Hi @all,
Habe Probleme mit Unixbench!
Wenn ich dieser anleitung folge....
bekomme ich ab make folgene meldung:
und bei Run bekomme ich das als Ergebnis:
# wget http://members.dslextreme.com/users/...1.0-wht.tar.gz
# gunzip -dvc unixbench-4.1.0-wht.tar.gz | tar xvf -
# cd unixbench-4.1.0-wht
# make
# ./Run
uhwebxxxxx:~/unixbench-4.1.0-wht-1# make
Checking distribution of files
./pgms exists
./src exists
./testdir exists
./tmp exists
./results exists
gcc -o ./pgms/arithoh -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ffo rce-addr -fforce-mem -ffast-math -Wall -Darithoh ./src/arith.c
cc1: warning: -f[no-]force-mem is nop and option will be removed in 4.2
gcc -o ./pgms/register -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ff orce-addr -fforce-mem -ffast-math -Wall -Ddatum='register int' ./src/arith.c
gcc -o ./pgms/short -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforc e-addr -fforce-mem -ffast-math -Wall -Ddatum=short ./src/arith.c
gcc -o ./pgms/int -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce- addr -fforce-mem -ffast-math -Wall -Ddatum=int ./src/arith.c
gcc -o ./pgms/long -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce -addr -fforce-mem -ffast-math -Wall -Ddatum=long ./src/arith.c
gcc -o ./pgms/float -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforc e-addr -fforce-mem -ffast-math -Wall -Ddatum=float ./src/arith.c
gcc -o ./pgms/double -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ffor ce-addr -fforce-mem -ffast-math -Wall -Ddatum=double ./src/arith.c
gcc -o ./pgms/hanoi -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforc e-addr -fforce-mem -ffast-math -Wall ./src/hanoi.c
gcc -o ./pgms/syscall -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ffo rce-addr -fforce-mem -ffast-math -Wall ./src/syscall.c
gcc -o ./pgms/context1 -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ff orce-addr -fforce-mem -ffast-math -Wall ./src/context1.c
gcc -o ./pgms/pipe -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforce -addr -fforce-mem -ffast-math -Wall ./src/pipe.c
gcc -o ./pgms/spawn -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforc e-addr -fforce-mem -ffast-math -Wall ./src/spawn.c
gcc -o ./pgms/execl -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforc e-addr -fforce-mem -ffast-math -Wall ./src/execl.c
In file included from ./src/execl.c:32:
./src/big.c: In function 'wrapup':
./src/big.c:425: warning: implicit declaration of function 'kill'
./src/execl.c: In function 'main':
./src/execl.c:80: warning: format '%lu' expects type 'long unsigned int *', but argument 3 has type 'time_t *'
cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DHZ= -O2 -fomit-frame-pointer -ff orce-addr -fforce-mem -ffast-math -Wall dhry_1.c
cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DHZ= -O2 -fomit-frame-pointer -ff orce-addr -fforce-mem -ffast-math -Wall dhry_2.c
gcc -o ./pgms/dhry2 -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -fforc e-addr -fforce-mem -ffast-math -Wall ./src/dhry_1.o ./src/dhry_2.o
cd ./src; rm -f dhry_1.o dhry_2.o
cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DREG=register -DHZ= -O2 -fomit-fr ame-pointer -fforce-addr -fforce-mem -ffast-math -Wall dhry_1.c
cd ./src; gcc -c -DTIME -Wall -pedantic -ansi -DREG=register -DHZ= -O2 -fomit-fr ame-pointer -fforce-addr -fforce-mem -ffast-math -Wall dhry_2.c
gcc -o ./pgms/dhry2reg -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ff orce-addr -fforce-mem -ffast-math -Wall ./src/dhry_1.o ./src/dhry_2.o
gcc -o ./pgms/looper -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ffor ce-addr -fforce-mem -ffast-math -Wall ./src/looper.c
gcc -o ./pgms/fstime -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ffor ce-addr -fforce-mem -ffast-math -Wall -Dawk=1 ./src/fstime.c
./src/fstime.c: In function 'w_test':
./src/fstime.c:168: warning: implicit declaration of function 'sync'
gcc -o ./pgms/fsbuffer -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ff orce-addr -fforce-mem -ffast-math -Wall -Dawk=1 \
-DFSBUFFER ./src/fstime.c
gcc -o ./pgms/fsdisk -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-pointer -ffor ce-addr -fforce-mem -ffast-math -Wall -Dawk=1 \
-DFSDISK ./src/fstime.c
gcc -o ./pgms/whetstone-double -DTIME -Wall -pedantic -ansi -O2 -fomit-frame-poi nter -fforce-addr -fforce-mem -ffast-math -Wall -DDP -DUNIX -DUNIXBENCH ./src/wh ets.c -lm
INDEX VALUES
TEST BASELINE RESULT INDEX
Dhrystone 2 using register variables 376783.7 0.0 0.0
Double-Precision Whetstone 83.1 0.0 0.0
Execl Throughput 188.3 0.0 0.0
Pipe Throughput 111814.6 0.0 0.0
Pipe-based Context Switching 15448.6 0.0 0.0
Process Creation 569.3 0.0 0.0
Shell Scripts (8 concurrent) 44.8 0.0 0.0
System Call Overhead 114433.5 0.0 0.0
FINAL SCORE 0.0
