Probleme mit dem Socket nach Upgrade
  • Thread starter Thread starter Deleted member 13046
  • Start date Start date
D
hab Debian 9.1 mit Nginx und Maria DB, Postfix usw.
Lief bisher alles super, nur jetzt spinnt nach einem Upgrade der Mysql Socket.
log sagt:
Oct 11 13:00:18 enterprise dovecot: auth-worker(1303): Error: mysql(localhost): Connect failed to database (dbispconfig): Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2 "No such file or directory") - waiting for 1 seconds before retry
Oct 11 13:00:18 enterprise postfix/pipe[943]: AF6453EA2840: to=<info@xxxxxxxxx.de>, relay=dovecot, delay=70, delays=0.07/0.01/0/69, dsn=4.3.0, status=deferred (temporary failure)
Oct 11 13:00:19 enterprise dovecot: auth-worker(1303): Error: mysql(localhost): Connect failed to database (dbispconfig): Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2 "No such file or directory") - waiting for 5 seconds before retry
Oct 11 13:00:24 enterprise dovecot: auth-worker(1303): Error: mysql(localhost): Connect failed to database (dbispconfig): Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2 "No such file or directory") - waiting for 25 seconds before retry
Oct 11 13:00:49 enterprise dovecot: auth-worker(1303): Error: mysql(localhost): Connect failed to database (dbispconfig): Can't connect to local MySQL server through socket '/var/run/mysql/mysql.sock' (2 "No such file or directory") - waiting for 125 seconds before retry
Oct 11 13:01:01 enterprise CRON[1317]: (root) CMD (/usr/local/ispconfig/server/server.sh 2>&1 | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Oct 11 13:01:01 enterprise CRON[1318]: (root) CMD (/usr/local/ispconfig/server/cron.sh 2>&1 | while read line; do echo `/bin/date` "$line" >> /var/log/ispconfig/cron.log; done)
Ich kann mich per (mysql -u root -p) in die Datenbank einloggen, also die läuft.
ps -A|grep mysql gibt mir
700 ? 00:00:00 pure-ftpd-mysql
3159 ? 00:00:00 mysqld
Irgendwo wird da ein falscher Socket verwendet, also vermute ich mal.
Kann das sein?
Jemand eine Idee?
Danke Gruß Haxley
