Proftpd schaltet sich immer aus
Bernett22
Hallo Forum,
ich weiss nicht, woran es liegt. Und zwar ist es so, dass sich mein proftpd nach 3 fehlgeschlagenen Logins sich automatisch runterfährt. Über jeden Vorschlag würde ich mich sehr freuen.
etc/init.d/proftpd status
Checking for service proftpd                                          dead
hier mal die proftpd.conf:
# This is a basic ProFTPD configuration file (rename it to
# 'proftpd.conf' for actual use.  It establishes a single server
# and a single anonymous login.  It assumes that you have a user/group
# "nobody" and "ftp" for normal operation and anon.
ServerName                      "ITXWEB"
ServerType                      standalone
DefaultServer                   on
Port                            21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask                           022
# to 30.  If you need to allow more than 30 concurrent connections
# at once, simply increase this value.  Note that this ONLY works
# (such as xinetd).
MaxInstances                    30
MaxConnectionRate               4
SocketBindTight                 off
UseReverseDNS                   off
<IfModule mod_tls.c>
TLSProtocol SSLv23
</IfModule>
# Log-Formate definieren
SystemLog                       NONE
LogFormat default               "%h %l %u %t \"%r\" %s %b"
LogFormat auth                  "%v [%P] %h %t \"%r\" %s"
LogFormat write                 "%h %l %u %t \"%r\" %s %b"
# Set the user and group under which the server will run.
User                            ftp
Group                           ftp
# To cause every FTP user to be "jailed" (chrooted) into their home
# directory, uncomment this line.
DefaultRoot ~
AllowOverwrite                  on
AllowRetrieveRestart            on
HiddenStores                    on
DeleteAbortedStores             on
AllowStoreRestart               off # widerspricht sonst "DeleteAbortedStores"
# Bar use of SITE CHMOD by default
<Limit SITE_CHMOD>
  DenyAll
</Limit>
# Login
ServerIdent                     on "FTP server ready."
DeferWelcome                    on
DisplayConnect                  /etc/proftpd.msg
IdentLookups                    off
UseFtpUsers                     off
RequireValidShell               off
TimeoutLogin                    60
MaxLoginAttempts                3
MaxClientsPerHost               3
# Session
DenyFilter \*.*/
ListOptions "-An +R" strict
UseGlobbing                     off
ShowSymlinks                    on
TimesGMT                        on
# Timeouts
TimeoutIdle                     600 # Inaktivitaet
TimeoutNoTransfer               3600 # keine Datenuebertragung (Listing, File, ...)
TimeoutStalled                  300 # haengende Datenuebertragung
TimeoutSession                  7200 # Gesamtdauer einer Session
# We want 'welcome.msg' displayed at login, and '.message' displayed
# in each newly chdired directory.
DisplayLogin                    welcome.msg
DisplayChdir                    .message
AllowOverride                   off
# TLS
TLSEngine                       on
TLSLog                          /var/log/proftpd/proftpd_tls.log
TLSRequired                     off
TLSVerifyClient                 off
TLSRSACertificateFile           /usr/local/etc/ftpcert/host.cert
TLSRSACertificateKeyFile        /usr/local/etc/ftpcert/host.key
beste Grüße
Habe mich gerade extra mit einem falschen PW versucht anzumelden. Nach dem ersten, fehlgeschlagenen Versuch, ist der Proftpd down.... verstehe ich nicht
Noch ein kleiner Hinweis. Wenn ich mich, statt mit FileZilla, mit dem Internet Explorer ( ftp://ipadresse ) verbinden möchte, ist der Proftpd auch sofort auf Status dead.
Auszug aus der proftpd.log
Jun 19 17:32:12 server proftpd[32203] server.de: ProFTPD 1.3.1 (stable) (built Fri Oct 19 11:01:36 UTC 2007) standalone mode STARTUP
Jun 19 17:32:15 server proftpd[32203] server.de: ProFTPD killed (signal 15)
Jun 19 17:32:15 server proftpd[32203] server.de: ProFTPD 1.3.1 standalone mode SHUTDOWN
Jun 19 17:32:18 server proftpd[32223] server.de: ProFTPD 1.3.1 (stable) (built Fri Oct 19 11:01:36 UTC 2007) standalone mode STARTUP
Jun 19 17:32:28 server proftpd[32223] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): FTP session opened.
Jun 19 17:32:28 server proftpd[32223] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): USER mmustermann: Login successful.
Jun 19 17:32:28 server proftpd[32223] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): Preparing to chroot to directory '/home/mmustermann'
Jun 19 17:42:29 server proftpd[32223] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): FTP session idle timeout, disconnected
Jun 19 17:42:29 server proftpd[32223] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): ProFTPD 1.3.1 standalone mode SHUTDOWN
Jun 19 18:19:20 server proftpd[3378] server.de: ProFTPD 1.3.1 (stable) (built Fri Oct 19 11:01:36 UTC 2007) standalone mode STARTUP
Jun 19 18:19:26 server proftpd[3378] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): FTP session opened.
Jun 19 18:19:26 server proftpd[3378] server.de (::ffff:91.20.246.66[::ffff:91.20.246.66]): USER mmustermann (Login failed): Incorrect password.
Auszug aus der /var/log/messages
Jun 19 18:23:56 server proftpd: pam_warn(ftp:auth): function=[pam_sm_authenticate] service=[ftp] terminal=[<unknown>] user=[mmustermann] ruser=[mmustermann] rhost=[::ffff:91.20.246.66]
kann es vielleicht am User liegen, unter dem der Proftpd läuft ? Habe den ftp User genommen, der schon im System vorhanden war:
ftp:x:40:49:FTP account:/srv/ftp:/bin/bash
proftpd.conf
User                            ftp
Group                           ftp
