debian^confixx
Ich habe vor kurzem den FTP Server gewechselt.
Von vsftpd zu Proftpd.
Hab auch die Confixx Config angepasst.
Über ein normales FTP Programm funktioniert alles.
Aber wenn man sich über den WebFTP einloggt hat man Zugriff auf den ganzen Server.
Das soll so natürlich nichts sein.
Meine proftpd Config
Hab ich irgendwas vergessen?
Mein Sys:
Debian 3.1 Sarge
Confixx 3.3 Pro.
Edit:/ Bei dem FTP Programm ist das auch so..
# /etc/proftpd.conf -- This is a basic ProFTPD configuration file.
# To really apply changes reload proftpd after modifications.
ServerName "Debian"
ServerType standalone
DeferWelcome off
MultilineRFC2228 on
DefaultServer on
ShowSymlinks on
TimeoutNoTransfer 600
TimeoutStalled 600
TimeoutIdle 1200
DisplayLogin welcome.msg
DisplayFirstChdir .message
ListOptions "-l"
DenyFilter \*.*/
# Uncomment this if you are using NIS or LDAP to retrieve passwords:
#PersistentPasswd off
# Uncomment this if you would use TLS module:
#TLSEngine on
# Uncomment this if you would use quota module:
#Quotas on
# Uncomment this if you would use ratio module:
#Ratios on
Port 21
# (such as xinetd)
MaxInstances 30
User nobody
Group nogroup
Umask 022 022
AllowOverwrite on
# Delay engine reduces impact of the so-called Timing Attack described in
# http://security.lss.hr/index.php?page=details&ID=LSS-2004-10-02
# It is on by default.
#DelayEngine off
# A basic anonymous configuration, no upload directories.
# <Anonymous ~ftp>
# User ftp
# Group nogroup
# # We want clients to be able to login with "anonymous" as well as "ftp"
# UserAlias anonymous ftp
# # Cosmetic changes, all files belongs to ftp user
# DirFakeUser on ftp
# DirFakeGroup on ftp
# RequireValidShell off
Mein Sys:
Debian 3.1 Sarge
Confixx 3.3 Pro.
