					been run.
Total time to complete Offline
data collection: 		 (19092) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					Auto Offline data collection on/off support.
					Suspend Offline collection upon new
					command.
					Offline surface scan supported.
					Self-test supported.
					No Conveyance Self-test supported.
					Selective Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
					Supports SMART auto save timer.
Error logging capability:        (0x01)	Error logging supported.
					General Purpose Logging supported.
Short self-test routine
recommended polling time: 	 (   1) minutes.
Extended self-test routine
recommended polling time: 	 ( 255) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Error Recovery Control supported.
					SCT Feature Control supported.
					SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   016    Pre-fail  Always       -       65536
  2 Throughput_Performance  0x0005   134   134   054    Pre-fail  Offline      -       88
  3 Spin_Up_Time            0x0007   138   138   024    Pre-fail  Always       -       414 (Average 416)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       29
  5 Reallocated_Sector_Ct   0x0033   100   100   005    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   100   100   067    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   135   135   020    Pre-fail  Offline      -       26
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       2456
 10 Spin_Retry_Count        0x0013   100   100   060    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       29
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       31
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       31
194 Temperature_Celsius     0x0002   133   133   000    Old_age   Always       -       45 (Lifetime Min/Max 19/48)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%       102         -
# 2  Short offline       Completed without error       00%        90         -
# 3  Short offline       Completed without error       00%        90         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
Keine "Reallocated Sectors", keine Offline-Sektoren und keine "Pending Sectors" - es sieht nicht danach aus, als wenn die Platte in kürzester Zeit stirbt ;)
