Probleme mit Onyx 17.0.17 (Nginx / Backup)
Devilkeniple
Mahlzeit zusammen, ich habe zwei Probleme. Vll hat jemand ne Spontane Ahnung. Wenn Ich ein Backup Starte, bringt er folgende Fehlermeldung!
Details zur Backup-Aufgabe 25. Jan. 2017 18:46:50
Error:
Runtime error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Warning: hosting "*******.eu"
Hosting on domain *******.eu is skipped from backup due to error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Warning: mysql "*******"
Database *******, type mysql is skipped from backup due to error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/*******/domains/*******.eu/databases/*******_1/backup_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Warning: hosting "*******.de"
Hosting on domain *******.de is skipped from backup due to error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/*******/domains/*******.de/backup_user-data_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/nehring/domains/*******.de/backup_user-data_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Warning: mysql "piwik_"
Database piwik_, type mysql is skipped from backup due to error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/piwik/domains/*******.de/databases/piwik__1/backup_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/piwik/domains/*******.de/backup_user-data_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Warning: domain "*******.de"
Server settings are skipped from backup due to error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive backup_skel_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Warning: mysql "*******_"
Database *******_, type mysql is skipped from backup due to error: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Unable to upload archive clients/*******/domains/*******.de/databases/*******__1/backup_1701251846.tgz to FTP storage: ack Broken pipe: write( 14, 'clients/*******/domains/*******.eu/backup_user-data_1701251846.tgz ' ) at /opt/psa/PMM/agents/shared/IPC/Run/IO.pm line 558.
Desweiteren hat NGINX ein Problem mit der IPv6
Konfigurieren des Webservers nicht möglich:Execution failed. Command: httpdmng Arguments: Array ( [0] => --reconfigure-all ) Details: Execution failed. Command: httpdmng Arguments: Array ( [0] => --reconfigure-server [1] => -no-restart ) Details: [2017-01-25 12:58:53] ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/nginx-config' '-t'] with exit code [1] [2017-01-25 12:58:53] ERR [util_exec] proc_close() failed ['/opt/psa/admin/bin/nginx-config' '-t'] with exit code [1] [2017-01-25 12:58:53] ERR [panel] Apache config (14853455330.59855500) generation failed: Template_Exception: nginx: [emerg] bind() to [2a03:4******]:80 failed (99: Cannot assign requested address) nginx: configuration file /etc/nginx/nginx.conf test failed file: /opt/psa/admin/plib/Template/Writer/Webserver/Abstract.php line: 75 code: 0 nginx: [emerg] bind() to [2a03:4******]:80 failed (99: Cannot assign requested address) nginx: configuration file /etc/nginx/nginx.conf test failed
Vll hat einer von euch ne Idee!
Lg
