#soft_bounce = no
#myhostname = host.domain.tld
#myhostname = virtual.domain.tld
#mydomain = trocknerei-mahlis.de, trockmarken.de, kurzehose.de, mahlis.de
#myorigin = $myhostname
#inet_interfaces = all
#inet_interfaces = $myhostname
#inet_interfaces = $myhostname, localhost
#proxy_interfaces =
#proxy_interfaces = 1.2.3.4
#mydestination = $myhostname, localhost.$mydomain, localhost
#mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain
#mydestination = $myhostname, localhost.$mydomain, localhost, $mydomain,
# mail.$mydomain, www.$mydomain, ftp.$mydomain
#local_recipient_maps = unix:passwd.byname $alias_maps
#local_recipient_maps = proxy:unix:passwd.byname $alias_maps
#mynetworks_style = class
#mynetworks_style = host
#mynetworks = 168.100.189.0/28, 127.0.0.0/8
#mynetworks = $config_directory/mynetworks
#mynetworks = hash:/etc/postfix/network_table
#relay_domains = $mydestination
#relayhost = $mydomain
#relayhost = [gateway.my.domain]
#relayhost = [mailserver.isp.tld]
#relayhost = uucphost
#relayhost = [an.ip.add.ress]
#relay_recipient_maps = hash:/etc/postfix/relay_recipients
#in_flow_delay = 1s
#alias_maps = dbm:/etc/aliases
#alias_maps = hash:/etc/aliases
#alias_maps = hash:/etc/aliases, nis:mail.aliases
#alias_maps = netinfo:/aliases
#alias_database = dbm:/etc/aliases
#alias_database = dbm:/etc/mail/aliases
#alias_database = hash:/etc/aliases
#alias_database = hash:/etc/aliases, hash:/opt/majordomo/aliases
#home_mailbox = Mailbox
#home_mailbox = Maildir/
#mail_spool_directory = /var/spool/mail
#mailbox_command = /some/where/procmail
#mailbox_command = /some/where/procmail -a "$EXTENSION"
#mailbox_transport = lmtp:unix:/file/name
#fallback_transport = lmtp:unix:/file/name
#luser_relay = $user@other.host
#luser_relay = $local@other.host
#luser_relay = admin+$local
#header_checks = regexp:/etc/postfix/header_checks
#fast_flush_domains = $relay_domains
#smtpd_banner = $myhostname ESMTP $mail_name
#smtpd_banner = $myhostname ESMTP $mail_name ($mail_version)
#debug_peer_list = 127.0.0.1
#debug_peer_list = some.domain
debugger_command =
xxgdb $daemon_directory/$process_name $process_id & sleep 5
# readme_directory: The location of the Postfix README files.
program_directory = /usr/lib/postfix
command_directory = /usr/sbin
mailq_path = /usr/bin/mailq
default_privs = nobody
mailbox_command = /usr/lib/cyrus/bin/deliver
mailbox_transport = cyrus
fallback_transport = cyrus
local_destination_concurrency_limit = 2
default_destination_concurrency_limit = 10
debug_peer_level = 2
default_peer_level = 2
mynetworks = 192.168.1.0/24, 127.0.0.0/8
mydomain = mahlis.local
myhostname = linux.mahlis.local
myorigin = $mydomain
mail_owner = postfix
default_transport = smtp
canonical_maps = hash:/etc/postfix/canonical
setgid_group = maildrop
luser_relay = root@linux.mahlis.local
mynetworks_style = subnet
recipient_delimiter = +
html_directory = /usr/share/doc/packages/postfix/html
sample_directory = /usr/share/doc/packages/postfix/samples
readme_directory = /usr/share/doc/packages/postfix/README_FILES
inet_protocols = all
biff = no
sender_canonical_maps = hash:/etc/postfix/canonical
virtual_maps = hash:/etc/postfix/virtual
virtual_alias_maps = hash:/etc/postfix/virtual
relocated_maps = hash:/etc/postfix/relocated
sender_canonical_maps = hash:/etc/postfix/sender_canonical
masquerade_exceptions = root
masquerade_domains =
mydestination = $myhostname,localhost.$mydomain,$mydomain
defer_transports =
disable_dns_lookups = no
relayhost = 64.75.152.162
smtpd_sender_restrictions = hash:/etc/postfix/access
smtpd_client_restrictions =
smtpd_helo_required = yes
smtpd_helo_restrictions =
strict_rfc821_envelopes = no
#smtpd_recipient_restrictions = check_recipient_access hash:/etc/postfix/recipient_access
#smtpd_recipient_restrictions = permit_mynetworks,reject_unauth_destination,reject_unknown_sender_domain,reject_unkown_receipient_domain,reject_rbl_client
#maps_rbl_domains=relays.ordb.org
#smtp_sasl_auth_enable = no
#smtpd_sasl_auth_enable = no
#smtpd_use_tls = no
#smtp_use_tls = no
mailbox_size_limit = 150000000
message_size_limit = 150000000
