Ich habe auf meinen Ubuntu vServer einen Samba Server eingerichtet und mit Benutzer und guten Passwort angelegt, der Zugriff klappt von T-Com, Alice, Vodafone, Unitymedia.
Mein Problem besteht darin das ich einen Congstar Anschluss habe und leider mein Router die Ports nicht weiter mappen tut.
Als ersten Lösung Vorgang habe ich angesehen die Ports höher zu legen da meine vermutung ist das Sie von der Box geblockt werden, leider blieb das ohne Erfolg.
Ich wäre dankbar wenn mir einer da weiterhelfen könnte im Anhang seht ihr die Router Einstellungen aber erstmal hier die smb.conf:
lsof -ni wirft folgendes aus:
# Sample configuration file for the Samba suite for Debian GNU/Linux.
# This is the main Samba configuration file. You should read the
# smb.conf(5) manual page in order to understand the options listed
# here. Samba has a huge number of configurable options most of which
# are not shown in this example
# Some options that are often worth tuning have been included as
# commented-out examples in this file.
# - When such options are commented with ";", the proposed setting
# differs from the default Samba behaviour
# - When commented with "#", the proposed setting is the default
# behaviour of Samba but the option is considered important
# enough to be mentioned here
# NOTE: Whenever you modify this file you should run the command
# "testparm" to check that you have not made any basic syntactic
# errors.
# A well-established practice is to name the original file
# "smb.conf.master" and create the "real" config file with
# testparm -s smb.conf.master >smb.conf
# This minimizes the size of the really used smb.conf file
# which, according to the Samba Team, impacts performance
# However, use this with caution if your smb.conf file contains nested
# "include" statements. See Debian bug #483187 for a case
# where using a master file is not a good idea.
#======================= Global Settings =======================
[global]
smb ports = 3001 3002 3003
## Browsing/Identification ###
# Change this to the workgroup/NT-domain name your Samba server will part of
workgroup = WORKGROUP
# server string is the equivalent of the NT Description field
server string = %h server (Samba, Ubuntu)
# Windows Internet Name Serving Support Section:
# WINS Support - Tells the NMBD component of Samba to enable its WINS Server
# wins support = no
# WINS Server - Tells the NMBD components of Samba to be a WINS Client
# Note: Samba can be either a WINS Server, or a WINS Client, but NOT both
; wins server = w.x.y.z
# This will prevent nmbd to search for NetBIOS names through DNS.
dns proxy = no
# What naming service and in what order should we use to resolve host names
# to IP addresses
; name resolve order = lmhosts host wins bcast
#### Networking ####
# The specific set of interfaces / networks to bind to
# This can be either the interface name or an IP address/netmask;
# interface names are normally preferred
; interfaces = 127.0.0.0/8 eth0
# Only bind to the named interfaces and/or networks; you must use the
# 'interfaces' option above to use this.
# It is recommended that you enable this feature if your Samba machine is
# not protected by a firewall or is a firewall itself. However, this
# option cannot handle dynamic or non-broadcast interfaces correctly.
; bind interfaces only = yes
#### Debugging/Accounting ####
# This tells Samba to use a separate log file for each machine
# that connects
log file = /var/log/samba/log.%m
# Cap the size of the individual log files (in KiB).
max log size = 1000
# If you want Samba to only log through syslog then set the following
# parameter to 'yes'.
# syslog only = no
# We want Samba to log a minimum amount of information to syslog. Everything
# should go to /var/log/samba/log.{smbd,nmbd} instead. If you want to log
# through syslog you should set the following parameter to something higher.
syslog = 0
# Do something sensible when Samba crashes: mail the admin a backtrace
panic action = /usr/share/samba/panic-action %d
####### Authentication #######
# "security = user" is always a good idea. This will require a Unix account
# in this server for every user accessing the server. See
# /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/ServerType.html
# in the samba-doc package for details.
# security = user
# You may wish to use password encryption. See the section on
# 'encrypt passwords' in the smb.conf(5) manpage before enabling.
encrypt passwords = true
# If you are using encrypted passwords, Samba will need to know what
# password database type you are using.
passdb backend = tdbsam
obey pam restrictions = yes
# This boolean parameter controls whether Samba attempts to sync the Unix
# password with the SMB password when the encrypted SMB password in the
# passdb is changed.
unix password sync = yes
# For Unix password sync to work on a Debian GNU/Linux system, the following
# parameters must be set (thanks to Ian Kahan <<kahan@informatik.tu-muenchen.de> for
# sending the correct chat script for the passwd program in Debian Sarge).
passwd program = /usr/bin/passwd %u
passwd chat = *Enter\snew\s*\spassword:* %n\n *Retype\snew\s*\spassword:* %n\n *password\supdated\ssuccessfully* .
# This boolean controls whether PAM will be used for password changes
# when requested by an SMB client instead of the program listed in
# 'passwd program'. The default is 'no'.
pam password change = yes
# This option controls how unsuccessful authentication attempts are mapped
# to anonymous connections
map to guest = bad user
########## Domains ###########
# Is this machine able to authenticate users. Both PDC and BDC
# must have this setting enabled. If you are the BDC you must
# change the 'domain master' setting to no
; domain logons = yes
# The following setting only takes effect if 'domain logons' is set
# It specifies the location of the user's profile directory
# from the client point of view)
# The following required a [profiles] share to be setup on the
# samba server (see below)
; logon path = \\%N\profiles\%U
# Another common choice is storing the profile in the user's home directory
# (this is Samba's default)
# logon path = \\%N\%U\profile
# It specifies the location of a user's home directory (from the client
# point of view)
; logon drive = H:
# logon home = \\%N\%U
# It specifies the script to run during logon. The script must be stored
# in the [netlogon] share
# NOTE: Must be store in 'DOS' file format convention
; logon script = logon.cmd
# This allows Unix users to be created on the domain controller via the SAMR
# RPC pipe. The example command creates a user account with a disabled Unix
# password; please adapt to your needs
; add user script = /usr/sbin/adduser --quiet --disabled-password --gecos "" %u
# This allows machine accounts to be created on the domain controller via the
# SAMR RPC pipe.
# The following assumes a "machines" group exists on the system
; add machine script = /usr/sbin/useradd -g machines -c "%u machine account" -d /var/lib/samba -s /bin/false %u
# This allows Unix groups to be created on the domain controller via the SAMR
# RPC pipe.
; add group script = /usr/sbin/addgroup --force-badname %g
########## Printing ##########
# If you want to automatically load your printer list rather
# than setting them up individually then you'll need this
# load printers = yes
# lpr(ng) printing. You may wish to override the location of the
# printcap file
; printing = bsd
; printcap name = /etc/printcap
# CUPS printing. See also the cupsaddsmb(8) manpage in the
# cupsys-client package.
; printing = cups
; printcap name = cups
############ Misc ############
# Using the following line enables you to customise your configuration
# on a per machine basis. The %m gets replaced with the netbios name
# of the machine that is connecting
; include = /home/samba/etc/smb.conf.%m
# Most people will find that this option gives better performance.
# See smb.conf(5) and /usr/share/doc/samba-doc/htmldocs/Samba3-HOWTO/speed.html
# for details
# You may want to add the following on a Linux system:
# SO_RCVBUF=8192 SO_SNDBUF=8192
# socket options = TCP_NODELAY
# The following parameter is useful only if you have the linpopup package
# installed. The samba maintainer and the linpopup maintainer are
# working to ease installation and configuration of linpopup and samba.
; message command = /bin/sh -c '/usr/bin/linpopup "%f" "%m" %s; rm %s' &
# Domain Master specifies Samba to be the Domain Master Browser. If this
# machine will be configured as a BDC (a secondary logon server), you
# must set this to 'no'; otherwise, the default behavior is recommended.
# domain master = auto
# Some defaults for winbind (make sure you're not using the ranges
# for something else.)
; idmap uid = 10000-20000
; idmap gid = 10000-20000
; template shell = /bin/bash
# The following was the default behaviour in sarge,
# but samba upstream reverted the default because it might induce
# performance issues in large organizations.
# See Debian bug #368251 for some of the consequences of *not*
# having this setting and smb.conf(5) for details.
; winbind enum groups = yes
; winbind enum users = yes
# Setup usershare options to enable non-root users to share folders
# with the net usershare command.
# Maximum number of usershare. 0 (default) means that usershare is disabled.
; usershare max shares = 100
# Allow users who've been granted usershare privileges to create
# public shares, not just authenticated ones
usershare allow guests = yes
#======================= Share Definitions =======================
# Un-comment the following (and tweak the other settings below to suit)
# to enable the default home directory shares. This will share each
# user's home directory as \\server\username
;[homes]
; comment = Home Directories
; browseable = no
# By default, the home directories are exported read-only. Change the
# next parameter to 'no' if you want to be able to write to them.
; read only = yes
# File creation mask is set to 0700 for security reasons. If you want to
# create files with group=rw permissions, set next parameter to 0775.
; create mask = 0700
# Directory creation mask is set to 0700 for security reasons. If you want to
# create dirs. with group=rw permissions, set next parameter to 0775.
; directory mask = 0700
# By default, \\server\username shares can be connected to by anyone
# with access to the samba server. Un-comment the following parameter
# to make sure that only "username" can connect to \\server\username
# This might need tweaking when using external authentication schemes
; valid users = %S
# Un-comment the following and create the netlogon directory for Domain Logons
# (you need to configure Samba to act as a domain controller too.)
;[netlogon]
; comment = Network Logon Service
; path = /home/samba/netlogon
; guest ok = yes
; read only = yes
; share modes = no
# Un-comment the following and create the profiles directory to store
# users profiles (see the "logon path" option above)
# The path below should be writable by all users so that their
# profile directory may be created the first time they log on
;[profiles]
; comment = Users profiles
; path = /home/samba/profiles
; guest ok = no
; browseable = no
; create mask = 0600
[printers]
comment = All Printers
browseable = no
path = /var/spool/samba
printable = yes
guest ok = no
read only = yes
create mask = 0700
# Windows clients look for this share name as a source of downloadable
# printer drivers
[print$]
comment = Printer Drivers
path = /var/lib/samba/printers
browseable = yes
read only = yes
guest ok = no
# Uncomment to allow remote administration of Windows print drivers.
# You may need to replace 'lpadmin' with the name of the group your
# admin users are members of.
# Please note that you also need to set appropriate Unix permissions
# to the drivers directory for these users to have write rights in it
; write list = root, @lpadmin
# A sample share for sharing your CD-ROM with others.
;[cdrom]
; comment = Samba server's CD-ROM
; read only = yes
; locking = no
; path = /cdrom
; guest ok = yes
# The next two parameters show how to auto-mount a CD-ROM when the
# cdrom share is accesed. For this to work /etc/fstab must contain
# an entry like this:
# /dev/scd0 /cdrom iso9660 defaults,noauto,ro,user 0 0
# The CD-ROM gets unmounted automatically after the connection to the
# If you don't want to use auto-mounting/unmounting make sure the CD
# is mounted on /cdrom
; preexec = /bin/mount /cdrom
; postexec = /bin/umount /cdrom
[Freigabe]
public = no
writeable = yes
path = /home/freigabe
user = smb
[Bianca]
public = no
writeable = yes
path = /home/bianca
user = bianca
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
squid 1228 proxy 5u IPv4 1016165550 0t0 UDP *:49028
squid 1228 proxy 18u IPv4 1016166877 0t0 TCP 91.250.96.216:3128 (LISTEN)
squid 1228 proxy 19u IPv4 1016166878 0t0 UDP *:icpv2
named 1414 bind 20u IPv6 1016166711 0t0 TCP *:domain (LISTEN)
named 1414 bind 21u IPv4 1016166714 0t0 TCP 127.0.0.1:domain (LISTEN)
named 1414 bind 22u IPv4 1016166761 0t0 TCP 127.0.0.1:953 (LISTEN)
named 1414 bind 512u IPv6 1016166710 0t0 UDP *:domain
named 1414 bind 513u IPv4 1016166713 0t0 UDP 127.0.0.1:domain
named 1414 bind 514u IPv4 1016166763 0t0 UDP 91.250.96.216:domain
mysqld 1419 mysql 10u IPv4 1016167119 0t0 TCP *:mysql (LISTEN)
avahi-dae 1471 avahi 13u IPv4 1016167092 0t0 UDP *:mdns
avahi-dae 1471 avahi 14u IPv4 1016167093 0t0 UDP *:41364
couriertc 1480 root 5u IPv6 1016166996 0t0 TCP *:imap2 (LISTEN)
couriertc 1491 root 5u IPv6 1016167041 0t0 TCP *:imaps (LISTEN)
couriertc 1502 root 5u IPv6 1016167065 0t0 TCP *:pop3 (LISTEN)
couriertc 1514 root 5u IPv6 1016167157 0t0 TCP *:pop3s (LISTEN)
sshd 1548 root 3u IPv4 1016167365 0t0 TCP *:ssh (LISTEN)
sshd 1548 root 4u IPv6 1016167367 0t0 TCP *:ssh (LISTEN)
psa-pc-re 1579 postfix 3u IPv4 1016167674 0t0 TCP 127.0.0.1:12768 (LISTEN)
master 1688 root 106u IPv4 1016168760 0t0 TCP *:smtp (LISTEN)
master 1688 root 107u IPv6 1016168762 0t0 TCP *:smtp (LISTEN)
master 1688 root 110u IPv4 1016168768 0t0 TCP *:ssmtp (LISTEN)
master 1688 root 111u IPv6 1016168770 0t0 TCP *:ssmtp (LISTEN)
apache2 1899 root 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 1899 root 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
apache2 1900 www-data 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 1900 www-data 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
sw-cp-ser 1938 sw-cp-server 5u IPv4 1016173807 0t0 TCP 127.0.0.1:10001 (LISTEN)
sw-cp-ser 1938 sw-cp-server 6u IPv6 1016173808 0t0 TCP *:8443 (LISTEN)
sw-cp-ser 1938 sw-cp-server 7u IPv6 1016173809 0t0 TCP *:8880 (LISTEN)
DarwinStr 1963 qtss 6u IPv4 1016175192 0t0 TCP *:rtsp (LISTEN)
DarwinStr 1963 qtss 7u IPv4 1016175193 0t0 TCP *:7070 (LISTEN)
DarwinStr 1963 qtss 8u IPv4 1016175194 0t0 TCP *:8000 (LISTEN)
DarwinStr 1963 qtss 9u IPv4 1016175195 0t0 TCP *:8001 (LISTEN)
DarwinStr 1963 qtss 12u IPv4 1016176067 0t0 UDP 127.0.0.1:6970
DarwinStr 1963 qtss 13u IPv4 1016176068 0t0 UDP 127.0.0.1:6971
DarwinStr 1963 qtss 14u IPv4 1016176072 0t0 UDP 127.0.0.1:6972
DarwinStr 1963 qtss 15u IPv4 1016176073 0t0 UDP 127.0.0.1:6973
DarwinStr 1963 qtss 16u IPv4 1016176074 0t0 UDP 91.250.96.216:6970
DarwinStr 1963 qtss 17u IPv4 1016176075 0t0 UDP 91.250.96.216:6971
streaming 1970 qtss 3u IPv4 1016175310 0t0 TCP *:1220 (LISTEN)
cupsd 1999 root 6u IPv6 1016175568 0t0 TCP [::1]:ipp (LISTEN)
cupsd 1999 root 7u IPv4 1016175569 0t0 TCP 127.0.0.1:ipp (LISTEN)
verlihub 6114 root 6u IPv4 1016228129 0t0 TCP *:9999 (LISTEN)
verlihub 6114 root 7u IPv4 1034453038 0t0 TCP 91.250.96.216:9999->109.193.184.189:3530 (ESTABLISHED)
verlihub 6114 root 8u IPv4 1037075822 0t0 TCP 91.250.96.216:9999->188.26.89.127:52389 (ESTABLISHED)
verlihub 6114 root 9u IPv4 1024572695 0t0 TCP 91.250.96.216:9999->84.149.163.196:49208 (ESTABLISHED)
verlihub 6114 root 10u IPv4 1036730430 0t0 TCP 91.250.96.216:9999->178.12.136.236:61154 (ESTABLISHED)
verlihub 6114 root 11u IPv4 1034776490 0t0 TCP 91.250.96.216:9999->78.43.42.114:49275 (ESTABLISHED)
verlihub 6114 root 12u IPv4 1031273986 0t0 TCP 91.250.96.216:9999->93.113.82.252:4605 (ESTABLISHED)
verlihub 6114 root 13u IPv4 1030725190 0t0 TCP 91.250.96.216:9999->79.119.150.86:1222 (ESTABLISHED)
verlihub 6114 root 14u IPv4 1035204864 0t0 TCP 91.250.96.216:9999->87.143.31.199:25839 (ESTABLISHED)
verlihub 6114 root 18u IPv4 1030890476 0t0 TCP 91.250.96.216:9999->151.66.2.132:24659 (ESTABLISHED)
verlihub 6114 root 19u IPv4 1029509959 0t0 TCP 91.250.96.216:9999->87.78.143.15:1084 (ESTABLISHED)
verlihub 7176 root 6u IPv4 1016232432 0t0 TCP *:4500 (LISTEN)
PtokaX 7220 elite 3u IPv6 1016402458 0t0 TCP *:6110 (LISTEN)
PtokaX 7220 elite 4u IPv6 1031528228 0t0 TCP 91.250.96.216:6110->87.143.31.199:25786 (ESTABLISHED)
PtokaX 7220 elite 5u IPv6 1016449789 0t0 TCP 91.250.96.216:6110->62.141.39.161:62708 (ESTABLISHED)
PtokaX 7220 elite 7u IPv6 1024567971 0t0 TCP 91.250.96.216:6110->93.196.166.33:49805 (ESTABLISHED)
apache2 7299 www-data 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 7299 www-data 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
apache2 7308 www-data 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 7308 www-data 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
apache2 7358 www-data 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 7358 www-data 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
sshd 7923 root 3u IPv4 1031720956 0t0 TCP 91.250.96.216:ssh->79.207.116.207:23122 (ESTABLISHED)
apache2 8041 www-data 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 8041 www-data 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
sshd 9257 root 3u IPv4 1033657939 0t0 TCP 91.250.96.216:ssh->79.207.116.207:24462 (ESTABLISHED)
sshd 9339 root 3u IPv4 1033665245 0t0 TCP 91.250.96.216:ssh->79.207.116.207:24466 (ESTABLISHED)
sshd 9521 root 3u IPv4 1036366737 0t0 TCP 91.250.96.216:ssh->87.143.31.199:26912 (ESTABLISHED)
apache2 9852 www-data 4u IPv4 1016172022 0t0 TCP *:www (LISTEN)
apache2 9852 www-data 5u IPv4 1016172024 0t0 TCP *:https (LISTEN)
xinetd 10003 root 5u IPv6 1036523624 0t0 TCP *:ftp (LISTEN)
xinetd 10003 root 7u IPv6 1036523625 0t0 TCP *:poppassd (LISTEN)
smbd 10009 root 22u IPv4 1036523793 0t0 TCP *:3001 (LISTEN)
smbd 10009 root 23u IPv4 1036523796 0t0 TCP *:3002 (LISTEN)
smbd 10009 root 24u IPv4 1036523798 0t0 TCP *:3003 (LISTEN)
nmbd 10019 root 9u IPv4 1036523819 0t0 UDP *:netbios-ns
nmbd 10019 root 10u IPv4 1036523820 0t0 UDP *:netbios-dgm
nmbd 10019 root 11u IPv4 1036523822 0t0 UDP 91.250.96.216:netbios-ns
nmbd 10019 root 12u IPv4 1036523823 0t0 UDP 91.250.96.216:netbios-dgm
sshd 10044 root 3u IPv4 1037053451 0t0 TCP 91.250.96.216:ssh->87.143.31.199:27396 (ESTABLISHED)
