high-voltages
habe einen Debian mit vhcs2 laufen
habe auch schon einige fehler beseitig bezüglich des tmp verzeichnisses.
allerdings weis ich hier nicht wo da de fehler liegt.
Danke schon mal.
Greets
High-voltages
Warning: disk_total_space() [function.disk-total-space]: open_basedir restriction in effect. File(/Daten/Torrent) is not within the allowed path(s): (/var/www/virtual/wtorrent/:/usr/share/php/:/tmp) in /var/www/virtual/wtorrent/htdocs/cls/rtorrent.cls.php on line 310
Warning: disk_free_space() [function.disk-free-space]: open_basedir restriction in effect. File(/Daten/Torrent) is not within the allowed path(s): (/var/www/virtual/wtorrent/:/usr/share/php/:/tmp) in /var/www/virtual/wtorrent/htdocs/cls/rtorrent.cls.php on line 310
0 b/
Warning: disk_total_space() [function.disk-total-space]: open_basedir restriction in effect. File(/Daten/Torrent) is not within the allowed path(s): (/var/www/virtual/wtorrent/:/usr/share/php/:/tmp) in /var/www/virtual/wtorrent/htdocs/cls/rtorrent.cls.php on line 314
0 b
Frei:
Warning: disk_free_space() [function.disk-free-space]: open_basedir restriction in effect. File(/Daten/Torrent) is not within the allowed path(s): (/var/www/virtual/wtorrent/:/usr/share/php/:/tmp) in /var/www/virtual/wtorrent/htdocs/cls/rtorrent.cls.php on line 306
Danke schon mal.
Greets
High-voltages
