#--AUTOMATICALLY GENERATED - DO NO EDIT!
#--MACROS
SMTP_PORT = 25
LOCAL_INTERFACES = <; 0.0.0.0.25 ; 0.0.0.0.465 ; [::0]:25 ; [::0]:465
CONFDIR = /etc/exim4
LOCAL_DOMAINS = mydomain1.de : myserver.myhoster.net : mydomain2.de : localhost
ETC_MAILNAME = myserver.myhoster.net
LOCAL_DELIVERY = mail_spool
CHECK_RCPT_LOCAL_LOCALPARTS = ^[.] : ^.*[@%!/|`#&?]
CHECK_RCPT_REMOTE_LOCALPARTS = ^[./|] : ^.*[@%!`#&?] : ^.*/\\.\\./
DKIM_ENABLE=1
DKIM_SELECTOR = mail
DKIM_PRIVATE_KEY = /etc/exim4/dkim/private.key
DKIM_CANON = relaxed
DKIM_STRICT = 1
TLS_ENABLE=1
TLS_ADVERTISE_HOSTS = *
TLS_CERTIFICATE = /etc/ssl/certs/myserver.myhoster.net.crt
TLS_PRIVATEKEY = /etc/ssl/private/myserver.myhoster.net.key
TLS_VERIFY_CERTIFICATES = ${if exists{/etc/ssl/certs/ca-certificates.crt} {/etc/ssl/certs/ca-certificates.crt} {/dev/null}}
COURIERSOCKET = /var/run/courier/authdaemon/socket
ACL_SMTP_MAIL = acl_check_mail
ACL_SMTP_RCPT = acl_check_rcpt
ACL_SMTP_DATA = acl_check_data
#--CONFIGURATION
daemon_smtp_ports = SMTP_PORT
local_interfaces = LOCAL_INTERFACES
domainlist local_domains = LOCAL_DOMAINS
qualify_domain = ETC_MAILNAME
gecos_pattern = ^([^,:]*)
gecos_name = $1
acl_smtp_mail = ACL_SMTP_MAIL
acl_smtp_rcpt = ACL_SMTP_RCPT
acl_smtp_data = ACL_SMTP_DATA
# spamd_address = 127.0.0.1 783
local_from_check = false
local_sender_retain = true
untrusted_set_sender = *
ignore_bounce_errors_after = 2d
timeout_frozen_after = 7d
freeze_tell = postmaster
spool_directory = /var/spool/exim4
trusted_users = uucp
.ifdef TLS_ENABLE
tls_on_connect_ports = 465
tls_advertise_hosts = TLS_ADVERTISE_HOSTS
tls_certificate = TLS_CERTIFICATE
tls_privatekey = TLS_PRIVATEKEY
tls_verify_certificates = TLS_VERIFY_CERTIFICATES
.endif
begin acl
acl_check_mail:
.ifdef CHECK_MAIL_HELO_ISSUED
deny
message = no HELO given before MAIL command
condition = ${if def:sender_helo_name {no}{yes}}
.endif
accept
acl_check_rcpt:
accept
hosts = :
control = dkim_disable_verify
.ifdef CHECK_RCPT_LOCAL_LOCALPARTS
deny
domains = +local_domains
local_parts = CHECK_RCPT_LOCAL_LOCALPARTS
message = restricted characters in address
.endif
.ifdef CHECK_RCPT_REMOTE_LOCALPARTS
deny
domains = !+local_domains
local_parts = CHECK_RCPT_REMOTE_LOCALPARTS
.endif
accept
.ifndef CHECK_RCPT_POSTMASTER
local_parts = postmaster
.else
local_parts = CHECK_RCPT_POSTMASTER
.endif
.ifdef CHECK_RCPT_VERIFY_SENDER
deny
message = Sender verification failed
!verify = sender
.endif
accept
authenticated = *
control = submission/sender_retain
require
message = relay not permitted
require
verify = recipient
.ifdef CHECK_RCPT_SPF
deny
message = [SPF] $sender_host_address is not allowed to send mail from \
${if def:sender_address_domain {$sender_address_domain}{$sender_helo_name}}. \
Please see \
http://www.openspf.org/Why?scope=${if def:sender_address_domain \
{mfrom}{helo}};identity=${if def:sender_address_domain \
{$sender_address}{$sender_helo_name}};ip=$sender_host_address
log_message = SPF check failed.
condition = ${run{/usr/bin/spfquery.mail-spf-perl --ip \
\"$sender_host_address\" --identity \
{--scope mfrom --identity \"$sender_address\"}\
{--scope helo --identity \"$sender_helo_name\"}}}\
{no}{${if eq {$runrc}{1}{yes}{no}}}}
defer
message = Temporary DNS error while checking SPF record. Try again later.
condition = ${if eq {$runrc}{5}{yes}{no}}
warn
condition = ${if <={$runrc}{6}{yes}{no}}
add_header = Received-SPF: ${if eq {$runrc}{0}{pass}\
{${if eq {$runrc}{2}{softfail}\
{${if eq {$runrc}{3}{neutral}\
{${if eq {$runrc}{4}{permerror}\
{${if eq {$runrc}{6}{none}{error}}}}}}}}}\
} client-ip=$sender_host_address; \
{envelope-from=${sender_address}; }{}}\
helo=$sender_helo_name
warn
log_message = Unexpected error in SPF check.
condition = ${if >{$runrc}{6}{yes}{no}}
.endif
.ifdef CHECK_RCPT_IP_DNSBLS
warn
dnslists = CHECK_RCPT_IP_DNSBLS
add_header = X-Warning: $sender_host_address is listed at $dnslist_domain ($dnslist_value: $dnslist_text)
log_message = $sender_host_address is listed at $dnslist_domain ($dnslist_value: $dnslist_text)
.endif
.ifdef CHECK_RCPT_DOMAIN_DNSBLS
warn
!senders = ${if exists{CONFDIR/local_domain_dnsbl_whitelist}\
dnslists = CHECK_RCPT_DOMAIN_DNSBLS
add_header = X-Warning: $sender_address_domain is listed at $dnslist_domain ($dnslist_value: $dnslist_text)
log_message = $sender_address_domain is listed at $dnslist_domain ($dnslist_value: $dnslist_text)
.endif
accept
acl_check_data:
deny
message = Message headers fail syntax check
!verify = header_syntax
accept
begin routers
vforward:
debug_print = "R: vforward for $local_part@$domain"
driver = redirect
allow_defer
allow_fail
file = /etc/exim.forward/$local_part@$domain
file_transport = address_file
pipe_transport = address_pipe
vdomain:
debug_print = "R: vdomain for $local_part@$domain"
driver = accept
domains = dsearch;/etc/exim.domains
local_parts = lsearch;/etc/exim.domains/$domain
transport = vmail
dnslookup:
debug_print = "R: dnslookup for $local_part@$domain"
driver = dnslookup
domains = ! +local_domains
transport = remote_smtp
headers_remove = received
same_domain_copy_routing = yes
ignore_target_hosts = 0.0.0.0 : 127.0.0.0/8 : 192.168.0.0/16 :\
172.16.0.0/12 : 10.0.0.0/8 : 169.254.0.0/16
no_more
nonlocal:
debug_print = "R: nonlocal for $local_part@$domain"
driver = redirect
allow_fail
data = :fail: Mailing to remote domains not supported
no_more
COND_LOCAL_SUBMITTER = "\
${if match_ip{$sender_host_address}{:@[]}\
{1}{0}\
real_local:
debug_print = "R: real_local for $local_part@$domain"
driver = accept
condition = COND_LOCAL_SUBMITTER
local_part_prefix = real-
check_local_user
transport = LOCAL_DELIVERY
procmail:
debug_print = "R: procmail for $local_part@$domain"
driver = accept
check_local_user
transport = procmail_pipe
# emulate OR with "if exists"-expansion
require_files = ${local_part}:\
${if exists{/etc/procmailrc}\
{/etc/procmailrc}{${home}/.procmailrc}}:\
+/usr/bin/procmail
no_verify
no_expn
maildrop:
debug_print = "R: maildrop for $local_part@$domain"
driver = accept
check_local_user
transport = maildrop_pipe
require_files = ${local_part}:${home}/.mailfilter:+/usr/bin/maildrop
no_verify
no_expn
local_user:
debug_print = "R: local_user for $local_part@$domain"
driver = accept
check_local_user
local_parts = ! root
cannot_route_message = Unknown user
mail4root:
debug_print = "R: mail4root for $local_part@$domain"
driver = redirect
data = /var/mail/mail
local_parts = root
user = mail
group = mail
begin transports
vmail:
debug_print = "T: vmail for $local_part@$domain"
driver = appendfile
user = mail
maildir_format = true
directory = /var/vmail/$domain/$local_part
create_directory
delivery_date_add
envelope_to_add
return_path_add
group = mail
mode = 0600
mail_spool:
debug_print = "T: appendfile for $local_part@$domain"
driver = appendfile
file = /var/mail/$local_part
delivery_date_add
envelope_to_add
return_path_add
group = mail
mode = 0660
mode_fail_narrower = false
maildir_home:
debug_print = "T: maildir_home for $local_part@$domain"
driver = appendfile
.ifdef MAILDIR_HOME_MAILDIR_LOCATION
directory = MAILDIR_HOME_MAILDIR_LOCATION
.else
directory = $home/Maildir
.endif
.ifdef MAILDIR_HOME_CREATE_DIRECTORY
create_directory
.endif
.ifdef MAILDIR_HOME_CREATE_FILE
create_file = MAILDIR_HOME_CREATE_FILE
.endif
delivery_date_add
envelope_to_add
return_path_add
maildir_format
.ifdef MAILDIR_HOME_DIRECTORY_MODE
directory_mode = MAILDIR_HOME_DIRECTORY_MODE
.else
directory_mode = 0700
.endif
.ifdef MAILDIR_HOME_MODE
mode = MAILDIR_HOME_MODE
.else
mode = 0600
.endif
maildrop_pipe:
debug_print = "T: maildrop_pipe for $local_part@$domain"
driver = pipe
path = "/bin:/usr/bin:/usr/local/bin"
command = "/usr/bin/maildrop"
return_path_add
delivery_date_add
envelope_to_add
procmail_pipe:
debug_print = "T: procmail_pipe for $local_part@$domain"
driver = pipe
command = "/usr/bin/procmail"
return_path_add
delivery_date_add
envelope_to_add
remote_smtp:
debug_print = "T: remote_smtp for $local_part@$domain"
driver = smtp
.ifdef DKIM_ENABLE
dkim_domain = $sender_address_domain
.ifdef DKIM_SELECTOR
dkim_selector = DKIM_SELECTOR
.endif
.ifdef DKIM_PRIVATE_KEY
dkim_private_key = DKIM_PRIVATE_KEY
.endif
.ifdef DKIM_CANON
dkim_canon = DKIM_CANON
.endif
.ifdef DKIM_STRICT
dkim_strict = DKIM_STRICT
.endif
.ifdef DKIM_SIGN_HEADERS
dkim_sign_headers = DKIM_SIGN_HEADERS
.endif
.endif
address_file:
debug_print = "T: address_file for $local_part@$domain"
driver = appendfile
delivery_date_add
envelope_to_add
return_path_add
address_pipe:
debug_print = "T: address_pipe for $local_part@$domain"
driver = pipe
return_fail_output
address_reply:
debug_print = "T: autoreply for $local_part@$domain"
driver = autoreply
begin retry
* * F,2h,15m; G,16h,1h,1.5; F,4d,6h
begin rewrite
begin authenticators
login:
driver = plaintext
public_name = LOGIN
server_prompts = Username:: : Password::
server_condition = ${extract {address} {${readsocket{COURIERSOCKET} \
{AUTH ${strlen:exim\nlogin\n$1\n$2\n}\nexim\nlogin\n$1\n$2\n} }} {yes} fail}
server_set_id = $1
plain:
driver = plaintext
public_name = PLAIN
server_prompts = :
{AUTH ${strlen:exim\nlogin\n$2\n$3\n}\nexim\nlogin\n$2\n$3\n} }} {yes} fail}
server_set_id = $2
server_advertise_condition = ${if eq{$tls_cipher}{} {no} {yes}}
