# VHCS proftpd config file
ServerName "<domain>"
ServerType standalone
DeferWelcome off
ShowSymlinks on
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
AllowOverwrite on
LogFormat traff "%b %u"
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayFirstChdir .message
#LsDefaultOptions "-l"
DenyFilter \*.*/
DefaultRoot ~
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
#PersistentPasswd off
Port 21
# (such as xinetd)
MaxInstances 30
User nobody
Group nogroup
<Directory /*>
Umask 022 022
AllowOverwrite on
HideNoAccess on
</Directory>
<Limit ALL>
IgnoreHidden on
</Limit>
<Global>
TransferLog /var/log/xferlog
ExtendedLog /var/log/ftp_traff.log read,write traff
PathDenyFilter "\.quota$"
</Global>
# VHCS2 Managment;
SQLAuthTypes Crypt
SQLAuthenticate on
SQLConnectInfo yyyyyyyyyyyyy@lyyyyyyyyyyyyyyyyy yyyyyyyyyyyyy yyyyyyyyyyyyyyy
SQLUserInfo ftp_users userid passwd uid gid homedir shell
SQLGroupInfo ftp_group groupname gid members
SQLMinID 2000
# VHCS2 Quota management;
QuotaEngine off
QuotaShowQuotas off
QuotaDisplayUnits Mb
SQLNamedQuery get-quota-limit SELECT "name, quota_type, per_session, limit_type, bytes_in_avail, bytes_out_avail, bytes_xfer_avail, files_in_avail, files_out_avail, files_xfer_avail FROM quotalimits WHERE name = '%{0}' AND quota_type = '%{1}'"
SQLNamedQuery get-quota-tally SELECT "name, quota_type, bytes_in_used, bytes_out_used, bytes_xfer_used, files_in_used, files_out_used, files_xfer_used FROM quotatallies WHERE name = '%{0}' AND quota_type = '%{1}'"
SQLNamedQuery update-quota-tally UPDATE "bytes_in_used = bytes_in_used + %{0}, bytes_out_used = bytes_out_used + %{1}, bytes_xfer_used = bytes_xfer_used + %{2}, files_in_used = files_in_used + %{3}, files_out_used = files_out_used + %{4}, files_xfer_used = files_xfer_used + %{5} WHERE name = '%{6}' AND quota_type = '%{7}'" quotatallies
SQLNamedQuery insert-quota-tally INSERT "%{0}, %{1}, %{2}, %{3}, %{4}, %{5}, %{6}, %{7}" quotatallies
QuotaLock /var/run/proftpd/tally.lock
QuotaLimitTable sql:/get-quota-limit
QuotaTallyTable sql:/get-quota-tally/update-quota-tally/insert-quota-tally
