Probleme bei der umstellung auf MySQL von Postfix und Dovecot
I_Maruko_I
Hallo erstmal.
Ich wollte Postfix und Dovecot auf MySQL umstellen.
Das bedeutet das Ich nur noch Virtuelle benutzer nutzen will und dafür auch schon alles angelegt habe.
Ich habe diese Tutorial benutzt:
Mail server HOWTO - Postfix and Dovecot with MySQL and TLS/SSL, Postgrey and DSPAM at Johnny Chadda .se
Die meisten Sachen habe ich auch so hinbekommen wie sie dort standen, oder ich konnte sie anders ableiten.
Leider klappt es nicht wirklich so wie in der Beschreibung steht.
Hier ist erstmal meine Dovecot Config:
## Dovecot configuration file
ssl_disable = yes
# Base directory where to store runtime data.
base_dir = /var/run/dovecot/
# Protocols we want to be serving: imap imaps pop3 pop3s
# If you only want to use dovecot-auth, you can set this to "none".
#protocols = imap imaps
protocols = imap pop3
listen =
disable_plaintext_auth = no
#shutdown_clients = yes
## Logging
# Log file to use for error messages, instead of sending them to syslog.
# /dev/stderr can be used to log into stderr.
log_path = /var/log/dovecot/log.log
# Log file to use for informational and debug messages.
# Default is the same as log_path.
info_log_path = /var/log/dovecot/info.log
# Prefix for each line written to log file. % codes are in strftime(3)
# format.
log_timestamp = "%Y-%m-%d %H:%M:%s "
# Syslog facility to use if you're logging to syslog. Usually if you don't
# want to use "mail", you'll use local0..local7. Also other standard
# facilities are supported.
syslog_facility = mail
## SSL settings
# IP or host address where to listen in for SSL connections. Defaults
# to above if not specified.
#ssl_listen =
ssl_listen =
## Login processes
login_dir = /var/run/dovecot/login
## Mailbox locations and namespaces
mail_extra_groups = mail
## Mail processes
mail_debug = no
first_valid_uid = 150
last_valid_uid = 150
## Maildir-specific settings
# When copying a message, do it with hard links whenever possible. This makes
# the performance much better, and it's unlikely to have any side effects.
maildir_copy_with_hardlinks = yes
## mbox-specific settings
## dbox-specific settings
# Maximum dbox file size in kilobytes until it's rotated.
#dbox_rotate_size = 2048
# Minimum dbox file size in kilobytes before it's rotated
# (overrides dbox_rotate_days)
#dbox_rotate_min_size = 16
# Maximum dbox file age in days until it's rotated. Day always begins from
# midnight, so 1 = today, 2 = yesterday, etc. 0 = check disabled.
#dbox_rotate_days = 0
## IMAP specific settings
protocol imap {
  # Login executable location.
  login_executable = /usr/local/libexec/dovecot/imap-login
  # IMAP executable location. Changing this allows you to execute other
  # binaries before the imap process is executed.
  # This would write rawlogs into ~/dovecot.rawlog/ directory:
  #   mail_executable = /usr/libexec/dovecot/rawlog /usr/libexec/dovecot/imap
  # This would attach gdb into the imap process and write backtraces into
  # /tmp/gdbhelper.* files:
  #   mail_executable = /usr/libexec/dovecot/gdbhelper /usr/libexec/dovecot/imap
  mail_executable = /usr/local/libexec/dovecot/imap
  # Maximum IMAP command line length in bytes. Some clients generate very long
  # command lines with huge mailboxes, so you may need to raise this if you get
  # "Too long argument" or "IMAP command line too large" errors often.
  imap_max_line_length = 65536
  # Support for dynamically loadable plugins. mail_plugins is a space separated
  # list of plugins to load.
  #mail_plugins =
  #mail_plugin_dir = /usr/lib/dovecot/imap
  # Send IMAP capabilities in greeting message. This makes it unnecessary for
  # clients to request it with CAPABILITY command, so it saves one round-trip.
  # Many clients however don't understand it and ask the CAPABILITY anyway.
  #login_greeting_capability = no
  # Override the IMAP CAPABILITY response.
  #imap_capability =
  # Workarounds for various client bugs:
  #   delay-newmail:
  #     Send EXISTS/RECENT new mail notifications only when replying to NOOP
  #     and CHECK commands. Some clients ignore them otherwise, for example OSX
  #     Mail (<v2.1). Outlook Express breaks more badly though, without this it
  #     may show user "Message no longer in server" errors. Note that OE6 still
  #     breaks even with this workaround if synchronization is set to
  #     "Headers Only".
  #   outlook-idle:
  #     Outlook and Outlook Express never abort IDLE command, so if no mail
  #     arrives in half a hour, Dovecot closes the connection. This is still
  #     fine, except Outlook doesn't connect back so you don't see if new mail
  #     arrives.
  #   netscape-eoh:
  #     Netscape 4.x breaks if message headers don't end with the empty "end of
  #     headers" line. Normally all messages have this, but setting this
  #     workaround makes sure that Netscape never breaks by adding the line if
  #     it doesn't exist. This is done only for FETCH BODY[HEADER.FIELDS..]
  #     commands. Note that RFC says this shouldn't be done.
  #   tb-extra-mailbox-sep:
  #     With mbox storage a mailbox can contain either mails or submailboxes,
  #     but not both. Thunderbird separates these two by forcing server to
  #     accept '/' suffix in mailbox names in subscriptions list.
  # The list is space-separated.
  #imap_client_workarounds = outlook-idle
## POP3 specific settings
protocol pop3 {
  login_executable = /usr/local/libexec/dovecot/pop3-login
  # POP3 executable location. See IMAP's mail_executable above for examples
  # how this could be changed.
  mail_executable = /usr/local/libexec/dovecot/pop3
  # Don't try to set mails non-recent or seen with POP3 sessions. This is
  # mostly intended to reduce disk I/O. With maildir it doesn't move files
  # from new/ to cur/, with mbox it doesn't write Status-header.
  #pop3_no_flag_updates = no
  # Support LAST command which exists in old POP3 specs, but has been removed
  # from new ones. Some clients still wish to use this though. Enabling this
  # makes RSET command clear all \Seen flags from messages.
  #pop3_enable_last = no
  # If mail has X-UIDL header, use it as the mail's UIDL.
  #pop3_reuse_xuidl = no
  # Keep the mailbox locked for the entire POP3 session.
  #pop3_lock_session = no
  # POP3 UIDL (unique mail identifier) format to use. You can use following
  # variables:
  #  %v - Mailbox's IMAP UIDVALIDITY
  #  %u - Mail's IMAP UID
  #  %m - MD5 sum of the mailbox headers in hex (mbox only)
  #  %f - filename (maildir only)
  # If you want UIDL compatibility with other POP3 servers, use:
  #  UW's ipop3d         : %08Xv%08Xu
  #  Courier version 0   : %f
  #  Courier version 1   : %u
  #  Courier version 2   : %v-%u
  #  Cyrus (<= 2.1.3)    : %u
  #  Cyrus (>= 2.1.4)    : %v.%u
  #  Older Dovecots      : %v.%u
  #  tpop3d              : %Mf
  # Note that Outlook 2003 seems to have problems with %v.%u format which was
  # Dovecot's default, so if you're building a new server it would be a good
  # idea to change this. %08Xu%08Xv should be pretty fail-safe.
  # NOTE: Nowadays this is required to be set explicitly, since the old
  # default was bad but it couldn't be changed without breaking existing
  # installations. %08Xu%08Xv will be the new default, so use it for new
  # installations.
  pop3_uidl_format = %08Xu%08Xv
  # POP3 logout format string:
  #  %t - number of TOP commands
  #  %p - number of bytes sent to client as a result of TOP command
  #  %r - number of RETR commands
  #  %b - number of bytes sent to client as a result of RETR command
  #  %d - number of deleted messages
  #  %m - number of messages (before deletion)
  #  %s - mailbox size in bytes (before deletion)
  #pop3_logout_format = top=%t/%p, retr=%r/%b, del=%d/%m, size=%s
  #mail_plugins =
  #mail_plugin_dir = /usr/lib/dovecot/pop3
  #   outlook-no-nuls:
  #     Outlook and Outlook Express hang if mails contain NUL characters.
  #     This setting replaces them with 0x80 character.
  #   oe-ns-eoh:
  #     Outlook Express and Netscape Mail breaks if end of headers-line is
  #     missing. This option simply sends it if it's missing.
  #pop3_client_workarounds =
## LDA specific settings
protocol lda {
  # Address to use when sending rejection mails.
  postmaster_address = postmaster@ragnatech.de
  # Hostname to use in various parts of sent mails, eg. in Message-Id.
  # Default is the system's real hostname.
  #hostname =
  #mail_plugins =
  #mail_plugin_dir = /usr/lib/dovecot/lda
  # Binary to use for sending mails.
  sendmail_path = /usr/lib/sendmail
  # UNIX socket path to master authentication server to find users.
  auth_socket_path = /var/run/dovecot/auth-master
## Authentication processes
# Executable location
#auth_executable = /usr/libexec/dovecot/dovecot-auth
# Set max. process size in megabytes.
#auth_process_size = 256
# Authentication cache size in kilobytes. 0 means it's disabled.
# Note that bsdauth, PAM and vpopmail require cache_key to be set for caching
# to be used.
#auth_cache_size = 0
# Time to live in seconds for cached data. After this many seconds the cached
# record is no longer used, *except* if the main database lookup returns
# internal failure. We also try to handle password changes automatically: If
# user's previous authentication was successful, but this one wasn't, the
# cache isn't used. For now this works only with plaintext authentication.
#auth_cache_ttl = 3600
# Space separated list of realms for SASL authentication mechanisms that need
# them. You can leave it empty if you don't want to support multiple realms.
# Many clients simply use the first one listed here, so keep the default realm
# first.
#auth_realms =
# Default realm/domain to use if none was specified. This is used for both
# SASL realms and appending @domain to username in plaintext logins.
#auth_default_realm =
# List of allowed characters in username. If the user-given username contains
# a character not listed in here, the login automatically fails. This is just
# an extra check to make sure user can't exploit any potential quote escaping
# vulnerabilities with SQL/LDAP databases. If you want to allow all characters,
# set this value to empty.
#auth_username_chars = abcdefghijklmnopqrstuvwxyzABCDEFGHIJKLMNOPQRSTUVWXYZ01234567890.-_@
# Username character translations before it's looked up from databases. The
# value contains series of from -> to characters. For example "#@/@" means
# that '#' and '/' characters are translated to '@'.
#auth_username_translation =
# Username formatting before it's looked up from databases. You can use
# the standard variables here, eg. %Lu would lowercase the username, %n would
# drop away the domain if it was given, or "%n-AT-%d" would change the '@' into
# "-AT-". This translation is done after auth_username_translation changes.
#auth_username_format =
# If you want to allow master users to log in by specifying the master
# username within the normal username string (ie. not using SASL mechanism's
# support for it), you can specify the separator character here. The format
# is then <username><separator><master username>. UW-IMAP uses "*" as the
# separator, so that could be a good choice.
#auth_master_user_separator =
# Username to use for users logging in with ANONYMOUS SASL mechanism
#auth_anonymous_username = anonymous
# More verbose logging. Useful for figuring out why authentication isn't
# working.
auth_verbose = no
# Even more verbose logging for debugging purposes. Shows for example SQL
# queries.
auth_debug = no
# In case of password mismatches, log the passwords and used scheme so the
# problem can be debugged. Requires auth_debug=yes to be set.
auth_debug_passwords = no
# Maximum number of dovecot-auth worker processes. They're used to execute
# blocking passdb and userdb queries (eg. MySQL and PAM). They're
# automatically created and destroyed as needed.
#auth_worker_max_count = 30
# Host name to use in GSSAPI principal names. The default is to use the
# name returned by gethostname().
#auth_gssapi_hostname =
# Kerberos keytab to use for the GSSAPI mechanism. Will use the system
# default (usually /etc/krb5.keytab) if not specified.
#auth_krb5_keytab =
auth default {
  # Space separated list of wanted authentication mechanisms:
  #   plain login digest-md5 cram-md5 ntlm rpa apop anonymous gssapi
  mechanisms = plain
  # Password database is used to verify user's password (and nothing more).
  # You can have multiple passdbs and userdbs. This is useful if you want to
  # allow both system users (/etc/passwd) and virtual users to login without
  # duplicating the system users into virtual database.
  # <doc/wiki/PasswordDatabase.txt>
  # By adding master=yes setting inside a passdb you make the passdb a list
  # of "master users", who can log in as anyone else. Unless you're using PAM,
  # you probably still want the destination user to be looked up from passdb
  # that it really exists. This can be done by adding pass=yes setting to the
  # master passdb. <doc/wiki/Authentication.MasterUsers.txt>
  # Users can be temporarily disabled by adding a passdb with deny=yes.
  # If the user is found from that database, authentication will fail.
  # The deny passdb should always be specified before others, so it gets
  # checked first. Here's an example:
  #passdb passwd-file {
    # File contains a list of usernames, one per line
    #args = /etc/dovecot.deny
    #deny = yes
  # PAM authentication. Preferred nowadays by most systems.
  # Note that PAM can only be used to verify if user's password is correct,
  # so it can't be used as userdb. If you don't want to use a separate user
  # database (passwd usually), you can use static userdb.
  # REMEMBER: You'll need /etc/pam.d/dovecot file created for PAM
  # authentication to actually work. <doc/wiki/PasswordDatabase.PAM.txt>
  #passdb pam {
    # [blocking=yes] [session=yes] [setcred=yes]
    # [cache_key=<key>] [<service name>]
    # By default a new process is forked from dovecot-auth for each PAM lookup.
    # Setting blocking=yes uses the alternative way: dovecot-auth worker
    # processes do the PAM lookups.
    # session=yes makes Dovecot open and immediately close PAM session. Some
    # PAM plugins need this to work, such as pam_mkhomedir.
    # setcred=yes makes Dovecot establish PAM credentials if some PAM plugins
    # need that. They aren't ever deleted though, so this isn't enabled by
    # default.
    # cache_key can be used to enable authentication caching for PAM
    # (auth_cache_size also needs to be set). It isn't enabled by default
    # because PAM modules can do all kinds of checks besides checking password,
    # such as checking IP address. Dovecot can't know about these checks
    # without some help. cache_key is simply a list of variables (see
    # doc/wiki/Variables.txt) which must match for the cached data to be used.
    # Here are some examples:
    #   %u - Username must match. Probably sufficient for most uses.
    #   %u%r - Username and remote IP address must match.
    #   %u%s - Username and service (ie. IMAP, POP3) must match.
    # If service name is "*", it means the authenticating service name
    # is used, eg. pop3 or imap (/etc/pam.d/pop3, /etc/pam.d/imap).
    # Some examples:
    #   args = session=yes *
    #   args = cache_key=%u dovecot
    #args = /etc/dovecot/dovecot-sql.conf
  # /etc/passwd or similar, using getpwnam()
  # In many systems nowadays this uses Name Service Switch, which is
  # configured in /etc/nsswitch.conf. <doc/wiki/AuthDatabase.Passwd.txt>
  #passdb passwd {
    # [blocking=yes] - See userdb passwd for explanation
    #args =
  # /etc/shadow or similiar, using getspnam(). Deprecated by PAM nowadays.
  # <doc/wiki/PasswordDatabase.Shadow.txt>
  #passdb shadow {
    #args =
  # PAM-like authentication for OpenBSD.
  # <doc/wiki/PasswordDatabase.BSDAuth.txt>
  #passdb bsdauth {
    # [cache_key=<key>] - See cache_key in PAM for explanation.
    #args =
  # passwd-like file with specified location
  # <doc/wiki/AuthDatabase.PasswdFile.txt>
    # Path for passwd-file
    #args =
  # checkpassword executable authentication
  # NOTE: You will probably want to use "userdb prefetch" with this.
  # <doc/wiki/PasswordDatabase.CheckPassword.txt>
  #passdb checkpassword {
    # Path for checkpassword binary
    #args =
  # SQL database <doc/wiki/AuthDatabase.SQL.txt>
  passdb sql {
    # Path for SQL configuration file, see doc/dovecot-sql-example.conf
    args = /usr/local/etc/dovecot-sql.conf
  # LDAP database <doc/wiki/AuthDatabase.LDAP.txt>
  #passdb ldap {
    # Path for LDAP configuration file, see doc/dovecot-ldap-example.conf
    #args =
  # vpopmail authentication <doc/wiki/AuthDatabase.VPopMail.txt>
  #passdb vpopmail {
    #args =
  # User database specifies where mails are located and what user/group IDs
  # own them. For single-UID configuration use "static".
  # <doc/wiki/UserDatabase.txt>
  # /etc/passwd or similar, using getpwnam(). In many systems nowadays this
  # uses Name Service Switch, which is configured in /etc/nsswitch.conf.
  # <doc/wiki/AuthDatabase.Passwd.txt>
  #userdb passwd {
    # [blocking=yes] - By default the lookups are done in the main dovecot-auth
    # process. This setting causes the lookups to be done in auth worker
    # proceses. Useful with remote NSS lookups that may block.
    # NOTE: Be sure to use this setting with nss_ldap or users might get
    # logged in as each others!
    #args =
  #userdb passwd-file {
    #args =
  # static settings generated from template <doc/wiki/UserDatabase.Static.txt>
  #userdb static {
    # Template for the fields. Can return anything a userdb could normally
    # return. For example:
    #  args = uid=500 gid=500 home=/var/mail/%u
    # If you use deliver, it needs to look up users only from the userdb. This
    # of course doesn't work with static because there is no list of users.
    # Normally static userdb handles this by doing a passdb lookup. This works
    # with most passdbs, with PAM being the most notable exception. If you do
    # the user verification another way, you can add allow_all_users=yes to
    # the args in which case the passdb lookup is skipped.
    #args =
  userdb sql {
  #userdb ldap {
    #args =
  # vpopmail <doc/wiki/AuthDatabase.VPopMail.txt>
  #userdb vpopmail {
  # "prefetch" user database means that the passdb already provided the
  # needed information and there's no need to do a separate userdb lookup.
  # This can be made to work with SQL and LDAP databases, see their example
  # configuration files for more information how to do it.
  # <doc/wiki/UserDatabase.Prefetch.txt>
  #userdb prefetch {
  # User to use for the process. This user needs access to only user and
  # password databases, nothing else. Only shadow and pam authentication
  # requires roots, so use something else if possible. Note that passwd
  # authentication with BSDs internally accesses shadow files, which also
  # requires roots. Note that this user is NOT used to access mails.
  # That user is specified by userdb above.
  user = nobody
  # Directory where to chroot the process. Most authentication backends don't
  # work if this is set, and there's no point chrooting if auth_user is root.
  # Note that valid_chroot_dirs isn't needed to use this setting.
  #chroot =
  # Number of authentication processes to create
  #count = 1
  # Require a valid SSL client certificate or the authentication fails.
  #ssl_require_client_cert = no
  # Take the username from client's SSL certificate, using
  # X509_NAME_get_text_by_NID() which returns the subject's DN's
  # CommonName.
  #ssl_username_from_cert = no
  # It's possible to export the authentication interface to other programs:
  socket listen {
    master {
      # Master socket provides access to userdb information. It's typically
      # used to give Dovecot's local delivery agent access to userdb so it
      # can find mailbox locations.
      mode = 0600
      # Default user/group is the one who started dovecot-auth (root)
      user = vmail
      group = mail
    client {
      # The client socket is generally safe to export to everyone. Typical use
      # is to export it to your SMTP server so it can do SMTP AUTH lookups
      # using it.
      path = /var/run/dovecot/auth-client
      mode = 0660
      user = postfix
      group = postfix
dict {
  #quota = mysql:/etc/dovecot-dict-quota.conf
## Plugin settings
plugin {
Ich hab den Text so gut es geht gekürzt.
Hier noch schnell die Datenbank-Querys:
driver = mysql
connect = host=localhost dbname=mail user=mail password=mail
# The new name for MD5 is MD5-CRYPT so you might need to change this depending on version
default_pass_scheme = MD5-CRYPT
# Get the mailbox
user_query = SELECT '/var/vmail/%d/%n' as home, 'maildir:/var/vmail/%d/%n' as mail, 150 AS uid, 8 AS gid, concat('dirsize:storage=', quota) AS quota FROM mailbox WHERE username = '&u' AND active = '1'
# Get the password
password_query = SELECT username as user, password, '/var/vmail/%d/%n' as userdb_home, 'maildir:/var/vmail/%d/%n' as userdb_mail, 150 as userdb_uid, 8 as userdb_gid FROM mailbox WHERE username = '%u' AND active = '1'
# If using client certificates for authentication, comment the above and uncomment the following
#password_query = SELECT null AS password, '%u' AS user
In den Logfiles von Dovecote steht:
dovecot: 2007-05-30 18:18:1180541910 Error: auth(default): userdb(tholen@ragnatech.de,88.77.15.159): user not found from userdb
Dabei ist der User in der Datenbank!!!
So, habe meinen Fehler nach einer Nacht durch Tippen endlich gefunden.
War unter anderem haupsächlich einfache Tippfehler.
Aber ein Problem ist noch geblieben!
Bei dem HowTo soll man bei Postfix den SASL auf "dovecot" umstellen, und den SASL-Path auf "private/auth".
Das löst allerdings etliche Fehler aus, und nichts geht mehr danach.
Wenn ich es nicht umstelle, läuft es trotzdem, da ich SASL vorher schonmal richtig eingestellt hatte.
Danke nochmal an Huschi!!! :)
Allerdings ist durch diese alte Configuration nicht alles so perfekt wie es sein soll.
Ich würde gern die DB von Postfixadmin nutzen. Allerdings stehen dort die Passwörter in "MD5-Crypt", und in der aktuellen DB stehen die noch in PLAIN.
Wie erklär ich jetzt SASL das er die anderen versteht?
Marco
