Jul 28 20:49:01 donau094 sendmail[17262]: j6SIn1w7017262: Saved message in /var/log/dead.letter
Jul 28 20:49:01 donau094 sendmail[17277]: AUTH=server, relay=localhost [127.0.0.1], authid=web1p1, mech=LOGIN, bits=0
Jul 28 20:49:02 donau094 sendmail[17277]: j6SImxF9017277: from=<kolsms@rumail.de>, size=632, class=0, nrcpts=1, msgid=<200507281849.j6SImxF9017277@donau094.server4you.de>, proto=SMTP, daemon=MTA, relay=localhost [127.0.0.1]
Jul 28 20:49:02 donau094 popper[17283]: Stats: web1p1 1 26224 0 0 donau094.server4you.de 62.75.204.159 [pop_updt.c:296]
Jul 28 20:49:04 donau094 sendmail[17280]: j6SImxF9017277: to=<info@forum-hoster.de>, ctladdr=<kolsms@rumail.de> (637/107), delay=00:00:02, xdelay=00:00:02, mailer=esmtp, pri=120632, relay=mail.forum-hoster.de. [80.190.246.93], dsn=2.0.0, stat=Sent (Ok: queued as 783F51806BD)
Jul 28 20:50:03 donau094 sendmail[17382]: alias database /etc/aliases rebuilt by root
Jul 28 20:50:03 donau094 sendmail[17382]: /etc/aliases: 0 aliases, longest 0 bytes, 0 bytes total
Jul 28 20:50:03 donau094 sendmail-client[16435]: persistent queue runner control process: lost all children: wait returned ECHILD
Jul 28 20:50:03 donau094 sendmail-client[17397]: starting daemon (8.13.1): persistent-queueing@00:01:00
Jul 28 20:50:03 donau094 sendmail[17368]: j6SIo3rH017368: from=root, size=343, class=0, nrcpts=1, msgid=<200507281850.j6SIo3rH017368@donau094.server4you.de>, relay=root@localhost
Jul 28 20:50:03 donau094 sendmail[17368]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:50:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:00:05, xdelay=00:00:00, mailer=relay, pri=120343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:51:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:01:05, xdelay=00:00:00, mailer=relay, pri=210343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:52:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:02:05, xdelay=00:00:00, mailer=relay, pri=300343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:53:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:03:05, xdelay=00:00:00, mailer=relay, pri=390343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:54:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:04:05, xdelay=00:00:00, mailer=relay, pri=480343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:55:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:05:05, xdelay=00:00:00, mailer=relay, pri=570343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:56:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:06:05, xdelay=00:00:00, mailer=relay, pri=660343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:57:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:07:05, xdelay=00:00:00, mailer=relay, pri=750343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:58:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:08:05, xdelay=00:00:00, mailer=relay, pri=840343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 20:59:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:09:05, xdelay=00:00:00, mailer=relay, pri=930343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 21:00:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:10:05, xdelay=00:00:00, mailer=relay, pri=1020343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
Jul 28 21:01:08 donau094 sendmail-client[17398]: j6SIo3rH017368: to=root, ctladdr=root (0/0), delay=00:11:05, xdelay=00:00:00, mailer=relay, pri=1110343, relay=[127.0.0.1] [127.0.0.1], dsn=4.0.0, stat=Deferred: Connection refused by [127.0.0.1]
