# This is the ProFTPD configuration file
ServerName "FTP Server"
ServerIdent on "FTP Server ready."
ServerAdmin root@localhost
ServerType standalone
#ServerType inetd
DefaultServer on
AccessGrantMsg "User %u logged in."
#DisplayConnect /etc/ftpissue
#DisplayLogin /etc/ftpmotd
#DisplayGoAway /etc/ftpgoaway
DeferWelcome off
# Use this to excude users from the chroot
DefaultRoot ~ !adm
# Use pam to authenticate (default) and be authoritative
#AuthPAMConfig proftpd
#AuthOrder mod_auth_pam.c* mod_auth_unix.c
# Do not perform ident nor DNS lookups (hangs when the port is filtered)
IdentLookups off
UseReverseDNS off
Port 21
# Umask 022 is a good standard umask to prevent new dirs and files
# from being group and world writable.
Umask 022
# Default to show dot files in directory listings
ListOptions "-a"
# See Configuration.html for these (here are the default values)
#MultilineRFC2228 off
#RootLogin off
#LoginPasswordPrompt on
#MaxLoginAttempts 3
#MaxClientsPerHost none
#AllowForeignAddress off # For FXP
# Allow to resume not only the downloads but the uploads too
AllowRetrieveRestart on
AllowStoreRestart on
# (such as xinetd)
MaxInstances 20
User nobody
Group nobody
# Disable sendfile by default since it breaks displaying the download speeds in
# ftptop and ftpwho
UseSendfile no
# This is where we want to put the pid file
ScoreboardFile /var/run/proftpd.score
# Normally, we want users to do a few things.
<Global>
AllowOverwrite yes
<Limit ALL SITE_CHMOD>
AllowAll
</Limit>
</Global>
# Define the log formats
LogFormat default "%h %l %u %t \"%r\" %s %b"
LogFormat auth "%v [%P] %h %t \"%r\" %s"
# TLS
# Explained at http://www.castaglia.org/proftpd/modules/mod_tls.html
#TLSEngine on
#TLSRequired on
#TLSRSACertificateFile /etc/pki/tls/certs/proftpd.pem
#TLSRSACertificateKeyFile /etc/pki/tls/certs/proftpd.pem
#TLSCipherSuite ALL:!ADH:!DES
#TLSOptions NoCertRequest
#TLSVerifyClient off
##TLSRenegotiate ctrl 3600 data 512000 required off timeout 300
#TLSLog /var/log/proftpd/tls.log
# SQL authentication Dynamic Shared Object (DSO) loading
# See README.DSO and howto/DSO.html for more details.
#<IfModule mod_dso.c>
# LoadModule mod_ban.c
# LoadModule mod_ifsession.c
# LoadModule mod_quotatab.c
# LoadModule mod_quotatab_file.c
# LoadModule mod_sql.c
# LoadModule mod_sql_mysql.c
# LoadModule mod_sql_postgres.c
#</IfModule>
# added by opaque for mysql
LoadModule mod_quotatab_sql.c
# The passwords in MySQL are encrypted using CRYPT
SQLAuthTypes Plaintext Crypt
SQLAuthenticate users groups
# used to connect to the database
# databasename@host database_user user_password
SQLConnectInfo ftp@localhost proftpd passwort
# Here we tell ProFTPd the names of the database columns in the "usertable"
# we want it to interact with. Match the names with those in the db
SQLUserInfo ftpuser userid passwd uid gid homedir shell
# Here we tell ProFTPd the names of the database columns in the "grouptable"
# we want it to interact with. Again the names match with those in the db
SQLGroupInfo ftpgroup groupname gid members
# set min UID and GID - otherwise these are 999 each
SQLMinID 999
# create a user's home directory on demand if it doesn't exist
SQLHomedirOnDemand on
# Update count every time user logs in
SQLLog PASS updatecount
SQLNamedQuery updatecount UPDATE "count=count+1, accessed=now() WHERE userid='%u'" ftpuser
# Update modified everytime user uploads or deletes a file
SQLLog STOR,DELE modified
SQLNamedQuery modified UPDATE "modified=now() WHERE userid='%u'" ftpuser
# User quotas
#QuotaEngine on
#QuotaDirectoryTally on
#QuotaDisplayUnits Mb
#QuotaShowQuotas on
#SQLNamedQuery get-quota-limit SELECT "name, quota_type, per_session, limit_type, bytes_in_avail, bytes_out_avail, bytes_xfer_avail, files_in_avail, files_out_avail, files_xfer_avail FROM ftpquotalimits WHERE name = '%{0}' AND quota_type = '%{1}'"
#SQLNamedQuery get-quota-tally SELECT "name, quota_type, bytes_in_used, bytes_out_used, bytes_xfer_used, files_in_used, files_out_used, files_xfer_used FROM ftpquotatallies WHERE name = '%{0}' AND quota_type = '%{1}'"
#SQLNamedQuery update-quota-tally UPDATE "bytes_in_used = bytes_in_used + %{0}, bytes_out_used = bytes_out_used + %{1}, bytes_xfer_used = bytes_xfer_used + %{2}, files_in_used = files_in_used + %{3}, files_out_used = files_out_used + %{4}, files_xfer_used = files_xfer_used + %{5} WHERE name = '%{6}' AND quota_type = '%{7}'" ftpquotatallies
#SQLNamedQuery insert-quota-tally INSERT "%{0}, %{1}, %{2}, %{3}, %{4}, %{5}, %{6}, %{7}" ftpquotatallies
#QuotaLimitTable sql:/get-quota-limit
#QuotaTallyTable sql:/get-quota-tally/update-quota-tally/insert-quota-tally
RootLogin off
RequireValidShell off
# end added by opaque
# A basic anonymous configuration, with an upload directory.
#<Anonymous ~ftp>
# User ftp
# Group ftp
# AccessGrantMsg "Anonymous login ok, restrictions apply."
# # We want clients to be able to login with "anonymous" as well as "ftp"
# UserAlias anonymous ftp
# # Limit the maximum number of anonymous logins
# MaxClients 10 "Sorry, max %m users -- try again later"
# # Put the user into /pub right after login
# #DefaultChdir /pub
# # We want 'welcome.msg' displayed at login, '.message' displayed in
# # each newly chdired directory and tell users to read README* files.
# DisplayLogin /welcome.msg
# DisplayFirstChdir .message
# DisplayReadme README*
# # Some more cosmetic and not vital stuff
# DirFakeUser on ftp
# DirFakeGroup on ftp
# # Limit WRITE everywhere in the anonymous chroot
# <Limit WRITE SITE_CHMOD>
# DenyAll
# </Limit>
# # An upload directory that allows storing files but not retrieving
# # or creating directories.
# <Directory uploads/*>
# AllowOverwrite no
# <Limit READ>
# DenyAll
# </Limit>
# <Limit STOR>
# AllowAll
# </Limit>
# </Directory>
# # Don't write anonymous accesses to the system wtmp file (good idea!)
# WtmpLog off
# # Logging for the anonymous transfers
# ExtendedLog /var/log/proftpd/access.log WRITE,READ default
# ExtendedLog /var/log/proftpd/auth.log AUTH auth
#</Anonymous>
# Configuration for mod_ban
<IfModule mod_ban.c>
BanEngine on
BanLog /var/log/proftpd/ban.log
BanTable /var/run/proftpd/ban.tab
# If the same client reaches the MaxLoginAttempts limit 2 times
# within 10 minutes, automatically add a ban for that client that
# will expire after one hour.
BanOnEvent MaxLoginAttempts 2/00:10:00 01:00:00
# Allow the FTP admin to manually add/remove bans
BanControlsACLs all allow user ftpadm
</IfModule>
