Probleme mit Duplicity
Tristan
Hallo, ich habe grade Duplicity eingerichtet und wollte ein full Backup starten.
Erhalte aber folgenden Fehler:
ares:~# /usr/local/bin/duply ares.xxx.de full
Start duply v1.5.1.4, time is 02/01/10 15:24:05.
Using profile '/root/.duply/ares.xxx.de'.
Using installed duplicity version 0.6.06, gpg 1.4.9 (Home: ~/.gnupg)
Test - Encryption with key DBC933AF (OK)
Test - Decryption with key DBC933AF (OK)
Test - Compare Original w/ Decryption (OK)
Cleanup - Delete '/tmp/duply.16286.1265034245_*'(OK)
--- Start running command FULL 15:24:05.877 ---
NcFTP version is 3.2.1
Reading globbing filelist /root/.duply/ares.xxx.de/exclude
Local and Remote metadata are synchronized, no sync needed.
Last full backup date: none
Traceback (most recent call last):
File "/usr/bin/duplicity", line 1236, in <module>
with_tempdir(main)
File "/usr/bin/duplicity", line 1229, in with_tempdir
fn()
File "/usr/bin/duplicity", line 1202, in main
full_backup(col_stats)
File "/usr/bin/duplicity", line 416, in full_backup
globals.backend)
File "/usr/bin/duplicity", line 294, in write_multivol
globals.gpg_profile, globals.volsize)
File "/usr/lib/python2.5/site-packages/duplicity/gpg.py", line 282, in GPGWrit eFile
data = block_iter.next(min(block_size, bytes_to_go)).data
File "/usr/lib/python2.5/site-packages/duplicity/diffdir.py", line 509, in nex t
result = self.process(self.input_iter.next(), size)
File "/usr/lib/python2.5/site-packages/duplicity/diffdir.py", line 635, in pro cess
data, last_block = self.get_data_block(fp, size - 512)
File "/usr/lib/python2.5/site-packages/duplicity/diffdir.py", line 662, in get _data_block
buf = fp.read(read_size)
File "/usr/lib/python2.5/site-packages/duplicity/diffdir.py", line 419, in rea d
buf = self.infile.read(length)
File "/usr/lib/python2.5/site-packages/duplicity/diffdir.py", line 388, in rea d
IOError: [Errno 3] No such process
--- Finished state FAILED (code 30) at 15:24:09.585 - Runtime 00:00:03.707 ---
Jemand ne Idee worans liegt?
Grüße und danke.
