Qmail - Delivery Codes
misterx01
ich bin grad dabei die Logfiles zu studieren, da wieder Mal bei einen Kunden mehrere Mails nicht ankommen! Hierbei kommen immer wieder Delivery-Codes vor wo ich keinen Zusammenhang dazu finde bzw. nicht weiß was sie bedeuten!!
Vielleicht kann mir jemand kurz weiterhelfen!
delivery 456
Feb 15 08:07:05 promotion4you qmail-queue-handlers[30986]: from=xxx.kxxgl@omya.com
Feb 15 08:07:05 promotion4you qmail-queue-handlers[30986]: to=xxx@xxxademy.at
Feb 15 08:07:05 promotion4you qmail-queue-handlers[30986]: hook_dir = '/var/qmail//handlers/before-queue'
Feb 15 08:07:05 promotion4you qmail-queue-handlers[30986]: recipient[3] = 'xxx@xxxademy.at'
Feb 15 08:07:05 promotion4you qmail-queue-handlers[30986]: handlers dir = '/var/qmail//handlers/before-queue/recipient/xxx@xxxademy.at'
Feb 15 08:07:06 promotion4you qmail: 1203059225.522694 new msg 1527706
Feb 15 08:07:06 promotion4you qmail: 1203059225.522745 info msg 1527706: bytes 5064356 from <xxx.kxxgl@omya.com> qp 31748 uid 2020
Feb 15 08:07:06 promotion4you qmail-queue-handlers[30986]: starter: submitter[31748] exited normally
Feb 15 08:07:06 promotion4you qmail-local-handlers[31749]: Handlers Filter before-local for qmail started ...
Feb 15 08:07:06 promotion4you qmail: 1203059225.553830 starting delivery 456: msg 1527706 to local 24-xxx@xxxademy.at
Feb 15 08:07:06 promotion4you qmail: 1203059225.553880 status: local 1/10 remote 0/20
Feb 15 08:07:06 promotion4you qmail-local-handlers[31749]: from=xxx.kxxgl@omya.com
Feb 15 08:07:06 promotion4you qmail-local-handlers[31749]: to=xxx@xxxademy.at
Feb 15 08:07:06 promotion4you spamc[31752]: skipped message, greater than max message size (256000 bytes)
Feb 15 08:07:06 promotion4you qmail-local-handlers[31753]: Handlers Filter before-local for qmail started ...
Feb 15 08:07:06 promotion4you qmail-local-handlers[31753]: from=xxx.kxxgl@omya.com
Feb 15 08:07:06 promotion4you qmail-local-handlers[31753]: to=xxx@xxxademy.at
Feb 15 08:07:06 promotion4you qmail: 1203059226.355180 delivery 456: success: did_1+0+2/did_0+0+1/
Feb 15 08:07:06 promotion4you qmail: 1203059226.355233 status: local 0/10 remote 0/20
Feb 15 08:07:06 promotion4you qmail: 1203059226.355245 end msg 1527706
Weitere delivery-Codes: 540-559
